Auriez vous des logs ? Il est possible que la relance ne passe pas en fonction de la puissance de la machine. Mais pour corriger (rapidement bien évidement) il me faudrait la log.
Le plugin ne tournait pas avec les logs debug, du coup j’ai que ca actuellement pour les logs du blea local, c’est un peu léger je pense…je les ai activé en debug donc ce soir ca devrait être plus parlant.
0021|[2024-09-07 00:02:58] ERROR : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 17, error: Invalid Index)
0022|[2024-09-07 00:02:58] ERROR : Error on send request to jeedom HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/blea/core/php/jeeBlea.php?apikey=N6vCDmshK298ANQ1gA7LX8GyZ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75e55910>: Failed to establish a new connection: [Errno 111] Connection refused')) retry : 0/3
0023|[2024-09-07 00:02:58] ERROR : Error on send request to jeedom HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/blea/core/php/jeeBlea.php?apikey=N6vCDmshK298ANQ1gA7LX8GyZ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75e550f0>: Failed to establish a new connection: [Errno 111] Connection refused')) retry : 1/3
0024|[2024-09-07 00:02:58] ERROR : Error on send request to jeedom HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/blea/core/php/jeeBlea.php?apikey=N6vCDmshK298ANQ1gA7LX8GyZ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x733c92f0>: Failed to establish a new connection: [Errno 111] Connection refused')) retry : 2/3
0025|[2024-09-08 00:00:24] ERROR : GLOBAL------Fatal error : [Errno 98] Address already in use
0026|[2024-09-09 00:00:23] ERROR : GLOBAL------Fatal error : [Errno 98] Address already in use
0027|Can't get device info: No such device
0028|Can't get device info: No such device
0029|Can't get device info: No such device
0030|Can't get device info: No such device
0047|[2024-09-09 00:03:46] ERROR : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 17, error: Invalid Index)
0048|[2024-09-09 00:03:46] ERROR : Error on send request to jeedom HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/blea/core/php/jeeBlea.php?apikey=N6vCDmshK298ANQ1gA7LX8GyZ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73d4ee10>: Failed to establish a new connection: [Errno 111] Connection refused')) retry : 0/3
0049|[2024-09-09 00:03:46] ERROR : Error on send request to jeedom HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/blea/core/php/jeeBlea.php?apikey=N6vCDmshK298ANQ1gA7LX8GyZ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73d4e770>: Failed to establish a new connection: [Errno 111] Connection refused')) retry : 1/3
0050|[2024-09-09 00:03:46] ERROR : Error on send request to jeedom HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/blea/core/php/jeeBlea.php?apikey=N6vCDmshK298ANQ1gA7LX8GyZ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73d6e030>: Failed to establish a new connection: [Errno 111] Connection refused')) retry : 2/3
Pour info je tourne sur un RPI 3 B.
Idem, depuis la mise à jour le demon ne se lance plus et les dependances ne s’installent plus
Pas bcp de log helas:
0000|[2024-09-09 11:00:03] ERROR : Erreur sur la fonction cron15 du plugin : Call to a member function getRemoteName() on bool
0001|[2024-09-09 11:15:04] ERROR : Erreur sur la fonction cron15 du plugin : Call to a member function getRemoteName() on bool
0002|[2024-09-09 11:45:04] ERROR : Erreur sur la fonction cron15 du plugin : Call to a member function getRemoteName() on bool
Si cela peut aider…
Debian 10 sur RPI 4
Il faudrait essayer de passer debian 11 pour que ça soit plus facile pour nous.
Et puis arrêter de mettre a jour vos plugin et jeedom pour debian 10.
Je vous rappel que debian 10 et devenu obsolète pour jeedom.
pas juste pour jeedom
Ca c’est un autre soucis je connais pas assez le plugin pour le corriger celui la.
C’est vrai qu’il serait préférable que je migre sous Debian 11. Mais pour l’instant tout fonctionnait plutôt bien en debian 10 (jusqu’à ce petit problème de plugin blea). Je lance les mises à jour parfois de façon automatique, sans me poser la question de la version de debian.
S’il est préconisé de plus mettre à jour ses plugins, existerait-il une option dans Jeedom pour éventuellement (ceux qui le souhaitent) ne plus proposer les maj dans le centre de mises à jour ?
je ne serais répondre à cette question, mais peu être @Loic.
Pas de bol
faut cocher la case:
de plus, à l’avenir un plugin pourra spécifier la version os minimum requise (si jeedom core > 4.4.15) donc la mise à jour des plugins qui auront spécifiés ce paramètre sera automatiquement bloquée si version debian pas suffisante.
Top merci !
Je fais face au même problème que @MicaZ a remonté précédemment depuis la MAJ, à savoir une perte de co à minuit (il semble que le démon redémarre plusieurs fois de suite à minuit).
J’ai désactivé ce matin le cron « daily » pour voir ce que ça va donner ce soir, mais c’est effectivement pénible car l’état « mergé » de mes Nuts apparait comme absent du coup (alors que mes nuts eux repassent en Présent), comme si les changements d’état se font tellement vite que les routines (virtuels / scénarios etc.) n’arrivent pas à suivre …
Au vu des messages, cela semble fortement lié à la MAJ.
C’est 100% liée a la mise a jour il n’y a aucun doute a avoir la dessus malheureusement si vous me communiquer pas les information que je demande il ne pourra jamais avoir de correction. C’est vraiment dommage car avec les informations je devrais pouvoir corriger très rapidement et vous sortir de l’embaras.
Couper le cron comme tu l’as fait est complètement irresponsable tu vas avoir des conséquence partout dans ton jeedom et ca se trouve les voir que dans plusieurs mois quand ca sera irréparable.
Je réalise le même constat que @Technizo, message tous les soirs à minuit sur le plugin BLEA.
Voici le message : « 0000|[2024-09-10 00:00:05] ERROR : GLOBAL------Fatal error : [Errno 98] Address already in use »
La page santé de mon Jeedom :
La page du plugin de mon Jeedom :
J’ai pensé également à couper le cron, mais je viens de lire que ce n’est pas la bonne solution.
Ok merci j’ai enfin un bout de log… donc semaine une bêta va sortir et devrait corriger le soucis si vous pouvez tester (demain donc) et me dire si c’est bon ou pas je verrais ensuite pour faire une stable
Pas de soucis, merci
J’avais déjà fourni le bout de log précédent mais ca me semblait léger…J’ai activé entre temps les logs en debug, voici ce que j’ai eu hier soir:
[2024-09-11 00:00:21][ERROR] : GLOBAL------Fatal error : [Errno 98] Address already in use
[2024-09-11 00:00:21][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/blea/resources/blead/blead.py", line 588, in <module>
listen()
File "/var/www/html/plugins/blea/resources/blead/blead.py", line 179, in listen
jeedom_socket.open()
File "/var/www/html/plugins/blea/resources/blead/jeedom/jeedom.py", line 328, in open
self.netAdapter = TCPServer((self.address, self.port), jeedom_socket_handler)
File "/usr/lib/python3.7/socketserver.py", line 452, in __init__
self.server_bind()
File "/usr/lib/python3.7/socketserver.py", line 466, in server_bind
self.socket.bind(self.server_address)
OSError: [Errno 98] Address already in use
[2024-09-11 00:00:21][DEBUG] : GLOBAL------Shutdown
[2024-09-11 00:00:21][DEBUG] : GLOBAL------Removing PID file /tmp/jeedom/blea/deamon.pid
[2024-09-11 00:00:21][DEBUG] : GLOBAL------Closing all potential bluetooth connection
[2024-09-11 00:00:21][DEBUG] : Exit 0
[2024-09-11 00:00:22][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-09-11 00:00:22][DEBUG] : SOCKET-READ------Received command from jeedom : add
En espérant que ca aide
Je pense que ça enchaîne trop vite l’arrêt relance. La bêta sortie ce matin rajoute une pause de 60s à voir si ça suffit sinon j’utiliserai une autre approche
bonjour,
pour ma part j’ai aussi l’erreur GLOBAL------Fatal error : [Errno 98] Address already in use
l’erreur ne me dérange pas plus que ca (je suis aussi sous debian 10.7 et jeedom 4.4.16)
mon problème est que bléa me sert a détecter la présence de Nut et me notifie par message sur nos téléphones
donc tous les soirs après le redémarrage X messages sur nos téléphones
réveil pas top…
avez vous une solution pour supprimer ce redémarrage?
sinon je dois modifier un grand nombre de scenarios
merci pour vos infos
Comme dit 5 ou 6 fois la correction est en cours et meme disponible en beta si on me confirme que c’est bon tu aura demain la stable.
J’essaye vraiment de corriger au plus vite mais personne ne m’a donné les logs avant hier donc j’ai fait la correction hier soir en beta et si c’est bon tu l’auras demain je peux vraiment pas aller plus vite.
Mais je suis bien conscient de l’impact enorme que ca a sur votre domotique/maison et j’en suis vraiment désolé et je fais tout ce que je peux pour corriger au plus vite.
