Un autre modèle de Tuya Smart Air Box avec Formaldéide, Humidité, Voc, Co² et Température
"ieee": "a4:c1:38:12:97:0c:52:d4",
"nwk": 4968,
"status": 2,
"lqi": "228",
"rssi": "-43",
"last_seen": "1632314634.9673743",
"node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZE200_ryfmq5rl",
"model": "TS0601",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 64
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_ryfmq5rl"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
4,
5,
61184,
0
25,
10
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Informations brutes
[2021-09-22 14:32:07][DEBUG] : {"devices":{"a4:c1:38:12:97:0c:52:d4":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"125","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"2","cluster_name":"Cluster"}}}}}}}
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.1 => 125 convert to 125
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.2 => 2 convert to 2
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2021-09-22 14:32:07][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.9 => 2 convert to 2
[2021-09-22 14:32:08][DEBUG] : {"devices":{"a4:c1:38:12:97:0c:52:d4":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"127","cluster_name":"Cluster"},"1.2":{"value":"19","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"2","cluster_name":"Cluster"},"1.9":{"value":"18","cluster_name":"Cluster"}}}}}}}
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.1 => 127 convert to 127
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.2 => 19 convert to 19
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.8 => 2 convert to 2
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.9 => 18 convert to 18
[2021-09-22 14:32:08][DEBUG] : {"devices":{"a4:c1:38:12:97:0c:52:d4":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"129","cluster_name":"Cluster"},"1.2":{"value":"21","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.1 => 129 convert to 129
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.2 => 21 convert to 21
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2021-09-22 14:32:08][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.9 => 0 convert to 0
[2021-09-22 14:32:09][DEBUG] : {"devices":{"a4:c1:38:12:97:0c:52:d4":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"130","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"1","cluster_name":"Cluster"}}}}}}}
[2021-09-22 14:32:09][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2021-09-22 14:32:09][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2021-09-22 14:32:09][DEBUG] : Search command for a4:c1:38:12:97:0c:52:d4 logicalId : 1::61184::cmd::1.1 => 130 convert to 130
Debug
Est il possible de l’intégrer dans le plugin ?
