[2024-02-23 20:49:55] ******************
[2024-02-23 20:49:55] * Update apt-get *
[2024-02-23 20:49:56] Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
[2024-02-23 20:49:56] Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
[2024-02-23 20:49:56] Hit:3 http://archive.raspberrypi.org/debian buster InRelease
[2024-02-23 20:50:08] Reading package lists...
[2024-02-23 20:50:08] ****************************
[2024-02-23 20:50:08] * Install apt-get packages *
[2024-02-23 20:50:09] Reading package lists...
[2024-02-23 20:50:11] Building dependency tree...
[2024-02-23 20:50:11] Reading state information...
[2024-02-23 20:50:14] python3 is already the newest version (3.7.3-1).
[2024-02-23 20:50:14] python3-dev is already the newest version (3.7.3-1).
[2024-02-23 20:50:14] python3-requests is already the newest version (2.21.0-1+deb10u1).
[2024-02-23 20:50:14] python3-setuptools is already the newest version (40.8.0-1).
[2024-02-23 20:50:14] python3-venv is already the newest version (3.7.3-1).
[2024-02-23 20:50:14] python3-pip is already the newest version (18.1-5+rpt1).
[2024-02-23 20:50:14] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-02-23 20:50:14] ***********************
[2024-02-23 20:50:14] * Create Python3 venv *
[2024-02-23 20:50:14] Python3 Version :: 3.7
[2024-02-23 20:50:29] Python3 venv : done
[2024-02-23 20:50:29] *****************************
[2024-02-23 20:50:29] * Install Python3 libraries *
[2024-02-23 20:50:34] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-02-23 20:50:34] Requirement already satisfied: pip in ./venv/lib/python3.7/site-packages (24.0)
[2024-02-23 20:50:41] Requirement already satisfied: wheel in ./venv/lib/python3.7/site-packages (0.42.0)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /simple/wheel/
[2024-02-23 20:50:57] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-02-23 20:50:57] Requirement already satisfied: PyChromecast==13.1.0 in ./venv/lib/python3.7/site-packages (13.1.0)
[2024-02-23 20:50:57] Requirement already satisfied: google-cloud-texttospeech==2.16.1 in ./venv/lib/python3.7/site-packages (2.16.1)
[2024-02-23 20:50:58] Requirement already satisfied: gTTS==2.5.1 in ./venv/lib/python3.7/site-packages (2.5.1)
[2024-02-23 20:50:58] Requirement already satisfied: pydub==0.25.1 in ./venv/lib/python3.7/site-packages (0.25.1)
[2024-02-23 20:50:58] Requirement already satisfied: protobuf>=3.19.1 in ./venv/lib/python3.7/site-packages (from PyChromecast==13.1.0) (4.24.4)
[2024-02-23 20:50:58] Requirement already satisfied: zeroconf>=0.25.1 in ./venv/lib/python3.7/site-packages (from PyChromecast==13.1.0) (0.131.0)
[2024-02-23 20:50:58] Requirement already satisfied: casttube>=0.2.0 in ./venv/lib/python3.7/site-packages (from PyChromecast==13.1.0) (0.2.1)
[2024-02-23 20:50:58] Requirement already satisfied: google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.0 in ./venv/lib/python3.7/site-packages (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.0->google-cloud-texttospeech==2.16.1) (2.17.1)
[2024-02-23 20:50:58] Requirement already satisfied: google-auth<3.0.0dev,>=2.14.1 in ./venv/lib/python3.7/site-packages (from google-cloud-texttospeech==2.16.1) (2.28.1)
[2024-02-23 20:50:58] Requirement already satisfied: proto-plus<2.0.0dev,>=1.22.3 in ./venv/lib/python3.7/site-packages (from google-cloud-texttospeech==2.16.1) (1.23.0)
[2024-02-23 20:50:58] Requirement already satisfied: requests<3,>=2.27 in ./venv/lib/python3.7/site-packages (from gTTS==2.5.1) (2.31.0)
[2024-02-23 20:50:58] Requirement already satisfied: click<8.2,>=7.1 in ./venv/lib/python3.7/site-packages (from gTTS==2.5.1) (8.1.7)
[2024-02-23 20:50:58] Requirement already satisfied: importlib-metadata in ./venv/lib/python3.7/site-packages (from click<8.2,>=7.1->gTTS==2.5.1) (6.7.0)
[2024-02-23 20:50:58] Requirement already satisfied: googleapis-common-protos<2.0.dev0,>=1.56.2 in ./venv/lib/python3.7/site-packages (from google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.0->google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.0->google-cloud-texttospeech==2.16.1) (1.62.0)
[2024-02-23 20:50:58] Requirement already satisfied: grpcio<2.0dev,>=1.33.2 in ./venv/lib/python3.7/site-packages (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.0->google-cloud-texttospeech==2.16.1) (1.62.0)
[2024-02-23 20:50:58] Requirement already satisfied: grpcio-status<2.0.dev0,>=1.33.2 in ./venv/lib/python3.7/site-packages (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.0->google-cloud-texttospeech==2.16.1) (1.62.0)
[2024-02-23 20:50:59] Requirement already satisfied: cachetools<6.0,>=2.0.0 in ./venv/lib/python3.7/site-packages (from google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.1) (5.3.2)
[2024-02-23 20:50:59] Requirement already satisfied: pyasn1-modules>=0.2.1 in ./venv/lib/python3.7/site-packages (from google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.1) (0.3.0)
[2024-02-23 20:50:59] Requirement already satisfied: rsa<5,>=3.1.4 in ./venv/lib/python3.7/site-packages (from google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.1) (4.9)
[2024-02-23 20:50:59] Requirement already satisfied: charset-normalizer<4,>=2 in ./venv/lib/python3.7/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (3.3.2)
[2024-02-23 20:50:59] Requirement already satisfied: idna<4,>=2.5 in ./venv/lib/python3.7/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (3.6)
[2024-02-23 20:50:59] Requirement already satisfied: urllib3<3,>=1.21.1 in ./venv/lib/python3.7/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (2.0.7)
[2024-02-23 20:50:59] Requirement already satisfied: certifi>=2017.4.17 in ./venv/lib/python3.7/site-packages (from requests<3,>=2.27->gTTS==2.5.1) (2024.2.2)
[2024-02-23 20:50:59] Requirement already satisfied: async-timeout>=3.0.0 in ./venv/lib/python3.7/site-packages (from zeroconf>=0.25.1->PyChromecast==13.1.0) (4.0.3)
[2024-02-23 20:50:59] Requirement already satisfied: ifaddr>=0.1.7 in ./venv/lib/python3.7/site-packages (from zeroconf>=0.25.1->PyChromecast==13.1.0) (0.2.0)
[2024-02-23 20:50:59] Requirement already satisfied: typing-extensions>=3.6.5 in ./venv/lib/python3.7/site-packages (from async-timeout>=3.0.0->zeroconf>=0.25.1->PyChromecast==13.1.0) (4.7.1)
[2024-02-23 20:51:00] Requirement already satisfied: pyasn1<0.6.0,>=0.4.6 in ./venv/lib/python3.7/site-packages (from pyasn1-modules>=0.2.1->google-auth<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.1) (0.5.1)
[2024-02-23 20:51:01] Requirement already satisfied: zipp>=0.5 in ./venv/lib/python3.7/site-packages (from importlib-metadata->click<8.2,>=7.1->gTTS==2.5.1) (3.15.0)
[2024-02-23 20:51:03] ****************
[2024-02-23 20:51:03] * Install DONE *
debug démon:
[DAEMON][IMPORT] Error: importing module Google Cloud TTS :: /lib/arm-linux-gnueabihf/libm.so.6: version GLIBC_2.29’ not found (required by /var/www/html/plugins/ttscast/resources/venv/lib/python3.7/site-packages/grpc/_cython/cygrpc.cpython-37m-arm-linux-gnueabihf.so)`
