Page : https://www.jeedom.com/market/index.php?v=d&p=profils&tab=services#profil
Message :
Je suis a ma deuxième demande pour ajouter ce produit a la liste des produit z-wave.
SVP pouvez-vous l’ajouter SVP
Site : https://myiblinds.com/
If Jeedom is similar to other Open Source controllers like openHAB and Domoticz then the problem is probably because iblinds is a new device and it has not been added to the Jeedome Z-Wave database.
You can forward this information to Jeedom support and they should be able to help you.
Supported Command Classes - cc:5E,85,59,86,72,5A,73,26,25,80,70
Command Class Association Group Info V2
Command Class Association V2
Command Class Basic V2
Command Class Battery
Command Class Device Reset Locally
Command Class Manufacturer Specific V2
Command Class Powerlevel
Command Class Switch Binary
Command Class Switch Multilevel V4
Command Class Version V2
Command Class Z-Wave+ Info V2
Product Details
Z-Wave Specific Device Type: Window Covering - Endpoint and Position Aware, CLASS_B_MOTOR_CONTROL
Z-Wave Generic Device Type: Multilevel Switch
Z-Wave Role Type: Listening Sleeping Slave
Manufacturer ID: 0287
Product Type ID: 0x0003
Product ID: 0x000D
NOTE: DO NOT SEND GET COMMAND (POLL) AFTER BINARY SET OR MULTILEVEL SWITCH SET COMMAND. This can cause unexpected behavior !!.
