Demande ajout de commande
salut tlm,
j’utilise des inters xiaomi sans neutre et j’avais 2 commandes de retour d’etat : (pour mes scenarios)
etat de charge
etat du switch
la j’en qu’un des deux serait possible de rajouter la commande manquante
je joins les données brute de l’inter
donnees-brute-inter-xiaomi.txt (9,9 Ko)
[quote=« letictac67, post:1, topic:64595, full:true »]
salut tlm,
etat de charge
etat du switch
merci d’avance
    "ieee": "00:15:8d:00:01:3e:47:51",
    "nwk": 25515,
    "status": 2,
    "lqi": "255",
    "rssi": "-36",
    "last_seen": "1626213431.3308368",
    "node_descriptor": "01:40:84:37:10:7f:64:00:01:00:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 6,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.ctrl_neutral1",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 0
                            "id": 1,
                            "name": "app_version",
                            "value": 17
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 38
                            "id": 4,
                            "name": "manufacturer",
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.ctrl_neutral1"
                            "id": 6,
                            "name": "date_code",
                            "value": "08-31-2016"
                            "id": 7,
                            "name": "power_source",
                            "value": 4
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 2,
                    "name": "Device Temperature",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 16,
                    "name": "BinaryOutput",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 16,
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
            "id": 4,
            "status": 1,
            "device_type": 0,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 18,
                    "name": "MultistateInput",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
            "id": 5,
            "status": 1,
            "device_type": 0,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 18,
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "id": 6,
            "status": 1,
            "device_type": 0,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 18,
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "id": 8,
            "status": 1,
            "device_type": 83,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 12,
                    "name": "AnalogInput",
                    "attributes": []
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 132,
            "manufacturer_code": 4151,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 1,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 6,
                "input_clusters": [
                    0,
                    3,
                    1,
                    2,
                    25,
                    10
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    16,
                    6,
                    4,
                    5
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    16,
                    6,
                    4,
                    5
            "4": {
                "profile_id": 260,
                "device_type": 0,
                "input_clusters": [
                    18,
                    6
            "5": {
                "profile_id": 260,
                "device_type": 0,
                "input_clusters": [
                    18,
                    6
            "6": {
                "profile_id": 260,
                "device_type": 0,
                "input_clusters": [
                    18,
                    6
            "8": {
                "profile_id": 260,
                "device_type": 83,
                "input_clusters": [
                    12
    "class": "zigpy.device"
