Demon enocean nok suite mise à jour
[2024-12-31 13:08:03] INFO  : Sending packet
[2024-12-31 13:08:03] DEBUG  : FF:93:DA:80->05:91:EC:30 (-255 dBm): 0x01 ['0xd2', '0x6', '0x0', '0xff', '0x93', '0xda', '0x80', '0x0'] ['0x3', '0x5', '0x91', '0xec', '0x30', '0xff', '0x0'] OrderedDict([('CMD', {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 6', 'raw_value': 6}), ('QU', {'description': 'Query', 'unit': '', 'value': 'Query energy', 'raw_value': 0}), ('IO', {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0})])
[2024-12-31 13:08:03] DEBUG  : Message is repeated 0 times
[2024-12-31 13:08:03] DEBUG  : {'id': '0585A6D6', 'rorg': 'd2', 'packet_type': '1', 'dBm': '-46', 'func': '01', 'type': '0c', 'repeat': '0', 'destination': 'FF93DA80', 'manufacturer': '000', 'cmd': 7}
[2024-12-31 13:08:03] DEBUG  : Parsing Packet
[2024-12-31 13:08:03] DEBUG  : Its a VLD message
[2024-12-31 13:08:03] DEBUG  : Decode data : {"id": "0585A6D6", "rorg": "d2", "packet_type": "1", "dBm": "-46", "func": "01", "type": "0c", "repeat": "0", "destination": "FF93DA80", "manufacturer": "000", "cmd": 7, "CMD": {"description": "Command indentifier", "unit": "", "value": "Command ID 7", "raw_value": 7}, "UN": {"description": "Unit", "unit": "", "value": "Energy [Wh]", "raw_value": 1}, "IO": {"description": "I/O channel", "unit": "", "value": "Output channel 0 (to load)", "raw_value": 0}, "MV": {"description": "Measurement value", "unit": "", "value": 4456.0, "raw_value": 4456}, "C1": 4.456}
[2024-12-31 13:08:03] DEBUG  : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-31 13:08:03] DEBUG  : Received command from jeedom : send
[2024-12-31 13:08:03] DEBUG  : Send command
[2024-12-31 13:08:03] DEBUG  : {'QU': 0, 'IO': 0} on command 6 210 1 11
[2024-12-31 13:08:03] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 0, 255, 147, 218, 128, 0, 3, 5, 15, 10, 4, 255, 0, 44]
[2024-12-31 13:08:03] DEBUG  : Last packet for this 05:0F:0A:04 was emited 0.09891867637634277 seconds ago
[2024-12-31 13:08:03] DEBUG  : Waiting 0.4010813236236572 seconds FF:93:DA:80->05:0F:0A:04 (-255 dBm): 0x01 ['0xd2', '0x6', '0x0', '0xff', '0x93', '0xda', '0x80', '0x0'] ['0x3', '0x5', '0xf', '0xa', '0x4', '0xff', '0x0'] OrderedDict([('CMD', {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 6', 'raw_value': 6}), ('QU', {'description': 'Query', 'unit': '', 'value': 'Query energy', 'raw_value': 0}), ('IO', {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0})])
[2024-12-31 13:08:03] DEBUG  : No Response continue
[2024-12-31 13:08:03] DEBUG  : Receive response packet : 2
[2024-12-31 13:08:03] DEBUG  : Response is : OK
[2024-12-31 13:08:03] DEBUG  : {'QU': 1, 'IO': 0} on command 6 210 1 11
[2024-12-31 13:08:03] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 32, 255, 147, 218, 128, 0, 3, 5, 18, 64, 164, 255, 0, 91]
[2024-12-31 13:08:03] DEBUG  : Ignore this is an echo
[2024-12-31 13:08:03] DEBUG  : FF:93:DA:80->05:0D:C1:5F (-255 dBm): 0x01 ['0xd2', '0x6', '0x0', '0xff', '0x93', '0xda', '0x80', '0x0'] ['0x3', '0x5', '0xd', '0xc1', '0x5f', '0xff', '0x0'] OrderedDict([('CMD', {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 6', 'raw_value': 6}), ('QU', {'description': 'Query', 'unit': '', 'value': 'Query energy', 'raw_value': 0}), ('IO', {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0})])
[2024-12-31 13:08:03] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 0, 255, 147, 218, 128, 0, 3, 5, 18, 64, 164, 255, 0, 165]
[2024-12-31 13:08:03] DEBUG  : Last packet for this 05:12:40:A4 was emited 0.024188518524169922 seconds ago
[2024-12-31 13:08:03] DEBUG  : Waiting 0.4758114814758301 seconds FF:93:DA:80->05:12:40:A4 (-255 dBm): 0x01 ['0xd2', '0x6', '0x0', '0xff', '0x93', '0xda', '0x80', '0x0'] ['0x3', '0x5', '0x12', '0x40', '0xa4', '0xff', '0x0'] OrderedDict([('CMD', {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 6', 'raw_value': 6}), ('QU', {'description': 'Query', 'unit': '', 'value': 'Query energy', 'raw_value': 0}), ('IO', {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0})])
[2024-12-31 13:08:03] DEBUG  : {'id': '050DAFAE', 'rorg': 'd2', 'packet_type': '1', 'dBm': '-60', 'func': '01', 'type': '0c', 'repeat': '0', 'destination': 'FFFFFFFF', 'manufacturer': '000', 'cmd': 7}
[2024-12-31 13:08:03] ERROR  : Exception on enocean : 'UN'
[2024-12-31 13:08:03] DEBUG  : Shutdown
[2024-12-31 13:08:03] DEBUG  : Removing PID file /tmp/jeedom/openenocean/deamon.pid
[2024-12-31 13:08:03] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 32, 255, 147, 218, 128, 0, 3, 5, 14, 244, 10, 255, 0, 91]
[2024-12-31 13:08:03] DEBUG  : Waiting Response
[2024-12-31 13:08:03] INFO  : LoopNetServer Thread stopped
[2024-12-31 13:08:03] DEBUG  : Exit 0
Voici les dernière lignes
J’ai un scenario qui demande de releve de la consommation régulièrement pour chaque radiateur connecté avec un module enocean. Il y a 14 radiateurs en tout dans le logements. Le scénario demande un relève toutes les minutes pour assurer le délestage. Le problème peut il venir de là?
Je viens de mettre le scenario a inactif. Pour le moment le demon tient.
Le demon a l’air de tenir.
J’ai réactivé le scénario est le demon est repassé NOK. Y a-t-il une relation?
Type surcharge ou je ne sais pas trop quoi?
[2024-12-31 13:42:01][SCENARIO] -- Début : . Tags : {"#trigger#":"schedule","#trigger_name#":"","#trigger_id#":"","#trigger_message#":"Scénario exécuté automatiquement sur programmation","#trigger_value#":null}
[2024-12-31 13:42:01][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Garage][Cumulus][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Garage][Cumulus][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Bureau][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Bureau][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 329
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 327
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Entrée][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Entrée][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 396
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 398
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [WC bas][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [WC bas][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 331
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 333
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Cuisine][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Cuisine][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 402
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 404
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salle à manger][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salle à manger][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 335
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 337
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salon][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salon][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 339
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 341
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Dressing][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Dressing][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 406
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 400
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Couloir][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Couloir][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 408
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 410
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salle deau][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salle deau][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 412
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 414
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salle de bain][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Salle de bain][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 417
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 419
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [WC haut][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [WC haut][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 421
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 423
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Chambre Agathe][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Chambre Agathe][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 347
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 349
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 351
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Chambre Arthur][Radiareur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Chambre Arthur][Radiareur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 353
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 355
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 357
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Chambre Anita et Yves][Radiateur][Refresh Puissance]
[2024-12-31 13:42:01][SCENARIO] Exécution de la commande [Chambre Anita et Yves][Radiateur][Refresh Consommation]
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 359
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 361
[2024-12-31 13:42:01][SCENARIO] Exécution d'un bloc élément : 363
[2024-12-31 13:42:01][SCENARIO] Fin correcte du scénario
Devrais je tester chaque bloc en les allumant les uns après les autres?
Après quels tests, c’est bien un des modules qui fait passer le plugin NOK.
Il s’agit d’un module Advisen fil pilote pour le chauffage.
L’autre jour, je l’ai retrouvé éteint. Je n epeux plus le commander manuellement par contre la commande avec la centrale domotique fonctionne.
Finalement, j’ai créé un scénario avec uniquement le relevé de consommation sur le module incriminé.
Je vide les logs.
Au lancement du scénario, le demon passe NOK et voici le log.
Merci de votre aide.
[2024-12-31 14:35:30] DEBUG  : [85, 0, 12, 7, 1, 150, 210, 7, 96, 0, 0, 0, 1, 5, 146, 14, 251, 176, 0, 255, 147, 218, 128, 58, 0, 10]
[2024-12-31 14:35:30] DEBUG  : 05:92:0E:FB->FF:93:DA:80 (-58 dBm): 0x01 ['0xd2', '0x7', '0x60', '0x0', '0x0', '0x0', '0x1', '0x5', '0x92', '0xe', '0xfb', '0xb0'] ['0x0', '0xff', '0x93', '0xda', '0x80', '0x3a', '0x0'] OrderedDict()
[2024-12-31 14:35:30] DEBUG  : Message is repeated 0 times
[2024-12-31 14:35:30] DEBUG  : {'id': '05920EFB', 'rorg': 'd2', 'packet_type': '1', 'dBm': '-58', 'func': '01', 'type': '0c', 'repeat': '0', 'destination': 'FF93DA80', 'manufacturer': '000', 'cmd': 7}
[2024-12-31 14:35:30] DEBUG  : Parsing Packet
[2024-12-31 14:35:30] DEBUG  : Its a VLD message
[2024-12-31 14:35:30] DEBUG  : Decode data : {"id": "05920EFB", "rorg": "d2", "packet_type": "1", "dBm": "-58", "func": "01", "type": "0c", "repeat": "0", "destination": "FF93DA80", "manufacturer": "000", "cmd": 7, "CMD": {"description": "Command indentifier", "unit": "", "value": "Command ID 7", "raw_value": 7}, "UN": {"description": "Unit", "unit": "", "value": "Power [W]", "raw_value": 3}, "IO": {"description": "I/O channel", "unit": "", "value": "Output channel 0 (to load)", "raw_value": 0}, "MV": {"description": "Measurement value", "unit": "", "value": 1.0, "raw_value": 1}, "P1": 1.0}
[2024-12-31 14:35:30] DEBUG  : Send to jeedom: {'devices': {'05920EFB': {'id': '05920EFB', 'rorg': 'd2', 'packet_type': '1', 'dBm': '-58', 'func': '01', 'type': '0c', 'repeat': '0', 'destination': 'FF93DA80', 'manufacturer': '000', 'cmd': 7, 'CMD': {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 7', 'raw_value': 7}, 'UN': {'description': 'Unit', 'unit': '', 'value': 'Power [W]', 'raw_value': 3}, 'IO': {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0}, 'MV': {'description': 'Measurement value', 'unit': '', 'value': 1.0, 'raw_value': 1}, 'P1': 1.0}}}
[2024-12-31 14:35:30] DEBUG  : Starting new HTTP connection (1): 127.0.0.1:80
[2024-12-31 14:35:30] DEBUG  : http://127.0.0.1:80 "POST /plugins/openenocean/core/php/jeeOpenEnOcean.php?apikey=t7ULilecisXS2VYFjZr658TYkQHkwAgRjkyh6284SUa4TwwQScFgCM48EakGxUbn HTTP/1.1" 200 0
[2024-12-31 14:35:37] INFO  : Client connected to [127.0.0.1:48180]
[2024-12-31 14:35:37] INFO  : Message read from socket: b'{"apikey":"t7ULilecisXS2VYFjZr658TYkQHkwAgRjkyh6284SUa4TwwQScFgCM48EakGxUbn","cmd":"send","dest":"050DAFAE","profile":{"func":"01","rorg":"d2","type":"0c"},"command":{"command":"6","QU":"1","IO":"0"}}'
[2024-12-31 14:35:37] INFO  : Client disconnected from [127.0.0.1:48180]
[2024-12-31 14:35:37] INFO  : Client connected to [127.0.0.1:48188]
[2024-12-31 14:35:37] INFO  : Message read from socket: b'{"apikey":"t7ULilecisXS2VYFjZr658TYkQHkwAgRjkyh6284SUa4TwwQScFgCM48EakGxUbn","cmd":"send","dest":"050DAFAE","profile":{"func":"01","rorg":"d2","type":"0c"},"command":{"command":"6","QU":"0","IO":"0"}}'
[2024-12-31 14:35:37] INFO  : Client disconnected from [127.0.0.1:48188]
[2024-12-31 14:35:37] DEBUG  : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-12-31 14:35:37] DEBUG  : Received command from jeedom : send
[2024-12-31 14:35:37] DEBUG  : Send command
[2024-12-31 14:35:37] DEBUG  : {'QU': 1, 'IO': 0} on command 6 210 1 12
[2024-12-31 14:35:37] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 32, 255, 147, 218, 128, 0, 3, 5, 13, 175, 174, 255, 0, 104]
[2024-12-31 14:35:37] DEBUG  : {'QU': 0, 'IO': 0} on command 6 210 1 12
[2024-12-31 14:35:37] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 0, 255, 147, 218, 128, 0, 3, 5, 13, 175, 174, 255, 0, 150]
[2024-12-31 14:35:37] DEBUG  : Last packet for this 05:0D:AF:AE was emited 0.021477460861206055 seconds ago
[2024-12-31 14:35:37] DEBUG  : Waiting 0.47852253913879395 seconds FF:93:DA:80->05:0D:AF:AE (-255 dBm): 0x01 ['0xd2', '0x6', '0x0', '0xff', '0x93', '0xda', '0x80', '0x0'] ['0x3', '0x5', '0xd', '0xaf', '0xae', '0xff', '0x0'] OrderedDict([('CMD', {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 6', 'raw_value': 6}), ('QU', {'description': 'Query', 'unit': '', 'value': 'Query energy', 'raw_value': 0}), ('IO', {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0})])
[2024-12-31 14:35:37] INFO  : Sending packet
[2024-12-31 14:35:37] DEBUG  : FF:93:DA:80->05:0D:AF:AE (-255 dBm): 0x01 ['0xd2', '0x6', '0x20', '0xff', '0x93', '0xda', '0x80', '0x0'] ['0x3', '0x5', '0xd', '0xaf', '0xae', '0xff', '0x0'] OrderedDict([('CMD', {'description': 'Command indentifier', 'unit': '', 'value': 'Command ID 6', 'raw_value': 6}), ('QU', {'description': 'Query', 'unit': '', 'value': 'Query power', 'raw_value': 1}), ('IO', {'description': 'I/O channel', 'unit': '', 'value': 'Output channel 0 (to load)', 'raw_value': 0})])
[2024-12-31 14:35:37] DEBUG  : [85, 0, 1, 0, 2, 101, 0, 0]
[2024-12-31 14:35:37] DEBUG  : 0x02 ['0x0'] [] OrderedDict()
[2024-12-31 14:35:37] DEBUG  : Receive response packet : 2
[2024-12-31 14:35:37] DEBUG  : Response is : OK
[2024-12-31 14:35:37] DEBUG  : [85, 0, 8, 7, 1, 61, 210, 6, 32, 255, 147, 218, 128, 129, 0, 5, 13, 175, 174, 61, 0, 101]
[2024-12-31 14:35:37] DEBUG  : FF:93:DA:80->05:0D:AF:AE (-61 dBm): 0x01 ['0xd2', '0x6', '0x20', '0xff', '0x93', '0xda', '0x80', '0x81'] ['0x0', '0x5', '0xd', '0xaf', '0xae', '0x3d', '0x0'] OrderedDict()
[2024-12-31 14:35:37] DEBUG  : Ignore this is an echo
[2024-12-31 14:35:37] DEBUG  : [85, 0, 12, 7, 1, 150, 210, 7, 224, 0, 0, 0, 0, 5, 13, 175, 174, 48, 0, 255, 255, 255, 255, 61, 0, 248]
[2024-12-31 14:35:37] DEBUG  : 05:0D:AF:AE->FF:FF:FF:FF (-61 dBm): 0x01 ['0xd2', '0x7', '0xe0', '0x0', '0x0', '0x0', '0x0', '0x5', '0xd', '0xaf', '0xae', '0x30'] ['0x0', '0xff', '0xff', '0xff', '0xff', '0x3d', '0x0'] OrderedDict()
[2024-12-31 14:35:37] DEBUG  : Message is repeated 0 times
[2024-12-31 14:35:37] DEBUG  : {'id': '050DAFAE', 'rorg': 'd2', 'packet_type': '1', 'dBm': '-61', 'func': '01', 'type': '0c', 'repeat': '0', 'destination': 'FFFFFFFF', 'manufacturer': '000', 'cmd': 7}
[2024-12-31 14:35:37] DEBUG  : Parsing Packet
[2024-12-31 14:35:37] DEBUG  : Its a VLD message
[2024-12-31 14:35:37] ERROR  : Exception on enocean : 'UN'
[2024-12-31 14:35:37] DEBUG  : Shutdown
[2024-12-31 14:35:37] DEBUG  : Removing PID file /tmp/jeedom/openenocean/deamon.pid
[2024-12-31 14:35:37] INFO  : LoopNetServer Thread stopped
[2024-12-31 14:35:37] DEBUG  : Exit 0
Je ne sais pas si c’est normal que ce « UN » (unité) ne soit pas présent pour ce cas (on voit que l’info est présente pour d’autres) mais j’ai fixé le démon pour que ca ne bloque plus.
A tester avec la beta demain.
