Jeedom m’a invité à faire la mise à jour de mon os de Strech à Buster pour pouvoir passer à la V4 (je suis sur RPI3).
J’ai suivi ce tutoriel sans problème:
https://www.arnaudmartin.net/2020/07/27/raspberry-pi-mise-a-jour-depuis-raspbian-stretch-vers-buster/
Sauf qu’au redémarrage quand j’ai voulu aller sur l’interface web de jeedom, j’ai eu ça:
<?php
/* This file is part of Jeedom.
* Jeedom is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Jeedom is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Jeedom. If not, see <http://www.gnu.org/licenses/>.
try {
if (!file_exists(__DIR__ . '/core/config/common.config.php')) {
header("location: install/setup.php");
if (!isset($_GET['v'])) {
$useragent = (isset($_SERVER["HTTP_USER_AGENT"])) ? $_SERVER["HTTP_USER_AGENT"] : 'none';
$getParams = (stristr($useragent, "Android") || strpos($useragent, "iPod") || strpos($useragent, "iPhone") || strpos($useragent, "Mobile") || strpos($useragent, "WebOS") || strpos($useragent, "mobile") || strpos($useragent, "hp-tablet"))
? 'm' : 'd';
foreach ($_GET AS $var => $value) {
$getParams .= '&' . $var . '=' . $value;
$url = 'index.php?v=' . trim($getParams, '&');
if (headers_sent()) {
echo '<script type="text/javascript">';
echo "window.location.href='$url';";
echo '</script>';
} else {
exit(header('Location: ' . $url));
die();
require_once __DIR__ . "/core/php/core.inc.php";
if (isset($_GET['v']) && $_GET['v'] == 'd') {
if (isset($_GET['modal'])) {
try {
include_file('core', 'authentification', 'php');
if (!isConnect()) {
throw new Exception('{{401 - Accès non autorisé}}');
include_file('desktop', init('modal'), 'modal', init('plugin'));
} catch (Exception $e) {
ob_end_clean();
echo '<div class="alert alert-danger div_alert">';
echo translate::exec(displayException($e), 'desktop/' . init('p') . '.php');
echo '</div>';
} catch (Error $e) {
ob_end_clean();
echo '</div>';
} elseif (isset($_GET['configure'])) {
include_file('plugin_info', 'configuration', 'configuration', init('plugin'));
} elseif (isset($_GET['ajax']) && $_GET['ajax'] == 1) {
try {
$title = config::byKey('product_name');
if (init('m') != '') {
try {
$plugin = plugin::byId(init('m'));
if (is_object($plugin)) {
$title = $plugin->getName() . ' - '.config::byKey('product_name');
} else if (init('p') != '') {
$title = ucfirst(init('p')) . ' - ' . config::byKey('product_name');
echo '<script>';
echo 'document.title = "' . $title . '"';
echo '</script>';
include_file('desktop', init('p'), 'php', init('m'));
ob_end_clean();
echo '</div>';
ob_end_clean();
echo '</div>';
} else {
include_file('desktop', 'index', 'php');
} elseif (isset($_GET['v']) && $_GET['v'] == 'm') {
$_fn = 'index';
$_type = 'html';
$_plugin = '';
$_fn = init('modal');
$_type = 'modalhtml';
$_plugin = init('plugin');
} elseif (isset($_GET['p']) && isset($_GET['ajax'])) {
$_fn = $_GET['p'];
$_plugin = isset($_GET['m']) ? $_GET['m'] : $_plugin;
include_file('mobile', $_fn, $_type, $_plugin);
} else {
echo "Erreur : veuillez contacter l'administrateur";
echo $e->getMessage();
La je suis très inquiet… J’ai fait une connerie ?
Merci pour votre aide, je ne sais vraiment pas quoi faire là !
