je viens de faire une migration raspbian stretch → image jeedom-debian-buster-rpi-4.0.61.zip, restauration de sauvegarde puis mise à jour en 4.1.18. Tout à fonctionné à merveille sauf pour le plugin OpenEnocean. (au passage elle semble géniale cette nouvelle version !!)
Suite à la restauration de la sauvegarde, le statut du plugin était à NOK. J’ai relancé les dépendances, puis redémarré, sans succès. Suivant les conseils d’ @akenad, j’ai lancé la commande sudo python -m pip install soupsieve==1.8, puis relancé les dépendances, toujours sans succès. Maintenant je sèche
un peu … voici mes logs :
OpenEnocean-update
* Installation des dépendances *
Hit:1 http://packages.microsoft.com/repos/code stable InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python-enum' is not installed, so not removed
The following packages were automatically installed and are no longer required:
python-backports.functools-lru-cache python-soupsieve raspi-gpio
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
python-serial is already the newest version (3.4-4).
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: enum-compat in /usr/local/lib/python2.7/dist-packages (0.0.3)
Requirement already satisfied: enum34; python_version < "3.4" in /usr/lib/python2.7/dist-packages (from enum-compat) (1.1.6)
Package 'python-bs4' is not installed, so not removed
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python2.7/dist-packages (4.9.3)
Requirement already satisfied: soupsieve<2.0,>1.2; python_version < "3.0" in /usr/local/lib/python2.7/dist-packages (from beautifulsoup4) (1.8)
Requirement already satisfied: backports.functools-lru-cache; python_version < "3" in /usr/local/lib/python2.7/dist-packages (from soupsieve<2.0,>1.2; python_version < "3.0"->beautifulsoup4) (1.6.1)
* Installation terminée *
OpenEnocean
[2021-01-29 19:55:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-01-29 19:55:12][ERROR] : No base id from enocean key, shutdown
[2021-01-29 20:00:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-01-29 20:00:16][ERROR] : No base id from enocean key, shutdown
[2021-01-29 20:05:04][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-01-29 20:05:12][ERROR] : No base id from enocean key, shutdown
[2021-01-29 20:10:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-01-29 20:10:13][ERROR] : No base id from enocean key, shutdown
[2021-01-29 20:15:05][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2021-01-29 20:15:15][ERROR] : No base id from enocean key, shutdown
pip2 list
jeedom@jeedom:~ $ pip2 list
Package Version
asn1crypto 0.24.0
astroid 1.6.6
backports-abc 0.5
backports.functools-lru-cache 1.6.1
beautifulsoup4 4.9.3
blessings 1.7
certifi 2018.8.24
chardet 3.0.4
configparser 3.5.0b2
coverage 5.4
cryptography 2.6.1
Cython 0.29.2
docutils 0.14
entrypoints 0.3
enum-compat 0.0.3
enum34 1.1.6
futures 3.3.0
gpg 1.12.0
html5lib 1.0.1
idna 2.6
ipaddress 1.0.17
isort 4.3.21
keyring 17.1.1
keyrings.alt 3.1.1
lazy-object-proxy 1.5.2
libopenzwave 0.3.1
Louie 1.1
lxml 4.3.2
mccabe 0.6.1
nose 1.3.7
nose-html 1.1
nose-progressive 1.5.2
olefile 0.46
openzwave 0.3.1
Pillow 5.4.1
pip 18.1
pycrypto 2.6.1
Pygments 2.3.1
PyGObject 3.30.4
pylint 1.9.5
pyOpenSSL 19.0.0
pyserial 3.4
pyudev 0.21.0
pyxdg 0.25
requests 2.21.0
roman 2.0.0
RPi.GPIO 0.7.0
SecretStorage 2.3.1
setuptools 40.8.0
singledispatch 3.4.0.3
six 1.12.0
soupsieve 1.8
tornado 5.1.1
urllib3 1.24.1
urwid 2.1.2
webencodings 0.5.1
wheel 0.32.3
wrapt 1.12.1
Je précise que tout fonctionnait parfaitement avant, et que rien d’autre n’a été modifié si ce n’est le passage stretch->buster (puis passage en jeedom 4.1 mais qui n’a rien changé à ce problème …)
Dernière précision : je dispose d’une passerelle EnoceanPi …
Merci d’avance pour votre aide !
