Informations Jeedom
Core : 4.4.8.1 (V4-stable)
DNS Jeedom : non
Plugin : Eufy
Version : 2024-06-22 19:59:33 (stable)
Statut Démon : Stoppé - (2024-07-04 14:55:05)
J’ai crée un compte dédié pour jeedom depuis l’app
Pas de double authent
Mes caméras sont les S340 (celles avec panneaux solaires)
J’ai installé le plugin Docker management :
+ touch /tmp/jeedom_install_in_progress_docker2
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/docker2/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/docker2/resources/pre-install.sh
Docker arch found : arm64
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:6 https://download.docker.com/linux/debian bullseye InRelease
Reading package lists...
+ echo 3
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye InRelease
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
Hit:5 https://download.docker.com/linux/debian bullseye InRelease
Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y apt-transport-https
apt-transport-https is already the newest version (2.2.4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y ca-certificates
ca-certificates is already the newest version (20210119).
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y curl
curl is already the newest version (7.74.0-1.3+deb11u12).
+ echo 7
+ sudo apt install -o Dpkg::Options::=--force-confdef -y gnupg
gnupg is already the newest version (2.2.27-2+deb11u2).
+ echo 8
+ sudo apt install -o Dpkg::Options::=--force-confdef -y lsb-release
lsb-release is already the newest version (11.1.0).
+ echo 9
+ sudo apt install -o Dpkg::Options::=--force-confdef -y docker-ce
docker-ce is already the newest version (5:27.0.3-1~debian.11~bullseye).
+ echo 10
+ sudo apt install -o Dpkg::Options::=--force-confdef -y docker-ce-cli
docker-ce-cli is already the newest version (5:27.0.3-1~debian.11~bullseye).
+ echo 11
+ sudo apt install -o Dpkg::Options::=--force-confdef -y containerd.io
containerd.io is already the newest version (1.7.18-1).
+ echo 12
+ sudo chmod +x /var/www/html/core/class/../../plugins/docker2/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/docker2/resources/post-install.sh
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
1 22.8M 1 318k 0 0 226k 0 0:01:43 0:00:01 0:01:42 322k
5 22.8M 5 1326k 0 0 550k 0 0:00:42 0:00:02 0:00:40 666k
8 22.8M 8 2062k 0 0 605k 0 0:00:38 0:00:03 0:00:35 691k
11 22.8M 11 2766k 0 0 627k 0 0:00:37 0:00:04 0:00:33 694k
16 22.8M 16 3742k 0 0 691k 0 0:00:33 0:00:05 0:00:28 750k
20 22.8M 20 4798k 0 0 748k 0 0:00:31 0:00:06 0:00:25 895k
23 22.8M 23 5438k 0 0 734k 0 0:00:31 0:00:07 0:00:24 823k
28 22.8M 28 6622k 0 0 787k 0 0:00:29 0:00:08 0:00:21 911k
34 22.8M 34 7994k 0 0 849k 0 0:00:27 0:00:09 0:00:18 1045k
38 22.8M 38 8906k 0 0 855k 0 0:00:27 0:00:10 0:00:17 1032k
41 22.8M 41 9742k 0 0 853k 0 0:00:27 0:00:11 0:00:16 989k
46 22.8M 46 10.6M 0 0 849k 0 0:00:27 0:00:12 0:00:15 1007k
49 22.8M 49 11.2M 0 0 859k 0 0:00:27 0:00:13 0:00:14 979k
53 22.8M 53 12.0M 0 0 858k 0 0:00:27 0:00:14 0:00:13 874k
56 22.8M 56 12.9M 0 0 863k 0 0:00:27 0:00:15 0:00:12 879k
61 22.8M 61 14.0M 0 0 878k 0 0:00:26 0:00:16 0:00:10 934k
66 22.8M 66 15.2M 0 0 894k 0 0:00:26 0:00:17 0:00:09 1017k
71 22.8M 71 16.2M 0 0 904k 0 0:00:25 0:00:18 0:00:07 1027k
75 22.8M 75 17.1M 0 0 905k 0 0:00:25 0:00:19 0:00:06 1042k
79 22.8M 79 18.0M 0 0 907k 0 0:00:25 0:00:20 0:00:05 1042k
83 22.8M 83 19.1M 0 0 915k 0 0:00:25 0:00:21 0:00:04 1036k
85 22.8M 85 19.5M 0 0 893k 0 0:00:26 0:00:22 0:00:04 893k
90 22.8M 90 20.6M 0 0 901k 0 0:00:25 0:00:23 0:00:02 889k
93 22.8M 93 21.3M 0 0 864k 0 0:00:27 0:00:25 0:00:02 727k
93 22.8M 93 21.3M 0 0 836k 0 0:00:27 0:00:26 0:00:01 584k
100 22.8M 100 22.8M 0 0 889k 0 0:00:26 0:00:26 --:--:-- 773k
+ echo 13
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end docker2
+ echo 14
+ rm /tmp/jeedom_install_in_progress_docker2
J’ai ensuite installé le plugin Eufy en renseignant le compte que j’ai spécialement créé pour l’occasion
J’ai 2 Not OK en rouge
Et « installer eufy » et « demarrer eufy » sont donc non fonctionnels ![]()
Extrait de mes essais :
[2024-07-04 14:42:15] eufy.INFO: Début de l'opération install_container [] []
[2024-07-04 14:42:16] eufy.DEBUG: container id: [] []
[2024-07-04 14:45:06] eufy.ERROR: Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement [] []
[2024-07-04 14:45:07] eufy.DEBUG: >>> Checking container 127.0.0.1:3000 [] []
[2024-07-04 14:45:07] eufy.DEBUG: Container 127.0.0.1:3000 is not responding :( [] []
[2024-07-04 14:45:07] eufy.ERROR: Container Eufy non démarré [] []
[2024-07-04 14:46:14] eufy.DEBUG: >>> Checking container 127.0.0.1:3000 [] []
[2024-07-04 14:46:14] eufy.DEBUG: Container 127.0.0.1:3000 is not responding :( [] []
[2024-07-04 14:46:14] eufy.DEBUG: eufy-security-ws image version: [] []
[2024-07-04 14:46:15] eufy.DEBUG: eufy-security-ws service online: [] []
[2024-07-04 14:46:15] eufy.DEBUG: isListening: [] []
[2024-07-04 14:46:15] eufy.DEBUG: isOnline: [] []
[2024-07-04 14:46:29] eufy.DEBUG: >>> Checking container 127.0.0.1:3000 [] []
[2024-07-04 14:46:29] eufy.DEBUG: Container 127.0.0.1:3000 is not responding :( [] []
[2024-07-04 14:46:29] eufy.DEBUG: eufy-security-ws image version: [] []
[2024-07-04 14:46:29] eufy.DEBUG: eufy-security-ws service online: [] []
[2024-07-04 14:46:29] eufy.DEBUG: isListening: [] []
[2024-07-04 14:46:29] eufy.DEBUG: isOnline: [] []
[2024-07-04 14:50:05] eufy.ERROR: Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement [] []
[2024-07-04 14:50:06] eufy.DEBUG: >>> Checking container 127.0.0.1:3000 [] []
[2024-07-04 14:50:06] eufy.DEBUG: Container 127.0.0.1:3000 is not responding :( [] []
[2024-07-04 14:50:06] eufy.ERROR: Container Eufy non démarré [] []
[2024-07-04 14:55:05] eufy.ERROR: Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement [] []
[2024-07-04 14:55:06] eufy.DEBUG: >>> Checking container 127.0.0.1:3000 [] []
[2024-07-04 14:55:06] eufy.DEBUG: Container 127.0.0.1:3000 is not responding :( [] []
[2024-07-04 14:55:06] eufy.ERROR: Container Eufy non démarré [] []
[2024-07-04 14:56:45] eufy.DEBUG: Task 'installContainer' executed now [] []
[2024-07-04 14:56:45] eufy.DEBUG: isListening: [] []
[2024-07-04 14:56:45] eufy.DEBUG: isOnline: [] []
[2024-07-04 14:56:45] eufy.INFO: Début de l'opération install_container [] []
[2024-07-04 14:56:45] eufy.DEBUG: container id: [] []
[2024-07-04 15:00:08] eufy.ERROR: Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement [] []
[2024-07-04 15:00:09] eufy.DEBUG: >>> Checking container 127.0.0.1:3000 [] []
[2024-07-04 15:00:09] eufy.DEBUG: Container 127.0.0.1:3000 is not responding :( [] []
[2024-07-04 15:00:09] eufy.ERROR: Container Eufy non démarré [] []
Au cas où un docker info
Client: Docker Engine - Community
Version: 27.0.3
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.15.1
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v2.28.1
Path: /usr/libexec/docker/cli-plugins/docker-compose
Server:
ERROR: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.46/info": dial unix /var/run/docker.sock: connect: permission denied
errors pretty printing info
Et les commandes mentionnées dans l’aide :
python3 resources/test_eufy.py
File "/var/www/html/plugins/eufy/resources/test_eufy.py", line 20, in <module>
ws = create_connection("ws://" + url)
File "/usr/local/lib/python3.9/dist-packages/websocket/_core.py", line 646, in create_connection
websock.connect(url, **options)
File "/usr/local/lib/python3.9/dist-packages/websocket/_core.py", line 256, in connect
self.sock, addrs = connect(
File "/usr/local/lib/python3.9/dist-packages/websocket/_http.py", line 145, in connect
sock = _open_socket(addrinfo_list, options.sockopt, options.timeout)
File "/usr/local/lib/python3.9/dist-packages/websocket/_http.py", line 232, in _open_socket
raise err
File "/usr/local/lib/python3.9/dist-packages/websocket/_http.py", line 209, in _open_socket
sock.connect(address)
ConnectionRefusedError: [Errno 111] Connection refused
Merci pour votre aide ![]()
