J’ai acheté ce détecteur de mouvement/presence radar 24 Ghz zigbee vendu en masse pour usage compatible tuya
Je l’ai fait reconnaitre en capteur technologie radar moes (déjà connu dans jeedom)
La remontée info luminosité retourne la bonne valeur, il n’y a pas de remontée sur la presence / mouvement
Pourriez-vous m’aider à faire le nécessaire pour rendre le module compatible avec jeedom (j’ai toujours utilisé des équipements déjà compatibles jusqu’à maintenant) ?
Merci pour votre aide
Données de la colonne informations brutes du module :
"ieee": "a4:c1:38:c4:db:1f:23:9a",
"nwk": 61966,
"status": 2,
"lqi": "204",
"rssi": "-49",
"last_seen": "1737224050.842142",
"node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "_TZE200_2aaelwxk",
"model": "TS0225",
"output_clusters": [
"id": 10,
"name": "Time",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 162
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZE200_2aaelwxk"
"id": 5,
"name": "model",
"value": "TS0225"
"id": 7,
"name": "power_source",
"value": 4
"id": 16384,
"name": "sw_build_id",
"value": "0122052017"
"id": 3,
"name": "Identify",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 16,
"name": "cie_addr",
"value": [
184,
148,
113,
254,
255,
141,
121,
224
"id": 57346,
"name": "Cluster",
"attributes": []
"id": 61184,
"name": "Cluster",
"attributes": []
"id": 60928,
"name": "Cluster",
"attributes": []
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 1024,
"name": "Illuminance Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 1
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "TS0225",
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
3,
1280,
57346,
61184,
60928,
57344,
1024
10,
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
