Pour l’erreur suivante :
0497|(node:13195) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
0498|(Use `nodejs --trace-warnings ...` to show where the warning was created)
0499|imapConnected
Il faut éditer (via l’éditeur de Jeedom) le fichier suivant :
html/plugins/maillistener/resources/maillistener.js
Et modifier la ligne 14 :
process.env.NODE_TLS_REJECT_UNAUTHORIZED = "0";
en :
process.env.NODE_TLS_REJECT_UNAUTHORIZED = "1";
