Démon KO depuis MAJ 2024-05-21 01:03:16 et ZWaveJS UI 9.12.0
J’ai réalisé ce jour la MAJ du plugin ZWaveJS en version 2024-05-21 01:03:16, puis j’ai relancé les dépendances pour prendre en compte la version ZWaveJS UI v9.12.0.
Depuis, j’ai une erreur dans l’installation des dépendances, et le démon ne démarre pas.
Ma config : Jeedom v4.4.6 sur Raspberry 3, Debian 11.
Santé :
Config du plugin :
Logs dépendances :
[5/5] Building fresh packages...
success Saved lockfile.
Done in 242.17s.
+ sudo yarn run build
yarn run v1.22.22
$ npm-run-all 'build:*'
$ tsc
api/app.ts(32,36): error TS2307: Cannot find module 'zwave-js' or its corresponding type declarations.
api/lib/Gateway.ts(4,53): error TS2307: Cannot find module 'zwave-js' or its corresponding type declarations.
api/lib/ZwaveClient.ts(105,8): error TS2307: Cannot find module 'zwave-js' or its corresponding type declarations.
api/lib/ZwaveClient.ts(106,54): error TS2307: Cannot find module 'zwave-js/Utils' or its corresponding type declarations.
api/lib/utils.ts(2,25): error TS2307: Cannot find module 'zwave-js' or its corresponding type declarations.
error Command failed with exit code 2.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
ERROR: "build:server" exited with 2.
error Command failed with exit code 1.
+ chown -R www-data:www-data CHANGELOG.md LICENSE README.md SECURITY.md api certs docker docs esbuild-register.js esbuild.js genereteDocs.ts index.html kubernetes kustomization.yaml node_modules nodemon.json package-lock.json package.json package.sh pkg public server server_config.js snippets src store test tsconfig.eslint.json tsconfig.json vite.config.js wallaby.js yarn.lock
+ '[' -e /dev/ttyAMA0 ']'
+ sudo sed -i 's/console=ttyAMA0,115200//; s/kgdboc=ttyAMA0,115200//' /boot/cmdline.txt
+ sudo sed -i 's|[^:]*:[^:]*:respawn:/sbin/getty[^:]*ttyAMA0[^:]*||' /etc/inittab
sed: can't read /etc/inittab: No such file or directory
+ '[' -e /dev/ttymxc0 ']'
+ sudo systemctl mask serial-getty@ttyAMA0.service
+ sudo systemctl stop serial-getty@ttyAMA0.service
++ grep Revision /proc/cpuinfo
++ tr -d ' '
++ cut -d: -f2
+ RPI_BOARD_REVISION=a22082
+ [[ a22082 == \a\0\2\0\8\2 ]]
+ [[ a22082 == \a\2\2\0\8\2 ]]
+ systemctl disable hciuart
++ grep dtoverlay=pi3-miniuart-bt /boot/config.txt
+ [[ ! -n '' ]]
+ echo 'Raspberry Pi 3 Detected. If you use a Razberry board you must Disable Bluetooth'
+ echo 'Please add '\''dtoverlay=pi3-miniuart-bt'\'' to the end of the file /boot/config.txt'
Please add 'dtoverlay=pi3-miniuart-bt' to the end of the file /boot/config.txt
+ echo 'And reboot your Raspberry Pi'
+ echo 'Everything is successfully installed!'
+ echo 11
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zwavejs
+ echo 12
+ rm /tmp/jeedom_install_in_progress_zwavejs
Log Plugin
yarn run v1.22.22
$ node --preserve-symlinks server/bin/www.js
node:internal/modules/cjs/loader:1143
throw err;
Error: Cannot find module '/var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/bin/www.js'
at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
at Module._load (node:internal/modules/cjs/loader:981:27)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
at node:internal/main/run_main_module:28:49 {
code: 'MODULE_NOT_FOUND',
requireStack: []
Node.js v18.20.2
J’ai relancé plusieurs fois les dépendances, j’ai également relancé les dépendances de MQTT Manager et redémarrer le démon, j’ai rétabli les droits des dossiers et fichiers depuis la page de configuration de Jeedom… Rien y fait, mon ZWave ne veut pas revenir à la vie :frowning:
Est-ce que quelqu’un a une idée du problème ?
Par avance, merci.
Quel est le deuxième plugin KO ?
Le port du contrôleur est il vraiment le bon ?
Quel est le modèle du contrôleur ?
le 2è plugin KO est mail listener (il n’est plus compatible, il faudrait que je le supprime).
La clé est une everspring ZWave+.
Et pour le port, j’étais initialement sur le /dev/ttyACM0, mais le résultat était le même.
Un lsusb m’a donné ceci :
Bus 001 Device 020: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Donc j’ai changé le port dans la config au cas, mais mêmes problèmes.
que donne un
ls -l /dev/serial/by-id
lrwxrwxrwx 1 root root 13 May 22 18:21 usb-0658_0200-if00 -> ../../ttyACM0
Le log des dépendances est incomplet.
En effet, comme il est assez conséquent, je n’avais mis que la partie dans laquelle il y avait l’erreur.
Voici le log complet :
+ touch /tmp/jeedom_install_in_progress_zwavejs
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
+ echo 'Pre installation de l'\''installation/mise à jour des dépendances zwavejs'
Pre installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/pre_install.sh
++ cd /var/www/html/core/class/../../plugins/zwavejs/resources
++ pwd
+ BASEDIR=/var/www/html/plugins/zwavejs/resources
+ cd /var/www/html/plugins/zwavejs/resources
+ source ../core/config/zwavejs.config.ini
+ echo 'Wanted Version: 9.12.0'
+ rm -R zwave-js-ui
+ git clone --branch v9.12.0 --depth 1 https://github.com/zwave-js/zwave-js-ui
Cloning into 'zwave-js-ui'...
Note: switching to '96eeb76b110f27d3ce16cfb4b3992cb8f8dc34d8'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
+ echo 'Pre install finished'
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
apt: no process found
apt-get: no process found
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Reading package lists...
Building dependency tree...
Reading state information...
1 package can be upgraded. Run 'apt list --upgradable' to see it.
apt-utils is already the newest version (2.2.4).
git is already the newest version (1:2.30.2-1+deb11u2).
lsb-release is already the newest version (11.1.0+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
[Check Version NodeJS actuelle : v18.20.2 : [  OK  ]
--2024-05-22 17:40:03--  https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 2001:41d0:302:1100::8:104f, 54.36.53.46
Connecting to getcomposer.org (getcomposer.org)|2001:41d0:302:1100::8:104f|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58444 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 87% 3.43M 0s
50K .......                                               100% 16.1M=0.01s
2024-05-22 17:40:04 (3.80 MB/s) - 'composer-setup.php' saved [58444/58444]
Begin installation of composer
All settings correct for using Composer
Downloading...
Composer (version 2.7.6) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
added 110 packages, and audited 111 packages in 12s
13 packages are looking for funding
run `npm fund` for details
3 moderate severity vulnerabilities
To address all issues, run:
npm audit fix
Run `npm audit` for details.
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
+ echo 4
+ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
+ echo 5
+ echo 6
+ echo 7
+ echo 8
+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
+ sudo /var/www/html/core/class/../../resources/install_composer.sh
--2024-05-22 17:41:58--  https://getcomposer.org/installer
0K .......... .......... .......... .......... .......... 87% 3.12M 0s
50K .......                                               100% 32.3M=0.02s
2024-05-22 17:41:58 (3.52 MB/s) - 'composer-setup.php' saved [58444/58444]
Downloading...
+ echo 9
+ sudo NODE_OPTIONS=--dns-result-order=ipv4first npm install --force -g yarn
npm WARN using --force Recommended protections disabled.
changed 1 package in 8s
+ echo 10
+ sudo chmod +x /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
+ echo 'Post installation de l'\''installation/mise à jour des dépendances zwavejs'
Post installation de l'installation/mise à jour des dépendances zwavejs
+++ dirname /var/www/html/core/class/../../plugins/zwavejs/resources/post_install.sh
++ pwd
+ cd zwave-js-ui
+ sudo yarn install
yarn install v1.22.22
info No lockfile found.
warning package-lock.json found. Your project contains lock files generated by tools other than Yarn. It is advised not to mix package managers in order to avoid resolution inconsistencies caused by unsynchronized lock files. To clear this warning, remove package-lock.json.
[1/5] Validating package.json...
[2/5] Resolving packages...
warning csurf@1.11.0: Please use another csrf package
warning native-url > querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
warning vue@2.7.16: Vue 2 has reached EOL and is no longer actively maintained. See https://v2.vuejs.org/eol/ for more details.
warning @types/extract-zip@2.0.1: This is a stub types definition. extract-zip provides its own type definitions, so you do not need this installed.
warning docsify-cli > docsify-server-renderer@4.13.1: docsify-server-renderer 4.x and below is no longer supported while we investigate the future of SSR and SSG for Docsify
warning vite-plugin-pwa > workbox-build > @rollup/plugin-replace > magic-string > sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
[3/5] Fetching packages...
[4/5] Linking dependencies...
warning " > vis-data@7.1.9" has unmet peer dependency "uuid@^3.4.0 || ^7.0.0 || ^8.0.0 || ^9.0.0".
warning " > vis-data@7.1.9" has unmet peer dependency "vis-util@^5.0.1".
warning " > vis-network@9.1.9" has unmet peer dependency "@egjs/hammerjs@^2.0.0".
warning " > vis-network@9.1.9" has unmet peer dependency "component-emitter@^1.3.0".
warning " > vis-network@9.1.9" has unmet peer dependency "keycharm@^0.2.0 || ^0.3.0 || ^0.4.0".
warning " > vis-network@9.1.9" has unmet peer dependency "uuid@^3.4.0 || ^7.0.0 || ^8.0.0 || ^9.0.0".
warning " > vis-network@9.1.9" has unmet peer dependency "vis-util@^5.0.1".
warning " > @babel/register@7.23.7" has unmet peer dependency "@babel/core@^7.0.0-0".
warning " > vite-plugin-pwa@0.16.7" has unmet peer dependency "workbox-build@^7.0.0".
warning " > vite-plugin-pwa@0.16.7" has unmet peer dependency "workbox-window@^7.0.0".
Done in 242.17s.
yarn run v1.22.22
$ tsc
++ tr -d ' '
++ cut -d: -f2
+ [[ ! -n '' ]]
+ echo 11
+ echo 12
problème de build.
Ce serait moi, j’essaierais de faire :
-Réglages > Système > Configuration > OS/DB > rétablissement des droits des dossiers et fichiers > Vérifier
-Réglages > Système > Editeur de fichiers
plugins/zwavejs/resources/zwave-js-ui/package-lock.json
clique droit Supprimer
-Relancer l’installation des dépendances
voir aussi : Zwave JS DEMON NOK suite MàJ - #25 par akenad
akenad :slight_smile:
Bonsoir.
Ce plugin fonctionne bien avec Jeedom v4.4.6 et Debian 11.
Malheureusement, cela ne fonctionne toujours pas…
Ah ? Alors je dois confondre… Toujours est-il que je n’en ai plus l’utilité pour le moment, c’est pour cela que je n’ai pas relancé le démon.
Une erreur légèrement différente au lancement du démon :
yarn run v1.22.22
throw err;
Error: Cannot find module 'zwave-js'
Require stack:
- /var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/lib/ZwaveClient.js
- /var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/config/store.js
- /var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/bin/www.js
at Module.require (node:internal/modules/cjs/loader:1231:19)
at require (node:internal/modules/helpers:177:18)
at Object.<anonymous> (/var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/lib/ZwaveClient.js:33:20)
at Module._compile (node:internal/modules/cjs/loader:1364:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
at Module.load (node:internal/modules/cjs/loader:1203:32)
at Module._load (node:internal/modules/cjs/loader:1019:12)
at Module.require (node:internal/modules/cjs/loader:1231:19) {
requireStack: [
'/var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/lib/ZwaveClient.js',
'/var/www/html/plugins/zwavejs/resources/zwave-js-ui/server/config/store.js',
Node.js v18.20.2
Mais bon, je pense que le soucis principal se situe au niveau des dépendances…
As-tu essayé de nettoyer le cache de yarn comme indiqué par @akenad ?
sudo yarn cache clean
:open_mouth: Je n’avais pas vu qu’il avait édité son post pour ajouter un lien…
Ceci étant, j’ai trouvé cet après-midi la même commande sur un autre thread.
Et après plusieurs relances des dépendances, un redémarrage de box… Tout semble revenu à la normale !
Mais j’ai quand meme l’impression que mon RPi 3B arrive aux limites de ses capacités :confused:
