J’ai une installation avec Jeedom V4.3.17 qui fonctionnait à merveille avant que je réalise la migration de OpenZwave à ZwaveJs.
ZwaveJs fonctionne sens problème, mais le démon MySensors ne veut plus démarrer.
Voilà l’erreur que j’ai:
Thu Jul 20 2023 12:07:08 GMT+0200 (Central European Summer Time) - Jeedom url : http://127.0.0.1:80/plugins/mySensors/core/api/jeeSensors.php?apikey=wESnmy1L1wNJPXyx0I0P4LtW89UgDB55&gateway=master, gwAddress : /dev/ttyACM0
Connection type serial
/var/www/html/plugins/mySensors/resources/node_modules/bindings/bindings.js:121
throw e;
Error: The module '/var/www/html/plugins/mySensors/resources/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 83. This version of Node.js requires
NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at Object.Module._extensions..node (node:internal/modules/cjs/loader:1282:18)
at Module.load (node:internal/modules/cjs/loader:1076:32)
at Function.Module._load (node:internal/modules/cjs/loader:911:12)
at Module.require (node:internal/modules/cjs/loader:1100:19)
at require (node:internal/modules/cjs/helpers:108:18)
at bindings (/var/www/html/plugins/mySensors/resources/node_modules/bindings/bindings.js:112:48)
at Object. (/var/www/html/plugins/mySensors/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1198:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
at Module.load (node:internal/modules/cjs/loader:1076:32) {
code: 'ERR_DLOPEN_FAILED'
Merci d’avance
