Hello @Michel_F
Je viens de migrer sur Debian 11 et je rencontre un souci.
Malgré plusieurs tentatives de réinstallation des dépendances, le démon refuse de se lancer.
Merci de ton aide.
Quelques extraits des messages :
ImportError: libffi.so.6: cannot open shared object file: No such file or directory
[2023-12-10 22:55:14]DEBUG : deamon_info = {"state":"nok","launchable":"ok"}
[2023-12-10 22:55:14]INFO : deamon_stop: Début
[2023-12-10 22:55:14]DEBUG : deamon_stop $deamon_state nok
tracker3","type":"info","cmdSlave":"0","cmdFctModbus":"3","cmdFormat":"uint16","cmdAddress":"3727","cmdFrequency":"1","cmdInvertBytes":"0","cmdInvertWords":"0","repeat":"0"}]}]'
File "/var/www/html/plugins/mymodbus/ressources/mymodbusd/mymodbusd.py", line 41, in
from mymodbus import PyModbusClient
File "/var/www/html/plugins/mymodbus/ressources/mymodbusd/mymodbus.py", line 37, in
from jeedom.jeedom import jeedom_utils
File "/var/www/html/plugins/mymodbus/ressources/mymodbusd/jeedom/jeedom.py", line 34, in
import pyudev
File "/var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.11.6/lib/python3.11/site-packages/pyudev/__init__.py", line 45, in
from pyudev.core import Context, Enumerator
File "/var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.11.6/lib/python3.11/site-packages/pyudev/core.py", line 27, in
from pyudev._ctypeslib.libudev import ERROR_CHECKERS, SIGNATURES
File "/var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.11.6/lib/python3.11/site-packages/pyudev/_ctypeslib/__init__.py", line 26, in
from . import libc, libudev
File "/var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.11.6/lib/python3.11/site-packages/pyudev/_ctypeslib/libc.py", line 27, in
from ctypes import c_int
File "/var/www/html/plugins/mymodbus/ressources/_pyenv/versions/3.11.6/lib/python3.11/ctypes/__init__.py", line 8, in
from _ctypes import Union, Structure, Array
Et les logs complets en PJ :
mymodbus_packages.txt (5,1 Ko)
mymodbus.txt (89,9 Ko)
