Demande integration plafonnier eglo (awox) 900001
bonjour ,
serait-il possible d’intégrer le plafonnier eglo (awox) modele 900001
voici les informations brut
    "ieee": "a4:c1:38:1a:84:ee:f1:7c",
    "nwk": 8431,
    "status": 2,
    "lqi": "132",
    "rssi": "-67",
    "last_seen": "1645979978.3640304",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 268,
            "profile_id": 260,
            "manufacturer": "AwoX",
            "model": "TLSR82xx",
            "output_clusters": [
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 0
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 0
                            "id": 4,
                            "name": "manufacturer",
                            "value": "AwoX"
                            "id": 5,
                            "name": "model",
                            "value": "TLSR82xx"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "0122052017"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 254
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 0
                            "id": 4,
                            "name": "current_y",
                            "value": 0
                            "id": 7,
                            "name": "color_temperature",
                            "value": 333
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 64599,
                    "name": "Manufacturer Specific",
                    "attributes": []
            "id": 3,
            "status": 1,
            "device_type": 268,
            "profile_id": 4751,
            "manufacturer": null,
            "model": null,
                    "id": 65360,
                    "attributes": []
                    "id": 65361,
                    "attributes": []
            "input_clusters": [
                    "id": 65360,
                    "attributes": []
                    "id": 65361,
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 268,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768,
                    4096,
                    64599
                    6
            "3": {
                "profile_id": 4751,
                "device_type": 268,
                "input_clusters": [
                    65360,
                    65361
                    65360,
                    65361
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
le debug
[2022-02-27 17:42:48]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:42:48]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2022-02-27 17:42:48]DEBUG : {"devices":{"a4:c1:38:1a:84:ee:f1:7c":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-02-27 17:42:48]DEBUG : Search attribut for a4:c1:38:1a:84:ee:f1:7c logicalId : 1::6::0 => Bool.false convert to 0
[2022-02-27 17:42:50]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:42:50]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-02-27 17:42:50]DEBUG : {"devices":{"a4:c1:38:1a:84:ee:f1:7c":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2022-02-27 17:42:50]DEBUG : Search attribut for a4:c1:38:1a:84:ee:f1:7c logicalId : 1::6::0 => Bool.true convert to 1
[2022-02-27 17:42:57]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:42:57]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[67,0]}],"allowQueue":false}
[2022-02-27 17:42:58]DEBUG : {"devices":{"a4:c1:38:1a:84:ee:f1:7c":{"1":{"768":{"7":{"value":"153","cluster_name":"Color Control"}}}}}}
[2022-02-27 17:42:58]DEBUG : Search attribut for a4:c1:38:1a:84:ee:f1:7c logicalId : 1::768::7 => 153 convert to 153
[2022-02-27 17:43:00]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:43:00]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[61,0]}],"allowQueue":false}
[2022-02-27 17:43:01]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:43:01]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"light_color","command":"move_to_color_temp","await":1,"args":[26,0]}],"allowQueue":false}
[2022-02-27 17:43:04]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:43:04]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[192,0]}],"allowQueue":false}
[2022-02-27 17:43:05]DEBUG : {"devices":{"a4:c1:38:1a:84:ee:f1:7c":{"1":{"8":[{"value":"192","cluster_name":"Level control"}]}}}}
[2022-02-27 17:43:05]DEBUG : Search attribut for a4:c1:38:1a:84:ee:f1:7c logicalId : 1::8::0 => 192 convert to 192
[2022-02-27 17:43:05]DEBUG : http://127.0.0.1:8089/device/command type : PUT
[2022-02-27 17:43:05]DEBUG : {"ieee":"a4:c1:38:1a:84:ee:f1:7c","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":[101,0]}],"allowQueue":false}
[2022-02-27 17:43:07]DEBUG : {"devices":{"a4:c1:38:1a:84:ee:f1:7c":{"1":{"8":[{"value":"101","cluster_name":"Level control"}]}}}}
[2022-02-27 17:43:07]DEBUG : Search attribut for a4:c1:38:1a:84:ee:f1:7c logicalId : 1::8::0 => 101 convert to 101
le magasin physique où je l’ai acheter ATMOSPHERE BY EGLO
merci d’avance
Bonjour, pour ceux qui cherchent à savoir comment réinitialise ce produit
