Serait il possible d’ajouter le produit suivant:
Ref: ZM-RT201
Marque: Tuya
Type de produit: Zigbee Motion Sensor
Lien commercial:
Image:
Info brut:
"ieee": "00:12:4b:00:07:cd:1e:e8",
"nwk": 26138,
"status": 1,
"lqi": "255",
"rssi": "-28",
"last_seen": "1628437073.5895736",
"node_descriptor": "02:40:80:00:00:50:a0:00:00:2a:a0:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 1,
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 2,
"name": "zone_status",
"value": 0
"signature": {
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
3,
1,
1280
0,
3,
1,
1280
"class": "zigpy.device"
Log en debug:
[2021-08-08 17:33:48][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2021-08-08 17:33:48][DEBUG] : {"duration":180}
[2021-08-08 17:33:49][DEBUG] : ""
[2021-08-08 17:35:00][DEBUG] : {"device_joined":"00:12:4b:00:07:cd:1e:e8"}
[2021-08-08 17:39:46][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2021-08-08 17:39:46][DEBUG] : null
[2021-08-08 17:39:46][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2021-08-08 17:39:46][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=0 type : GET
[2021-08-08 17:39:46][DEBUG] : {"with_attributes":0}
[2021-08-08 17:39:46][DEBUG] : [{"ieee":"80:4b:50:ff:fe:30:3c:f9","nwk":"0x0000","lqi":255,"rssi":0,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[]},{"ieee":"00:12:4b:00:07:cd:1e:e8","nwk":"0x661a","lqi":255,"rssi":-28,"device_type":"EndDevice","manufacturer":null,"model":null,"offline":false,"neighbours":[]}]
[2021-08-08 17:39:46][DEBUG] : {"ieee":"80:4b:50:ff:fe:30:3c:f9","version":"0.36.1","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_ezsp.db","device":{"path":"\/dev\/ttyUSB0","baudrate":115200,"flow_control":"software"},"network":{"channel":15,"extended_pan_id":null,"tc_address":null,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","key_sequence_number":0,"key":null,"pan_id":null,"update_id":0,"channels":34635776},"ezsp":{"CONFIG_APS_UNICAST_MESSAGE_COUNT":12,"CONFIG_SOURCE_ROUTE_TABLE_SIZE":16,"CONFIG_ADDRESS_TABLE_SIZE":8},"topology_scan_skip_coordinator":false,"topology_scan_enabled":true,"ota":{"ikea_provider":false,"otau_directory":null,"ledvance_provider":false},"handle_unknown_devices":false,"source_routing":false,"ezsp_config":[],"ezsp_policies":[],"topology_scan_period":240},"ezsp":{"extendedPanId":"3b:72:65:42:4c:64:77:72","panId":"0xa052","radioTxPower":8,"radioChannel":15,"nwkManagerId":"0x0","nwkUpdateId":"0x0","version":"6.7.0.0 build 149"}}
[2021-08-08 17:39:48][DEBUG] : [{"ieee":"80:4b:50:ff:fe:30:3c:f9","nwk":0,"status":2,"lqi":"255","rssi":"0","last_seen":"1628437147.691864","node_descriptor":"00:40:8f:cd:ab:52:80:00:41:2c:80:00:00","endpoints":[{"id":1,"status":1,"device_type":48879,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[],"input_clusters":[]},{"id":242,"status":1,"device_type":41440,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"manufacturer":"Silicon Labs","model":"EZSP","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":48879,"input_clusters":[],"output_clusters":[]},"242":{"profile_id":260,"device_type":41440,"input_clusters":[],"output_clusters":[33]}}},"class":"bellows.zigbee.application"},{"ieee":"00:12:4b:00:07:cd:1e:e8","nwk":26138,"status":1,"lqi":"255","rssi":"-28","last_seen":"1628437073.5895736","node_descriptor":"02:40:80:00:00:50:a0:00:00:2a:a0:00:00","endpoints":[{"id":1,"status":1,"device_type":1026,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":3,"name":"Identify","attributes":[]},{"id":1,"name":"Power Configuration","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":3,"name":"Identify","attributes":[]},{"id":1,"name":"Power Configuration","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[{"id":2,"name":"zone_status","value":0}]}]}],"signature":{"node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":0,"maximum_buffer_size":80,"maximum_incoming_transfer_size":160,"server_mask":10752,"maximum_outgoing_transfer_size":160,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":1026,"input_clusters":[0,3,1,1280],"output_clusters":[0,3,1,1280]}}},"class":"zigpy.device"}]
[2021-08-08 17:39:50][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2021-08-08 17:39:50][DEBUG] : null
[2021-08-08 17:39:50][DEBUG] : [{"ieee":"80:4b:50:ff:fe:30:3c:f9","nwk":"0x0000","lqi":255,"rssi":0,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[]},{"ieee":"00:12:4b:00:07:cd:1e:e8","nwk":"0x661a","lqi":255,"rssi":-28,"device_type":"EndDevice","manufacturer":null,"model":null,"offline":false,"neighbours":[]}]
[2021-08-08 17:40:03][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-08 17:40:03][DEBUG] : {"with_attributes":2}
[2021-08-08 17:40:05][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2021-08-08 17:40:05][DEBUG] : null
[2021-08-08 17:40:37][DEBUG] : http://127.0.0.1:8089/device/info?ieee=00%3A12%3A4b%3A00%3A07%3Acd%3A1e%3Ae8 type : GET
[2021-08-08 17:40:37][DEBUG] : {"ieee":"00:12:4b:00:07:cd:1e:e8"}
Merci d’avance à toute l’équipe
