j’ai remarqué complètement par hasard que le plugin ne fonctionnait plus sur mon Jeedom.
Rien n’a bougé sur les paramètres de la boite mail écoutée.
Impossible de réinstaller les dépendances et le démon s’arrête au bout de 60 secondes environ.
Voici les logs d’installation :
*Début de l'installation*
*Installation spécifique plugin*
*npm WARN deprecated har-validator@5.1.5: this library is no longer supported*
*npm WARN deprecated mimelib@0.3.1: This project is unmaintained*
*npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.*
*npm WARN deprecated mailparser@0.4.9: Mailparser versions older than v2.3.0 are deprecated*
*npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142*
*added 96 packages, and audited 97 packages in 2s*
*12 packages are looking for funding*
* run `npm fund` for details*
*1 moderate severity vulnerability*
*Some issues need review, and may require choosing*
*a different dependency.*
*Run `npm audit` for details.*
*Fin de l'installation*
Les logs de fonctionnement :
*(node:1626336) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.*
*(Use `nodejs --trace-warnings ...` to show where the warning was created)*
*imapConnected*
*Error: This socket has been ended by the other party*
* at Socket.writeAfterFIN [as write] (node:net:521:14)*
* at JSStreamSocket.doWrite (node:internal/js_stream_socket:176:19)*
* at JSStream.onwrite (node:internal/js_stream_socket:33:57)*
* at TLSSocket.Socket._final (node:net:491:28)*
* at callFinal (node:internal/streams/writable:696:27)*
* at prefinish (node:internal/streams/writable:725:7)*
* at finishMaybe (node:internal/streams/writable:735:5)*
* at TLSSocket.Writable.end (node:internal/streams/writable:633:5)*
* at TLSSocket.Socket.end (node:net:679:31) {*
* code: 'EPIPE',*
* source: 'socket'*
Je n’ai malheureusement pas trouvé grand chose sur le forum ressemblant à mon soucis, il semblerait que des packages ne soient pas à la dernière version, mais là je suis un peu perdu.
Version de mon Jeedom : 4.3.17
Je reste à dispo pour d’autres renseignements.
Merci de votre aide !
