serait-il possible d’ajouter le module ci-dessous dans les appareils Zigbee svp.
Merci d’avance ![]()
Vanne d’arrosage Tuya
Modèle : TZE200_a7sghmms.TS0601
lien du site sur la photo et le modèle
Information brut :
[2023-07-17 18:37:04]DEBUG : null
[2023-07-17 18:37:26]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"86","cluster_name":"Cluster"},"1.2":{"value":"102","cluster_name":"Cluster"},"1.3":{"value":"3","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"8","cluster_name":"Cluster"},"1.6":{"value":"45","cluster_name":"Cluster"},"1.7":{"value":"45","cluster_name":"Cluster"},"1.8":{"value":"58","cluster_name":"Cluster"},"1.9":{"value":"45","cluster_name":"Cluster"},"1.10":{"value":"45","cluster_name":"Cluster"},"1.11":{"value":"58","cluster_name":"Cluster"},"1.12":{"value":"45","cluster_name":"Cluster"},"1.13":{"value":"45","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 86 convert to 86
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 102 convert to 102
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 3 convert to 3
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 8 convert to 8
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 45 convert to 45
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 45 convert to 45
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 58 convert to 58
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 45 convert to 45
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.10 => 45 convert to 45
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.11 => 58 convert to 58
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.12 => 45 convert to 45
[2023-07-17 18:37:26]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.13 => 45 convert to 45
[2023-07-17 18:37:30]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"87","cluster_name":"Cluster"},"1.2":{"value":"111","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 87 convert to 87
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 111 convert to 111
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2023-07-17 18:37:30]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 0 convert to 0
[2023-07-17 18:37:31]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"88","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"1","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 88 convert to 88
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 2 convert to 2
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 1 convert to 1
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 1 convert to 1
[2023-07-17 18:37:31]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 1 convert to 1
[2023-07-17 18:37:37]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"89","cluster_name":"Cluster"},"1.2":{"value":"101","cluster_name":"Cluster"},"1.3":{"value":"3","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"8","cluster_name":"Cluster"},"1.6":{"value":"48","cluster_name":"Cluster"},"1.7":{"value":"48","cluster_name":"Cluster"},"1.8":{"value":"58","cluster_name":"Cluster"},"1.9":{"value":"51","cluster_name":"Cluster"},"1.10":{"value":"53","cluster_name":"Cluster"},"1.11":{"value":"58","cluster_name":"Cluster"},"1.12":{"value":"51","cluster_name":"Cluster"},"1.13":{"value":"57","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 89 convert to 89
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 101 convert to 101
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 3 convert to 3
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 8 convert to 8
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 48 convert to 48
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 48 convert to 48
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 58 convert to 58
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 51 convert to 51
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.10 => 53 convert to 53
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.11 => 58 convert to 58
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.12 => 51 convert to 51
[2023-07-17 18:37:37]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.13 => 57 convert to 57
[2023-07-17 18:37:42]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"90","cluster_name":"Cluster"},"1.2":{"value":"106","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:42]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 90 convert to 90
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 106 convert to 106
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2023-07-17 18:37:43]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 0 convert to 0
[2023-07-17 18:37:44]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"91","cluster_name":"Cluster"},"1.2":{"value":"103","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 91 convert to 91
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 103 convert to 103
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2023-07-17 18:37:44]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 0 convert to 0
[2023-07-17 18:37:45]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"92","cluster_name":"Cluster"},"1.2":{"value":"2","cluster_name":"Cluster"},"1.3":{"value":"1","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"1","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 92 convert to 92
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 2 convert to 2
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 1 convert to 1
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 1 convert to 1
[2023-07-17 18:37:45]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-07-17 18:37:55]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"93","cluster_name":"Cluster"},"1.2":{"value":"102","cluster_name":"Cluster"},"1.3":{"value":"3","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"8","cluster_name":"Cluster"},"1.6":{"value":"48","cluster_name":"Cluster"},"1.7":{"value":"48","cluster_name":"Cluster"},"1.8":{"value":"58","cluster_name":"Cluster"},"1.9":{"value":"51","cluster_name":"Cluster"},"1.10":{"value":"53","cluster_name":"Cluster"},"1.11":{"value":"58","cluster_name":"Cluster"},"1.12":{"value":"53","cluster_name":"Cluster"},"1.13":{"value":"50","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 93 convert to 93
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 102 convert to 102
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 3 convert to 3
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 8 convert to 8
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 48 convert to 48
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 48 convert to 48
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 58 convert to 58
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 51 convert to 51
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.10 => 53 convert to 53
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.11 => 58 convert to 58
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.12 => 53 convert to 53
[2023-07-17 18:37:55]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.13 => 50 convert to 50
[2023-07-17 18:37:57]DEBUG : {"devices":{"a4:c1:38:42:b9:53:2c:8c":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2023-07-17 18:37:57]DEBUG : Search attribut for a4:c1:38:42:b9:53:2c:8c logicalId : 1::6::0 => Bool.true convert to 1
[2023-07-17 18:38:05]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"94","cluster_name":"Cluster"},"1.2":{"value":"114","cluster_name":"Cluster"},"1.3":{"value":"3","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"10","cluster_name":"Cluster"},"1.6":{"value":"48","cluster_name":"Cluster"},"1.7":{"value":"48","cluster_name":"Cluster"},"1.8":{"value":"58","cluster_name":"Cluster"},"1.9":{"value":"48","cluster_name":"Cluster"},"1.10":{"value":"48","cluster_name":"Cluster"},"1.11":{"value":"58","cluster_name":"Cluster"},"1.12":{"value":"49","cluster_name":"Cluster"},"1.13":{"value":"51","cluster_name":"Cluster"},"1.14":{"value":"44","cluster_name":"Cluster"},"1.15":{"value":"48","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 94 convert to 94
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 114 convert to 114
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 3 convert to 3
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 10 convert to 10
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 48 convert to 48
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 48 convert to 48
[2023-07-17 18:38:05]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 58 convert to 58
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 48 convert to 48
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.10 => 48 convert to 48
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.11 => 58 convert to 58
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.12 => 49 convert to 49
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.13 => 51 convert to 51
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.14 => 44 convert to 44
[2023-07-17 18:38:06]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.15 => 48 convert to 48
[2023-07-17 18:38:07]DEBUG : {"devices":{"a4:c1:38:42:b9:53:2c:8c":{"1":{"2820":{"1291":{"value":"61","cluster_name":"Electrical Measurement"}}}}}}
[2023-07-17 18:38:07]DEBUG : Search attribut for a4:c1:38:42:b9:53:2c:8c logicalId : 1::2820::1291 => 61 convert to 61
[2023-07-17 18:38:14]DEBUG : {"devices":{"e0:79:8d:ff:fe:d0:c2:60":{"1":[{"1":{"value":"64","cluster_name":"Basic"},"65506":{"value":"22","cluster_name":"Basic"}}]}}}
[2023-07-17 18:38:14]DEBUG : Search attribut for e0:79:8d:ff:fe:d0:c2:60 logicalId : 1::0::1 => 64 convert to 64
[2023-07-17 18:38:14]DEBUG : Search attribut for e0:79:8d:ff:fe:d0:c2:60 logicalId : 1::0::65506 => 22 convert to 22
[2023-07-17 18:38:16]DEBUG : {"devices":{"a4:c1:38:5e:9f:86:18:51":{"1":{"61184":{"cmd":{"0":{"value":"2","cluster_name":"Cluster"},"1":{"value":"0","cluster_name":"Cluster"},"1.1":{"value":"95","cluster_name":"Cluster"},"1.2":{"value":"108","cluster_name":"Cluster"},"1.3":{"value":"2","cluster_name":"Cluster"},"1.4":{"value":"0","cluster_name":"Cluster"},"1.5":{"value":"4","cluster_name":"Cluster"},"1.6":{"value":"0","cluster_name":"Cluster"},"1.7":{"value":"0","cluster_name":"Cluster"},"1.8":{"value":"0","cluster_name":"Cluster"},"1.9":{"value":"90","cluster_name":"Cluster"}}}}}}}
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::0 => 2 convert to 2
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1 => 0 convert to 0
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.1 => 95 convert to 95
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.2 => 108 convert to 108
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.3 => 2 convert to 2
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.4 => 0 convert to 0
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.5 => 4 convert to 4
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.6 => 0 convert to 0
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.7 => 0 convert to 0
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.8 => 0 convert to 0
[2023-07-17 18:38:16]DEBUG : Search command for a4:c1:38:5e:9f:86:18:51 logicalId : 1::61184::cmd::1.9 => 90 convert to 90
[2023-07-17 18:40:08]DEBUG : http://127.0.0.1:8089/device/attributes type : POST
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:45:66:e7:d9:85","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : [Bureau][Télétravail] refresh
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:45:66:e7:d9:85","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:45:66:e7:d9:85","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : {"devices":{"a4:c1:38:45:66:e7:d9:85":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}],"1794":[{"value":"4846","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-07-17 18:40:08]DEBUG : Search attribut for a4:c1:38:45:66:e7:d9:85 logicalId : 1::6::0 => Bool.false convert to 0
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:f4:9d:19:3b:3f","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : Search attribut for a4:c1:38:45:66:e7:d9:85 logicalId : 1::1794::0 => 4846 convert to 4846
[2023-07-17 18:40:08]DEBUG : [Cuisine][Cafetière] refresh
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:f4:9d:19:3b:3f","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:f4:9d:19:3b:3f","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : {"devices":{"a4:c1:38:45:66:e7:d9:85":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}},"a4:c1:38:f4:9d:19:3b:3f":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2023-07-17 18:40:08]DEBUG : Search attribut for a4:c1:38:45:66:e7:d9:85 logicalId : 1::2820::1291 => 0 convert to 0
[2023-07-17 18:40:08]DEBUG : Search attribut for a4:c1:38:f4:9d:19:3b:3f logicalId : 1::6::0 => Bool.true convert to 1
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:b1:6c:2c:0c:5a","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : [Garage][Sèche linge] refresh
[2023-07-17 18:40:08]DEBUG : {"ieee":"a4:c1:38:b1:6c:2c:0c:5a","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:08]DEBUG : {"devices":{"a4:c1:38:f4:9d:19:3b:3f":{"1":{"1794":[{"value":"1101","cluster_name":"TuyaZBMeteringCluster"}],"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}},"a4:c1:38:b1:6c:2c:0c:5a":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:f4:9d:19:3b:3f logicalId : 1::1794::0 => 1101 convert to 1101
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:f4:9d:19:3b:3f logicalId : 1::2820::1291 => 0 convert to 0
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:b1:6c:2c:0c:5a logicalId : 1::6::0 => Bool.true convert to 1
[2023-07-17 18:40:09]DEBUG : [Garage][Sèche linge] refresh
[2023-07-17 18:40:09]DEBUG : http://127.0.0.1:8089/device/attributes type : POST
[2023-07-17 18:40:09]DEBUG : {"ieee":"a4:c1:38:b1:6c:2c:0c:5a","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-07-17 18:40:09]DEBUG : {"ieee":"a4:c1:38:be:eb:bc:ec:6b","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:09]DEBUG : {"devices":{"a4:c1:38:b1:6c:2c:0c:5a":{"1":{"1794":[{"value":"5615","cluster_name":"TuyaZBMeteringCluster"}],"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:b1:6c:2c:0c:5a logicalId : 1::1794::0 => 5615 convert to 5615
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:b1:6c:2c:0c:5a logicalId : 1::2820::1291 => 0 convert to 0
[2023-07-17 18:40:09]DEBUG : [Jardin][Pompe Avant] refresh
[2023-07-17 18:40:09]DEBUG : {"ieee":"a4:c1:38:be:eb:bc:ec:6b","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:09]DEBUG : {"ieee":"a4:c1:38:be:eb:bc:ec:6b","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-07-17 18:40:09]DEBUG : {"devices":{"a4:c1:38:be:eb:bc:ec:6b":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}],"1794":[{"value":"633","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:be:eb:bc:ec:6b logicalId : 1::6::0 => Bool.false convert to 0
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:be:eb:bc:ec:6b logicalId : 1::1794::0 => 633 convert to 633
[2023-07-17 18:40:09]DEBUG : {"ieee":"a4:c1:38:90:61:95:34:fa","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:09]DEBUG : {"devices":{"a4:c1:38:be:eb:bc:ec:6b":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:be:eb:bc:ec:6b logicalId : 1::2820::1291 => 0 convert to 0
[2023-07-17 18:40:09]DEBUG : [Jardin][Pompe Piscine] refresh
[2023-07-17 18:40:09]DEBUG : {"ieee":"a4:c1:38:90:61:95:34:fa","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:09]DEBUG : {"devices":{"a4:c1:38:90:61:95:34:fa":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2023-07-17 18:40:09]DEBUG : Search attribut for a4:c1:38:90:61:95:34:fa logicalId : 1::6::0 => Bool.false convert to 0
[2023-07-17 18:40:11]DEBUG : [Jardin][Pompe Piscine] refresh
[2023-07-17 18:40:11]DEBUG : http://127.0.0.1:8089/device/attributes type : POST
[2023-07-17 18:40:11]DEBUG : {"ieee":"a4:c1:38:90:61:95:34:fa","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-07-17 18:40:11]DEBUG : {"devices":{"a4:c1:38:90:61:95:34:fa":{"1":{"1794":[{"value":"15990","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-07-17 18:40:11]DEBUG : Search attribut for a4:c1:38:90:61:95:34:fa logicalId : 1::1794::0 => 15990 convert to 15990
[2023-07-17 18:40:13]DEBUG : [Jardin][Pompe Piscine] refresh
[2023-07-17 18:40:13]DEBUG : http://127.0.0.1:8089/device/attributes type : POST
[2023-07-17 18:40:13]DEBUG : {"ieee":"00:15:8d:00:05:d2:a0:92","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[256,1],"allowCache":0}
[2023-07-17 18:40:13]DEBUG : [Maison][LiXee.ZLinky_TIC 00:15:8d:00:05:d2:a0:92] refresh
[2023-07-17 18:40:13]DEBUG : {"ieee":"a4:c1:38:42:b9:53:2c:8c","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:13]DEBUG : [Salon][Ventilateur] refresh
[2023-07-17 18:40:13]DEBUG : {"ieee":"a4:c1:38:42:b9:53:2c:8c","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-07-17 18:40:13]DEBUG : {"ieee":"a4:c1:38:42:b9:53:2c:8c","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-07-17 18:40:13]DEBUG : {"devices":{"a4:c1:38:90:61:95:34:fa":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}},"00:15:8d:00:05:d2:a0:92":{"1":{"1794":{"256":{"value":"15790042","cluster_name":"ZLinkyTICMetering"},"1":{"value":"1507974","cluster_name":"ZLinkyTICMetering"}}}},"a4:c1:38:42:b9:53:2c:8c":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}],"1794":[{"value":"777","cluster_name":"TuyaZBMeteringCluster"}]}}}}
[2023-07-17 18:40:13]DEBUG : Search attribut for a4:c1:38:90:61:95:34:fa logicalId : 1::2820::1291 => 0 convert to 0
[2023-07-17 18:40:13]DEBUG : Search attribut for 00:15:8d:00:05:d2:a0:92 logicalId : 1::1794::256 => 15790042 convert to 15790042
[2023-07-17 18:40:13]DEBUG : Search attribut for 00:15:8d:00:05:d2:a0:92 logicalId : 1::1794::1 => 1507974 convert to 1507974
[2023-07-17 18:40:13]DEBUG : Search attribut for a4:c1:38:42:b9:53:2c:8c logicalId : 1::6::0 => Bool.true convert to 1
[2023-07-17 18:40:13]DEBUG : Search attribut for a4:c1:38:42:b9:53:2c:8c logicalId : 1::1794::0 => 777 convert to 777
[2023-07-17 18:40:13]DEBUG : {"devices":{"a4:c1:38:42:b9:53:2c:8c":{"1":{"2820":{"1291":{"value":"61","cluster_name":"Electrical Measurement"}}}}}}
[2023-07-17 18:40:13]DEBUG : Search attribut for a4:c1:38:42:b9:53:2c:8c logicalId : 1::2820::1291 => 61 convert to 61
[2023-07-17 18:40:47]DEBUG : {"devices":{"e0:79:8d:ff:fe:d0:c2:60":{"1":[{"1":{"value":"64","cluster_name":"Basic"},"65506":{"value":"22","cluster_name":"Basic"}}]}}}
[2023-07-17 18:40:47]DEBUG : Search attribut for e0:79:8d:ff:fe:d0:c2:60 logicalId : 1::0::1 => 64 convert to 64
Log Zigbee :
"ieee": "a4:c1:38:5e:9f:86:18:51",
"nwk": 8870,
"status": 2,
"lqi": "96",
"rssi": "-76",
"last_seen": "1689611896.253651",
"node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "_TZE200_a7sghmms",
"model": "TS0601",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"id": 0,
"name": "Basic",
"attributes": [
"id": 1,
"name": "app_version",
"value": 72
"id": 4,
"name": "manufacturer",
"value": "_TZE200_a7sghmms"
"id": 5,
"name": "model",
"value": "TS0601"
"signature": {
"model": "TS0601",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
4,
5,
61184,
0
25,
10
"class": "zigpy.device"
