J’ai fais l’acquisition de ce capteur chez Domadoo (qui le présente comme compatible Jeedom + Zigbee).
Ce capteur est bien reconnu sur mon installation (box Atlas avec Zigbee intégré) mais ne remonte uniquement que la dernière communication et la qualité de transmission radio, rien d’autre.
J’ai essayé de l’intégrer plusieurs fois via le contrôleur ou d’autres modules zigbee à proximité sans aucun autre résultat.
Le capteur n’est pas pris en charge dans Zigbee2QTT sous le vendor Frient A/S (tel que cela apparaît dans la configuration du noeud) mais il est reconnu dans Zigbee2QTT sous le vendor Develco.
Voici les infos brutes du capteur :
"date_code": "20231025 18:44",
"definition": {
"description": "Automatically generated definition",
"exposes": [
"features": [
"access": 7,
"description": "On\/off state of the switch",
"label": "State",
"name": "state",
"property": "state",
"type": "binary",
"value_off": "OFF",
"value_on": "ON",
"value_toggle": "TOGGLE"
"type": "switch"
"access": 5,
"description": "Remaining battery in %",
"label": "Battery",
"name": "battery",
"property": "battery",
"type": "numeric",
"unit": "%"
"access": 5,
"description": "Measured temperature value",
"label": "Temperature",
"name": "temperature",
"property": "temperature",
"type": "numeric",
"unit": "\u00b0C"
"access": 5,
"description": "Measured relative humidity",
"label": "Humidity",
"name": "humidity",
"property": "humidity",
"type": "numeric",
"unit": "%"
"access": 1,
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "HMSZB-120",
"options": [
"access": 2,
"description": "Calibrates the temperature value (absolute offset), takes into effect on next report of device.",
"label": "Temperature calibration",
"name": "temperature_calibration",
"property": "temperature_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.",
"label": "Temperature precision",
"name": "temperature_precision",
"property": "temperature_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Calibrates the humidity value (absolute offset), takes into effect on next report of device.",
"label": "Humidity calibration",
"name": "humidity_calibration",
"property": "humidity_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for humidity, takes into effect on next report of device. This option can only decrease the precision, not increase it.",
"label": "Humidity precision",
"name": "humidity_precision",
"property": "humidity_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "State actions will also be published as 'action' when true (default false).",
"label": "State action",
"name": "state_action",
"property": "state_action",
"type": "binary",
"value_off": false,
"value_on": true
"supports_ota": false,
"vendor": "frient A\/S"
"disabled": false,
"endpoints": {
"1": {
"bindings": [],
"clusters": {
"input": [
"genIdentify",
"genScenes",
"genOnOff"
"output": []
"configured_reportings": [],
"scenes": []
"38": {
"bindings": [
"cluster": "genPollCtrl",
"target": {
"endpoint": 1,
"ieee_address": "0xb4e3f9fffe947952",
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"genPollCtrl",
"msTemperatureMeasurement",
"msRelativeHumidity"
"output": [
"genIdentify",
"genTime",
"genOta"
"scenes": []
"friendly_name": "0x0015bc0035002335",
"ieee_address": "0x0015bc0035002335",
"interview_completed": true,
"interviewing": false,
"manufacturer": "frient A\/S",
"model_id": "HMSZB-120",
"network_address": 1010,
"power_source": "Battery",
"supported": false,
"type": "EndDevice"
Merci de vos retours.
