Est-ce possible d’ajouter ce capteur de température et d’humidité Tuya :
Modèle: Tuya - Capteur intelligent de température et d’humidité
Lien d’achat:
AliExpress
Photo:
Informations brutes:
"ieee": "a4:c1:38:8b:2d:5f:b4:b4",
"nwk": 8788,
"status": 2,
"lqi": "116",
"rssi": "-71",
"last_seen": "1682766747.435459",
"node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZE200_whkgqxse",
"model": "TS0601",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 72
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_whkgqxse"
"id": 5,
"name": "model",
"value": "TS0601"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
4,
5,
61184,
0
25,
10
"class": "zigpy.device"
Logs:
[2023-04-29 13:02:53][DEBUG] : {"devices":{"a4:c1:38:8b:2d:5f:b4:b4":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"66","cluster_name":"Cluster"},"1.1":{"value":"96","cluster_name":"Cluster"},"1.2":{"value":"1","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"189","cluster_name":"Cluster"},"1.10":{"value":"2","cluster_name":"Cluster"},"1.11":{"value":"2","cluster_name":"Cluster"},"1.12":{"value":"0","cluster_name":"Cluster"},"1.13":{"value":"4","cluster_name":"Cluster"},"1.14":{"value":"0","cluster_name":"Cluster"},"1.15":{"value":"0","cluster_name":"Cluster"},"1.16":{"value":"0","cluster_name":"Cluster"},"1.17":{"value":"66","cluster_name":"Cluster"},"1.18":{"value":"4","cluster_name":"Cluster"},"1.19":{"value":"2","cluster_name":"Cluster"},"1.20":{"value":"0","cluster_name":"Cluster"},"1.21":{"value":"4","cluster_name":"Cluster"},"1.22":{"value":"0","cluster_name":"Cluster"},"1.23":{"value":"0","cluster_name":"Cluster"},"1.24":{"value":"0","cluster_name":"Cluster"},"1.25":{"value":"100","cluster_name":"Cluster"},"1.26":{"value":"10","cluster_name":"Cluster"},"1.27":{"value":"2","cluster_name":"Cluster"},"1.28":{"value":"0","cluster_name":"Cluster"},"1.29":{"value":"4","cluster_name":"Cluster"},"1.30":{"value":"0","cluster_name":"Cluster"},"1.31":{"value":"0","cluster_name":"Cluster"},"1.32":{"value":"1","cluster_name":"Cluster"},"1.33":{"value":"104","cluster_name":"Cluster"},"1.34":{"value":"11","cluster_name":"Cluster"},"1.35":{"value":"2","cluster_name":"Cluster"},"1.36":{"value":"0","cluster_name":"Cluster"},"1.37":{"value":"4","cluster_name":"Cluster"},"1.38":{"value":"0","cluster_name":"Cluster"},"1.39":{"value":"0","cluster_name":"Cluster"},"1.40":{"value":"0","cluster_name":"Cluster"},"1.41":{"value":"200","cluster_name":"Cluster"}}}}}}}
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1 => 66 convert to 66
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.1 => 96 convert to 96
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.2 => 1 convert to 1
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.9 => 189 convert to 189
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.10 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.11 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.12 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.13 => 4 convert to 4
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.14 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.15 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.16 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.17 => 66 convert to 66
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.18 => 4 convert to 4
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.19 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.20 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.21 => 4 convert to 4
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.22 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.23 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.24 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.25 => 100 convert to 100
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.26 => 10 convert to 10
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.27 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.28 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.29 => 4 convert to 4
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.30 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.31 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.32 => 1 convert to 1
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.33 => 104 convert to 104
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.34 => 11 convert to 11
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.35 => 2 convert to 2
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.36 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.37 => 4 convert to 4
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.38 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.39 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.40 => 0 convert to 0
[2023-04-29 13:02:53][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.41 => 200 convert to 200
[2023-04-29 13:02:55][DEBUG] : {"devices":{"a4:c1:38:8b:2d:5f:b4:b4":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"66","cluster_name":"Cluster"},"1.1":{"value":"97","cluster_name":"Cluster"},"1.2":{"value":"12","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"70","cluster_name":"Cluster"},"1.10":{"value":"13","cluster_name":"Cluster"},"1.11":{"value":"2","cluster_name":"Cluster"},"1.12":{"value":"0","cluster_name":"Cluster"},"1.13":{"value":"4","cluster_name":"Cluster"},"1.14":{"value":"0","cluster_name":"Cluster"},"1.15":{"value":"0","cluster_name":"Cluster"},"1.16":{"value":"0","cluster_name":"Cluster"},"1.17":{"value":"20","cluster_name":"Cluster"},"1.18":{"value":"17","cluster_name":"Cluster"},"1.19":{"value":"2","cluster_name":"Cluster"},"1.20":{"value":"0","cluster_name":"Cluster"},"1.21":{"value":"4","cluster_name":"Cluster"},"1.22":{"value":"0","cluster_name":"Cluster"},"1.23":{"value":"0","cluster_name":"Cluster"},"1.24":{"value":"0","cluster_name":"Cluster"},"1.25":{"value":"30","cluster_name":"Cluster"},"1.26":{"value":"9","cluster_name":"Cluster"},"1.27":{"value":"4","cluster_name":"Cluster"},"1.28":{"value":"0","cluster_name":"Cluster"},"1.29":{"value":"1","cluster_name":"Cluster"},"1.30":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1 => 66 convert to 66
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.1 => 97 convert to 97
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.2 => 12 convert to 12
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.9 => 70 convert to 70
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.10 => 13 convert to 13
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.11 => 2 convert to 2
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.12 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.13 => 4 convert to 4
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.14 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.15 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.16 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.17 => 20 convert to 20
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.18 => 17 convert to 17
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.19 => 2 convert to 2
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.20 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.21 => 4 convert to 4
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.22 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.23 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.24 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.25 => 30 convert to 30
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.26 => 9 convert to 9
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.27 => 4 convert to 4
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.28 => 0 convert to 0
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.29 => 1 convert to 1
[2023-04-29 13:02:55][DEBUG] : Search command for a4:c1:38:8b:2d:5f:b4:b4 logicalId : 1::61184::cmd::1.30 => 0 convert to 0
C’est mon premier post, veuillez m’excuser si j’ai fait des erreurs.
Merci d’avance,
Alain
