Bonjour a tous,
Demon HS depuis ce matin j’ai essayé plusieurs commande ssh d’habitude j’arrive a le refaire partir mais pas cette fois, coupure de courant hier et depuis …
Si quelqu’un peut m’aider
merci
Tue Feb 20 2024 11:43:49 GMT+0100 (Central European Standard Time) - Jeedom url : http://127.0.0.1:80/plugins/rflink/core/api/rflink.php?apikey=RcXFglslG8vYTJKcrUtVCaNZbinESO3U, gwAddress : /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_5573032383135150C1E2-if00
/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:121
throw e;
Error: The module '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 93. This version of Node.js requires
NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at Module._extensions..node (node:internal/modules/cjs/loader:1452:18)
at Module.load (node:internal/modules/cjs/loader:1197:32)
at Module._load (node:internal/modules/cjs/loader:1013:12)
at Module.require (node:internal/modules/cjs/loader:1225:19)
at require (node:internal/modules/helpers:177:18)
at bindings (/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:112:48)
at Object.<anonymous> (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1356:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
at Module.load (node:internal/modules/cjs/loader:1197:32) {
code: 'ERR_DLOPEN_FAILED'
Node.js v18.19.0
