Depuis la dernière MAJ du plugin JMQTT, les communication MQTT de mes équipements qui gèrent le chauffage ne fonctionnent plus. Etant nouvel utilisateur du forum je ne peux pas joindre les fichiers log.
J’ai tenté le redémarrage de Jeedom, relancer les dépendances, une réparation Mosquitto et redémarrage Mosquitto.
Merci beaucoup de votre aide !
jMQTTd
[2026-02-11 22:31:03,857][ERROR] Client78 Brk78Th on_disconnect() : Unexpected disconnection from broker!
[2026-02-11 22:31:03,981][ERROR] JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'brokerDown', 'id': '78'}]
[2026-02-11 22:31:14,890][ERROR] JMsg.Snd MainThread send() : COULD NOT send TO Jeedom: [{'cmd': 'daemonDown'}]
[2026-02-12 18:33:33,031][INFO] Main MainThread set_log_level() : New log level set to: ERROR
jMQTT_shellies
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][Alimenté]# <- {"present":true}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:ht_ui]# <- {}
[2026-03-10 19:08:26][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Humidité]# est de type info Json : ignorée
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:humidity:0]# <- {"id": 0,"rh":69.9}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][Humidité]# <- 70
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:mqtt]# <- {"connected":true}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:sys]# <- {"mac":"80646FCBB92C","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":244936,"ram_free":159040,"fs_size":458752,"fs_free":188416,"cfg_rev":16,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600}
[2026-03-10 19:08:26][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Température]# est de type info Json : ignorée
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:temperature:0]# <- {"id": 0,"tC":20.7, "tF":69.3}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][Température]# <- 20.7
[2026-03-10 19:08:26][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][IP]# est de type info Json : ignorée
[2026-03-10 19:08:26][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][RSSI]# est de type info Json : ignorée
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:wifi]# <- {"sta_ip":"192.168.1.11","status":"got ip","ssid":"Freebox-610C85","rssi":-60}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][IP]# <- 192.168.1.11
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][RSSI]# <- -60
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:ws]# <- {"connected":false}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyFullStatus","params":{"ts":3.60,"ble":{},"cloud":{"connected":false},"devicepower:0":{"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}},"ht_ui":{},"humidity:0":{"id": 0,"rh":69.9},"mqtt":{"connected":true},"sys":{"mac":"80646FCBB92C","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":245004,"ram_free":158468,"fs_size":458752,"fs_free":188416,"cfg_rev":16,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600},"temperature:0":{"id": 0,"tC":20.7, "tF":69.3},"wifi":{"sta_ip":"192.168.1.11","status":"got ip","ssid":"Freebox-610C85","rssi":-60},"ws":{"connected":false}}}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyStatus","params":{"ts":3.59,"mqtt":{"connected":true}}}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyStatus","params":{"ts":1773166106.56,"cloud":{"connected":true}}}
[2026-03-10 19:08:26][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:cloud]# <- {"connected":true}
[2026-03-10 19:08:27][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyEvent","params":{"ts":1773166107.28,"events":[{"component":"sys", "event":"sleep", "ts":1773166107.28}]}}
[2026-03-10 19:08:27][INFO] Cmd #[RdC extension][shellyplusht-RdC][En ligne]# <- 0
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][En ligne]# <- 1
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:ble]# <- {}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:cloud]# <- {"connected":false}
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Voltage]# est de type info Json : ignorée
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Batterie ]# est de type info Json : ignorée
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Alimenté]# est de type info Json : ignorée
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:devicepower:0]# <- {"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][Voltage]# <- 0.43
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][Batterie ]# <- 0
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][Alimenté]# <- {"present":true}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:ht_ui]# <- {}
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Humidité]# est de type info Json : ignorée
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:humidity:0]# <- {"id": 0,"rh":62.5}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][Humidité]# <- 63
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:mqtt]# <- {"connected":true}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:sys]# <- {"mac":"D4D4DA7E75D4","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":244956,"ram_free":159400,"fs_size":458752,"fs_free":188416,"cfg_rev":29,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600}
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Température]# est de type info Json : ignorée
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:temperature:0]# <- {"id": 0,"tC":20.6, "tF":69.1}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][Température]# <- 20.6
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][IP]# est de type info Json : ignorée
[2026-03-10 19:08:32][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][RSSI]# est de type info Json : ignorée
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:wifi]# <- {"sta_ip":"192.168.1.113","status":"got ip","ssid":"Freebox-610C85","rssi":-50}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][IP]# <- 192.168.1.113
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][RSSI]# <- -50
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:ws]# <- {"connected":false}
[2026-03-10 19:08:32][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyFullStatus","params":{"ts":3.56,"ble":{},"cloud":{"connected":false},"devicepower:0":{"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}},"ht_ui":{},"humidity:0":{"id": 0,"rh":62.5},"mqtt":{"connected":true},"sys":{"mac":"D4D4DA7E75D4","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":245036,"ram_free":160560,"fs_size":458752,"fs_free":188416,"cfg_rev":29,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600},"temperature:0":{"id": 0,"tC":20.6, "tF":69.1},"wifi":{"sta_ip":"192.168.1.113","status":"got ip","ssid":"Freebox-610C85","rssi":-50},"ws":{"connected":false}}}
[2026-03-10 19:08:33][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyStatus","params":{"ts":3.56,"mqtt":{"connected":true}}}
[2026-03-10 19:08:33][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyStatus","params":{"ts":4.68,"cloud":{"connected":true}}}
[2026-03-10 19:08:33][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:cloud]# <- {"connected":true}
[2026-03-10 19:08:33][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyEvent","params":{"ts":1773166113.43,"events":[{"component":"sys", "event":"sleep", "ts":1773166113.43}]}}
[2026-03-10 19:08:34][INFO] Cmd #[Etage extention][shellyplusht-Etg][En ligne]# <- 0
[2026-03-10 19:10:07][INFO] Cmd #[Extérieur][Température piscine][events:rpc]# <- {"src":"shellyplus1-08b61fd89a10","dst":"shellyplus1-08b61fd89a10/events","method":"NotifyStatus","params":{"ts":2316805.40,"temperature:100":{"id":100,"tC":12.25,"tF":54.05}}}
[2026-03-10 19:10:07][DEBUG] Cmd #[Extérieur][Température piscine][Température °C]# est de type info Json : ignorée
[2026-03-10 19:10:07][INFO] Cmd #[Extérieur][Température piscine][status:temperature:100]# <- {"id": 100,"tC":12.2, "tF":54.0}
[2026-03-10 19:10:07][INFO] Cmd #[Extérieur][Température piscine][Température °C]# <- 12.2
[2026-03-10 19:10:17][INFO] Cmd #[Extérieur][Température piscine][events:rpc]# <- {"src":"shellyplus1-08b61fd89a10","dst":"shellyplus1-08b61fd89a10/events","method":"NotifyStatus","params":{"ts":2316815.40,"temperature:100":{"id":100,"tC":12.38,"tF":54.28}}}
[2026-03-10 19:10:17][DEBUG] Cmd #[Extérieur][Température piscine][Température °C]# est de type info Json : ignorée
[2026-03-10 19:10:17][INFO] Cmd #[Extérieur][Température piscine][status:temperature:100]# <- {"id": 100,"tC":12.4, "tF":54.3}
[2026-03-10 19:10:17][INFO] Cmd #[Extérieur][Température piscine][Température °C]# <- 12.4
[2026-03-10 19:11:57][INFO] Cmd #[Extérieur][Température piscine][events:rpc]# <- {"src":"shellyplus1-08b61fd89a10","dst":"shellyplus1-08b61fd89a10/events","method":"NotifyStatus","params":{"ts":2316915.40,"temperature:100":{"id":100,"tC":12.25,"tF":54.05}}}
[2026-03-10 19:11:57][DEBUG] Cmd #[Extérieur][Température piscine][Température °C]# est de type info Json : ignorée
[2026-03-10 19:11:57][INFO] Cmd #[Extérieur][Température piscine][status:temperature:100]# <- {"id": 100,"tC":12.2, "tF":54.0}
[2026-03-10 19:11:57][INFO] Cmd #[Extérieur][Température piscine][Température °C]# <- 12.2
[2026-03-10 19:12:02][INFO] Cmd #[Extérieur][Température piscine][events:rpc]# <- {"src":"shellyplus1-08b61fd89a10","dst":"shellyplus1-08b61fd89a10/events","method":"NotifyStatus","params":{"ts":2316920.40,"temperature:100":{"id":100,"tC":12.38,"tF":54.28}}}
[2026-03-10 19:12:02][DEBUG] Cmd #[Extérieur][Température piscine][Température °C]# est de type info Json : ignorée
[2026-03-10 19:12:02][INFO] Cmd #[Extérieur][Température piscine][status:temperature:100]# <- {"id": 100,"tC":12.4, "tF":54.3}
[2026-03-10 19:12:02][INFO] Cmd #[Extérieur][Température piscine][Température °C]# <- 12.4
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][En ligne]# <- 1
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:ble]# <- {}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:cloud]# <- {"connected":false}
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Voltage]# est de type info Json : ignorée
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Batterie ]# est de type info Json : ignorée
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Alimenté]# est de type info Json : ignorée
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:devicepower:0]# <- {"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][Voltage]# <- 0.43
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][Batterie ]# <- 0
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][Alimenté]# <- {"present":true}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:ht_ui]# <- {}
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Humidité]# est de type info Json : ignorée
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:humidity:0]# <- {"id": 0,"rh":69.9}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][Humidité]# <- 70
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:mqtt]# <- {"connected":true}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:sys]# <- {"mac":"80646FCBB92C","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":244924,"ram_free":157260,"fs_size":458752,"fs_free":188416,"cfg_rev":16,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600}
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][Température]# est de type info Json : ignorée
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:temperature:0]# <- {"id": 0,"tC":20.7, "tF":69.3}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][Température]# <- 20.7
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][IP]# est de type info Json : ignorée
[2026-03-10 19:13:31][DEBUG] Cmd #[RdC extension][shellyplusht-RdC][RSSI]# est de type info Json : ignorée
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:wifi]# <- {"sta_ip":"192.168.1.11","status":"got ip","ssid":"Freebox-610C85","rssi":-58}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][IP]# <- 192.168.1.11
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][RSSI]# <- -58
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:ws]# <- {"connected":false}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyFullStatus","params":{"ts":3.59,"ble":{},"cloud":{"connected":false},"devicepower:0":{"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}},"ht_ui":{},"humidity:0":{"id": 0,"rh":69.9},"mqtt":{"connected":true},"sys":{"mac":"80646FCBB92C","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":245004,"ram_free":158444,"fs_size":458752,"fs_free":188416,"cfg_rev":16,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600},"temperature:0":{"id": 0,"tC":20.7, "tF":69.3},"wifi":{"sta_ip":"192.168.1.11","status":"got ip","ssid":"Freebox-610C85","rssi":-58},"ws":{"connected":false}}}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyStatus","params":{"ts":3.59,"mqtt":{"connected":true}}}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyStatus","params":{"ts":1773166411.08,"cloud":{"connected":true}}}
[2026-03-10 19:13:31][INFO] Cmd #[RdC extension][shellyplusht-RdC][status:cloud]# <- {"connected":true}
[2026-03-10 19:13:32][INFO] Cmd #[RdC extension][shellyplusht-RdC][rpc]# <- {"src":"shellyplusht-80646fcbb92c","dst":"shellyplusht-RdC/events","method":"NotifyEvent","params":{"ts":1773166412.10,"events":[{"component":"sys", "event":"sleep", "ts":1773166412.10}]}}
[2026-03-10 19:13:32][INFO] Cmd #[RdC extension][shellyplusht-RdC][En ligne]# <- 0
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][En ligne]# <- 1
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:ble]# <- {}
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:cloud]# <- {"connected":false}
[2026-03-10 19:13:37][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Voltage]# est de type info Json : ignorée
[2026-03-10 19:13:37][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Batterie ]# est de type info Json : ignorée
[2026-03-10 19:13:37][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Alimenté]# est de type info Json : ignorée
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:devicepower:0]# <- {"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}}
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][Voltage]# <- 0.43
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][Batterie ]# <- 0
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][Alimenté]# <- {"present":true}
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:ht_ui]# <- {}
[2026-03-10 19:13:37][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Humidité]# est de type info Json : ignorée
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:humidity:0]# <- {"id": 0,"rh":62.5}
[2026-03-10 19:13:37][INFO] Cmd #[Etage extention][shellyplusht-Etg][Humidité]# <- 63
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:mqtt]# <- {"connected":true}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:sys]# <- {"mac":"D4D4DA7E75D4","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":244932,"ram_free":158880,"fs_size":458752,"fs_free":188416,"cfg_rev":29,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600}
[2026-03-10 19:13:38][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][Température]# est de type info Json : ignorée
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:temperature:0]# <- {"id": 0,"tC":20.6, "tF":69.1}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][Température]# <- 20.6
[2026-03-10 19:13:38][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][IP]# est de type info Json : ignorée
[2026-03-10 19:13:38][DEBUG] Cmd #[Etage extention][shellyplusht-Etg][RSSI]# est de type info Json : ignorée
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:wifi]# <- {"sta_ip":"192.168.1.113","status":"got ip","ssid":"Freebox-610C85","rssi":-51}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][IP]# <- 192.168.1.113
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][RSSI]# <- -51
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:ws]# <- {"connected":false}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyFullStatus","params":{"ts":3.71,"ble":{},"cloud":{"connected":false},"devicepower:0":{"id": 0,"battery":{"V":0.43, "percent":0},"external":{"present":true}},"ht_ui":{},"humidity:0":{"id": 0,"rh":62.5},"mqtt":{"connected":true},"sys":{"mac":"D4D4DA7E75D4","restart_required":false,"time":null,"unixtime":null,"uptime":3,"ram_size":245000,"ram_free":158340,"fs_size":458752,"fs_free":188416,"cfg_rev":29,"kvs_rev":0,"webhook_rev":0,"available_updates":{},"wakeup_reason":{"boot":"deepsleep_wake","cause":"status_update"},"wakeup_period":600},"temperature:0":{"id": 0,"tC":20.6, "tF":69.1},"wifi":{"sta_ip":"192.168.1.113","status":"got ip","ssid":"Freebox-610C85","rssi":-51},"ws":{"connected":false}}}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyStatus","params":{"ts":3.71,"mqtt":{"connected":true}}}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyStatus","params":{"ts":4.68,"cloud":{"connected":true}}}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][status:cloud]# <- {"connected":true}
[2026-03-10 19:13:38][INFO] Cmd #[Etage extention][shellyplusht-Etg][rpc]# <- {"src":"shellyplusht-d4d4da7e75d4","dst":"shellyplusht-Etg/events","method":"NotifyEvent","params":{"ts":1773166418.84,"events":[{"component":"sys", "event":"sleep", "ts":1773166418.84}]}}
[2026-03-10 19:13:39][INFO] Cmd #[Etage extention][shellyplusht-Etg][En ligne]# <- 0
[2026-03-10 19:15:10][INFO] Client MQTT déconnecté du Broker
Mes infos de config
OS version: debian 11 on microsoft
PHP version: 7.4.33
Python version: 3.9.2
Mosquitto: Installed by jMQTT
Core version: 4.5.2 (master)
Nb lines in http.error: 503
Plugins: airzone calendar camera FreeSms jMQTT mobile mode Monitoring openvpn shelly sshmanager tahoma thermostat virtual weather widget
jMQTT: 26.1.1 (2026-03-09 19:22:10) branch: stable
Nb Errors or Warnings in jMQTT logs: 762 (level is error)
Daemon Status: Stopped (2026-03-12 09:35:03)
Nb eqBrokers: 1 / eqLogics: 8 / cmds: 112
