ci dessous, les informations pour l’ajout d’un mini capteur de présence Tuya. Ce capteur fonctionne déjà en utilisant :
le Fabricant : Tuya
Equipement : Mini capteur de mouvement [TYZB01-TS0202]
Modèle exact : IH012-RT01 (indiqué sur la boite)
lien fournisseur
Image produit :
Informations brutes
"ieee": "a4:c1:38:37:3f:8d:2f:11",
"nwk": 28007,
"status": 2,
"lqi": "116",
"rssi": "-71",
"last_seen": "1663068647.562169",
"node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "_TZ3000_mcxw5ehu",
"model": "TS0202",
"output_clusters": [
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 16,
"name": "cie_addr",
"value": [
137,
107,
150,
254,
255,
249,
227,
180
"id": 19,
"name": "current_zone_sensitivity_level",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 70
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_mcxw5ehu"
"id": 5,
"name": "model",
"value": "TS0202"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"signature": {
"model": "TS0202",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
1,
1280,
3,
0
4096,
6,
25,
10
"class": "zigpy.device"
LOG Zigbee
zigbee.txt (61,0 Ko)
Merci d’avance et si jamais j’ai oublié quelque chose, ne pas hésiter.
Et si je peux aider à rajouter des équipements simple comme celui-là, je suis preneur.
Cdt,
Philippe
