Demande d'ajout - Tuya TS0012 - Module Commutation 2 sorties
Petite demande d’ajout d’un nouveau composant qui c’est bien intégré dans jeedom mais pas reconnu pour les commandes.
https://fr.aliexpress.com/item/1005003527612636.html?gatewayAdapt=glo2fra&aff_fcid=b6a349c6f2d74cd7923c34e5382edfdd-1642412915360-01381-_AtF0Fm&tt=CPS_NORMAL&aff_fsk=_AtF0Fm&aff_platform=shareComponent-detail&sk=_AtF0Fm&aff_trace_key=b6a349c6f2d74cd7923c34e5382edfdd-1642412915360-01381-_AtF0Fm&terminal_id=dd3500997d214ebcae0b4e5b3df76e39
C’est exactement le même qu’un module déjà présent dans Jeedom : TS0011 (qui fonctionne très bien chez moi :slight_smile:), sauf que ce dernier permet de gérer plus d’une lumière en même temps (2 dans ce cas, il en existe également avec une version 3 et 4 sorties mais je n’en ai pas pour vous donner les infos brutes).
Voila les informations brute de ce dernier :
    "ieee": "a4:c1:38:cb:69:6b:35:62",
    "nwk": 46113,
    "status": 2,
    "lqi": "255",
    "rssi": "-55",
    "last_seen": "1666513513.668378",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_jl7qyupf",
            "model": "TS0012",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_jl7qyupf"
                            "id": 5,
                            "name": "model",
                            "value": "TS0012"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "name": "off_wait_time",
                            "value": 0
                            "id": 32770,
                            "name": "power_on_state",
                            "value": 1
                    "id": 57344,
                    "name": "Tuya Manufacturer Specific",
                    "attributes": []
                    "id": 57345,
                    "name": "Tuya External Switch Type Cluster",
                    "attributes": [
                            "id": 53296,
                            "name": "external_switch_type",
                            "value": 0
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57345,
                    "attributes": []
    "signature": {
        "model": "TS0012",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    57344,
                    57345
                    10,
                    25
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
    "class": "zhaquirks.tuya.ts001x"
N’hésitez pas à me dire s’il vous faut plus d’informations.
Merci à tous et bonne journée,
De ce que je peux lire dans les infos brutes, Actuellement vous devriez avoir une commande action on off 1::6::0
Essayez d’ajouter une commande action avec 2::6::0 voir si ça fonctionne
Je ne serais pas l’expliquer, en revanant sur l’interface après quelques temps, toutes les commandes ont popées.
Et tout fonctionne, juste le module est toujours en inconnu. C’est comme s’il avait juste fait le binding.
Bon ba je suis content, peut être pouvez vous l’ajouter à la liste pour que ca se crée directement mais c’est top :wink:
Merci pour ton retour :slight_smile:
Ah ben super.
A propos je me suis trompé ce matin en disant :
C’était bien une commande info :wink:
Ce sera au développeur à faire ça car je suis simple utilisateur :slight_smile:
