Pouvez vous intégrer ce ruban LED ? déjà dans le plugin mais il semble qu’une nouvelle version soit sortie ce mois ci. L’intégration est partielle.
Rubal LED LIDL (livarno IAN 379908_2101)
https://www.lidl.fr/smart-home
Informations brutes :
"ieee": "cc:86:ec:ff:fe:af:be:c9",
"nwk": 40133,
"status": 0,
"lqi": "176",
"rssi": "-82",
"last_seen": "1646000771.543967",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [],
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"class": "zigpy.device"
Debug zigbee :
[2022-02-27 23:31:29]DEBUG : {"devices":{"00:04:74:00:00:0c:e3:6c":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2022-02-27 23:31:29]DEBUG : Search attribut for 00:04:74:00:00:0c:e3:6c logicalId : 1::2820::1291 => 0 convert to 0
[2022-02-27 23:31:48]DEBUG : {"devices":{"00:12:4b:00:22:69:3d:ad":{"1":{"1026":[{"value":"1987","cluster_name":"Temperature Measurement"}]}}}}
[2022-02-27 23:31:48]DEBUG : Search attribut for 00:12:4b:00:22:69:3d:ad logicalId : 1::1026::0 => 1987 convert to 1987
[2022-02-27 23:32:10]DEBUG : http://127.0.0.1:8089/device/attributes type : POST
[2022-02-27 23:32:10]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2022-02-27 23:32:10]INFO : [Aucun][ cc:86:ec:ff:fe:af:be:c9] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Endpoint not found : 1","code":0}
[2022-02-27 23:32:10]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","endpoint":1,"cluster":8,"cluster_type":"in","attributes":[0],"allowCache":0}
[2022-02-27 23:32:10]INFO : [Aucun][ cc:86:ec:ff:fe:af:be:c9] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","endpoint":1,"cluster":8,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Endpoint not found : 1","code":0}
[2022-02-27 23:32:10]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","endpoint":1,"cluster":768,"cluster_type":"in","attributes":[3,4,7],"allowCache":0}
[2022-02-27 23:32:10]INFO : [Aucun][ cc:86:ec:ff:fe:af:be:c9] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","endpoint":1,"cluster":768,"cluster_type":"in","attributes":[3,4,7],"allowCache":0} erreur : {"state":"error","result":"Endpoint not found : 1","code":0}
[2022-02-27 23:32:17]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 23:32:17]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-27 23:32:17]ERROR : Erreur exécution de la commande [Aucun][ cc:86:ec:ff:fe:af:be:c9][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:af:be:c9][zdevices.command] Endpoint not found : 1","code":0}
[2022-02-27 23:32:19]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 23:32:19]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2022-02-27 23:32:19]ERROR : Erreur exécution de la commande [Aucun][ cc:86:ec:ff:fe:af:be:c9][Off] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:af:be:c9][zdevices.command] Endpoint not found : 1","code":0}
[2022-02-27 23:32:23]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 23:32:23]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"on_off","command":"toggle","await":1}],"allowQueue":false}
[2022-02-27 23:32:23]ERROR : Erreur exécution de la commande [Aucun][ cc:86:ec:ff:fe:af:be:c9][Toggle] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"on_off","command":"toggle","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:af:be:c9][zdevices.command] Endpoint not found : 1","code":0}
[2022-02-27 23:32:26]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 23:32:26]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[127,0]}],"allowQueue":false}
[2022-02-27 23:32:26]ERROR : Erreur exécution de la commande [Aucun][ cc:86:ec:ff:fe:af:be:c9][Luminosité] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[127,0]}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:af:be:c9][zdevices.command] Endpoint not found : 1","code":0}
[2022-02-27 23:32:29]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 23:32:29]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[250,0]}],"allowQueue":false}
[2022-02-27 23:32:29]ERROR : Erreur exécution de la commande [Aucun][ cc:86:ec:ff:fe:af:be:c9][Température couleur] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[250,0]}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:af:be:c9][zdevices.command] Endpoint not found : 1","code":0}
[2022-02-27 23:32:32]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 23:32:32]DEBUG : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color","await":1,"args":[30296,32850,0]}],"allowQueue":false}
[2022-02-27 23:32:32]ERROR : Erreur exécution de la commande [Aucun][ cc:86:ec:ff:fe:af:be:c9][Couleur] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"cc:86:ec:ff:fe:af:be:c9","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color","await":1,"args":[30296,32850,0]}],"allowQueue":false} erreur : {"state":"error","result":"[cc:86:ec:ff:fe:af:be:c9][zdevices.command] Endpoint not found : 1","code":0}
[2022-02-27 23:32:39]DEBUG : {"devices":{"00:12:4b:00:23:ad:fa:a7":{"1":{"1029":[{"value":"8496","cluster_name":"Relative Humidity Measurement"}]}}}}
[2022-02-27 23:32:39]DEBUG : Search attribut for 00:12:4b:00:23:ad:fa:a7 logicalId : 1::1029::0 => 8496 convert to 8496
[2022-02-27 23:32:40]DEBUG : {"devices":{"00:12:4b:00:22:69:27:a7":{"1":{"1026":[{"value":"1924","cluster_name":"Temperature Measurement"}]}}}}
[2022-02-27 23:32:40]DEBUG : Search attribut for 00:12:4b:00:22:69:27:a7 logicalId : 1::1026::0 => 1924 convert to 1924
[2022-02-27 23:32:47]DEBUG : {"devices":{"00:15:bc:00:43:00:0c:ed":{"44":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Supervision_reports","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"0","cluster_name":"IAS Zone"},"1.3":{"value":"2400","cluster_name":"IAS Zone"}}}}}}}
