J’ai quelques capteurs de températures Zigbee que j’'essaie d’utiliser avec le plugin Jeezigbee.
les références de ces capteurs sont les suivant:
Lien Aliexpress
Ces capteurs existent sur https://www.zigbee2mqtt.io/
Référence sur Zigbee2mqqt
Le capteur est bien détecté par Jeedom.mais il n’est pas reconnu.
Voici les informations bruts obenus
"date_code": "",
"definition": {
"exposes": null
"disabled": false,
"endpoints": {
"1": {
"bindings": [],
"clusters": {
"input": [
"genGroups",
"genScenes",
"manuSpecificTuya",
"genBasic"
"output": [
"genOta",
"genTime"
"configured_reportings": [],
"scenes": []
"friendly_name": "0xa4c138157361cc90",
"ieee_address": "0xa4c138157361cc90",
"interview_completed": true,
"interviewing": false,
"manufacturer": "_TZE204_upagmta9",
"model_id": "TS0601",
"network_address": 52259,
"power_source": "Battery",
"supported": false,
"type": "EndDevice"
en mode debug, voici les informations qui sont reçus
[2023-11-11 12:51:41][DEBUG] : [Aucun][Capteur temperature] Check for update last_seen => "2023-11-11 12:51:41", raw : "2023-11-11T11:51:41.490Z"
[2023-11-11 12:51:44][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt\/0xa4c138157361cc90', payload '{\"device\":{\"applicationVersion\":73,\"dateCode\":\"\",\"friendlyName\":\"0xa4c138157361cc90\",\"hardwareVersion\":1,\"ieeeAddr\":\"0xa4c138157361cc90\",\"manufacturerID\":4417,\"manufacturerName\":\"_TZE204_upagmta9\",\"model\":\"unknown\",\"networkAddress\":52259,\"powerSource\":\"Battery\",\"stackVersion\":0,\"type\":\"EndDevice\",\"zclVersion\":3},\"last_seen\":\"2023-11-11T11:51:44.339Z\"}'"}},"0xa4c138157361cc90":{"device":{"applicationVersion":73,"dateCode":"","friendlyName":"0xa4c138157361cc90","hardwareVersion":1,"ieeeAddr":"0xa4c138157361cc90","manufacturerID":4417,"manufacturerName":"_TZE204_upagmta9","model":"unknown","networkAddress":52259,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-11-11T11:51:44.339Z"}}}
[2023-11-11 12:51:44][DEBUG] : [Aucun][Capteur temperature] Check for update last_seen => "2023-11-11 12:51:44", raw : "2023-11-11T11:51:44.339Z"
[2023-11-11 12:51:47][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt\/0xa4c138157361cc90', payload '{\"device\":{\"applicationVersion\":73,\"dateCode\":\"\",\"friendlyName\":\"0xa4c138157361cc90\",\"hardwareVersion\":1,\"ieeeAddr\":\"0xa4c138157361cc90\",\"manufacturerID\":4417,\"manufacturerName\":\"_TZE204_upagmta9\",\"model\":\"unknown\",\"networkAddress\":52259,\"powerSource\":\"Battery\",\"stackVersion\":0,\"type\":\"EndDevice\",\"zclVersion\":3},\"last_seen\":\"2023-11-11T11:51:47.188Z\"}'"}},"0xa4c138157361cc90":{"device":{"applicationVersion":73,"dateCode":"","friendlyName":"0xa4c138157361cc90","hardwareVersion":1,"ieeeAddr":"0xa4c138157361cc90","manufacturerID":4417,"manufacturerName":"_TZE204_upagmta9","model":"unknown","networkAddress":52259,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-11-11T11:51:47.188Z"}}}
[2023-11-11 12:51:47][DEBUG] : [Aucun][Capteur temperature] Check for update last_seen => "2023-11-11 12:51:47", raw : "2023-11-11T11:51:47.188Z"
[2023-11-11 12:51:50][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt\/0xa4c138157361cc90', payload '{\"device\":{\"applicationVersion\":73,\"dateCode\":\"\",\"friendlyName\":\"0xa4c138157361cc90\",\"hardwareVersion\":1,\"ieeeAddr\":\"0xa4c138157361cc90\",\"manufacturerID\":4417,\"manufacturerName\":\"_TZE204_upagmta9\",\"model\":\"unknown\",\"networkAddress\":52259,\"powerSource\":\"Battery\",\"stackVersion\":0,\"type\":\"EndDevice\",\"zclVersion\":3},\"last_seen\":\"2023-11-11T11:51:50.036Z\"}'"}},"0xa4c138157361cc90":{"device":{"applicationVersion":73,"dateCode":"","friendlyName":"0xa4c138157361cc90","hardwareVersion":1,"ieeeAddr":"0xa4c138157361cc90","manufacturerID":4417,"manufacturerName":"_TZE204_upagmta9","model":"unknown","networkAddress":52259,"powerSource":"Battery","stackVersion":0,"type":"EndDevice","zclVersion":3},"last_seen":"2023-11-11T11:51:50.036Z"}}}
[2023-11-11 12:51:50][DEBUG] : [Aucun][Capteur temperature] Check for update last_seen => "2023-11-11 12:51:50", raw : "2023-11-11T11:51:50.036Z"
Est il envisageable d’ajouter ce capteur à la liste des capteurs reconnus pas jeedom?
en vous remerciant par avance
Jerome
