J’ai un gros problème avec le plugin Nextcloud Talk depuis ma mise a jour de Nextcloud 27.1.1 et Talk 17.1sur mon serveur : Le démon est HS et je ne reçois plus les notifications. Si le créateur @NeCeN est dans le coin ;-), Merci par avance !!
Le log du plugin est le suivant :
[2023-10-01 02:15:02]INFO : Start demond
[2023-10-01 02:15:02]INFO : Log level : debug
[2023-10-01 02:15:02]INFO : Socket port : 52029
[2023-10-01 02:15:02]INFO : Socket host : localhost
[2023-10-01 02:15:02]INFO : PID file : /tmp/jeedom/nc_talk/deamon.pid
[2023-10-01 02:15:02]INFO : Apikey : XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
[2023-10-01 02:15:02]INFO : Device : auto
[2023-10-01 02:15:02]INFO : User : gestionmaison
[2023-10-01 02:15:02]INFO : Password : xxxxxxxxxxxxxxxxxxxx
[2023-10-01 02:15:02]INFO : URL : https://xxxxxxxxxxxxxxxxxxx
[2023-10-01 02:15:02]INFO : tps : 5
[2023-10-01 02:15:02]DEBUG : Writing PID 14333 to /tmp/jeedom/nc_talk/deamon.pid
[2023-10-01 02:15:02]DEBUG : Init request module v2.31.0
[2023-10-01 02:15:02]DEBUG : Starting new HTTPS connection (1): 127.0.0.1:443
[2023-10-01 02:15:02]DEBUG : https://127.0.0.1:443 "GET /plugins/nc_talk/core/php/jeenc_talk.php?apikey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX HTTP/1.1" 200 0
[2023-10-01 02:15:02]DEBUG : Socket interface started
[2023-10-01 02:15:02]DEBUG : LoopNetServer Thread started
[2023-10-01 02:15:02]DEBUG : Listening on: [localhost:52029]
[2023-10-01 02:15:03]DEBUG : Client connected to [127.0.0.1:51538]
[2023-10-01 02:15:03]DEBUG : Message read from socket: b'{"eq_clear":"1","apikey":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","eq_id":"532","talk_id":"XXXXXXXXX"}'
[2023-10-01 02:15:03]DEBUG : Client disconnected from [127.0.0.1:51538]
[2023-10-01 02:15:08]DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-10-01 02:15:08]DEBUG : talk XXXXXXXXX added to 532
[2023-10-01 02:15:08]DEBUG : https://xxxxxxxxxxxxxxxx
[2023-10-01 02:15:08]DEBUG : xxxxxxxxxxxxxxx
[2023-10-01 02:15:08]DEBUG : Starting new HTTPS connection (1): xxxxxxxxxxxxxxxxxx:443
[2023-10-01 02:15:09]DEBUG : https://xxxxxxxxxxxxxxxx:443 "GET /ocs/v2.php/apps/spreed/api/v1/chat/xxxxxxxxxxxx HTTP/1.1" 200 81
[2023-10-01 02:15:09]DEBUG : b'{"ocs":{"meta":{"status":"ok","statuscode":200,"message":"OK"},"data":[]}}'
[2023-10-01 02:15:09]ERROR : Fatal error : list index out of range
[2023-10-01 02:15:09]INFO : Traceback (most recent call last):
File "/var/www/html/plugins/nc_talk/resources/nc_talkd/nc_talkd.py", line 205, in
listen()
File "/var/www/html/plugins/nc_talk/resources/nc_talkd/nc_talkd.py", line 85, in listen
msg=response.json()["ocs"]["data"][0]['message']
IndexError: list index out of range
[2023-10-01 02:15:09]DEBUG : Shutdown
[2023-10-01 02:15:09]DEBUG : Removing PID file /tmp/jeedom/nc_talk/deamon.pid
[2023-10-01 02:15:09]DEBUG : LoopNetServer Thread stopped
[2023-10-01 02:15:09]DEBUG : Exit 0
[2023-10-01 02:18:53]ERROR : Fatal error : list index out of range
J’ai remplacé les infos confidentielles par XXXXXXXXXXXXXXX.
