Bonjour à tous, je rencontre un problème sur Jeedore.
L’installation se déroule correctement, l’installation des dépendances est OK, le daemon se lance parfaitement après avoir rempli les différentes informations de connexion de la Tydom 1.0.
Les équipements remontent correctement et sont pilotables. Mais au bout d’un certain moment (quelques heures maximum) la connexion se perd et plus aucun périphérique n’est joignable.
Je suis obligé de me reloggé (en mettant la Tydom en mode association : appui sur le petit bouton derrière).
Voici les logs du daemon :
12/04/2021 09:53:49 - Jeedore Daemon connection has been closed...
12/04/2021 09:53:49 - Connection to DeltaDore server has been closed...
12/04/2021 09:54:16 - Websocket connection initialization....
12/04/2021 09:54:16 - Connecting to '192.168.1.181'
12/04/2021 09:54:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:54:19 - Jeedore Daemon connection has been closed...
12/04/2021 09:54:19 - Connection to DeltaDore server has been closed...
12/04/2021 09:54:46 - Websocket connection initialization....
12/04/2021 09:54:46 - Connecting to '192.168.1.181'
12/04/2021 09:54:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:54:49 - Jeedore Daemon connection has been closed...
12/04/2021 09:54:49 - Connection to DeltaDore server has been closed...
12/04/2021 09:55:16 - Websocket connection initialization....
12/04/2021 09:55:16 - Connecting to '192.168.1.181'
12/04/2021 09:55:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:55:19 - Jeedore Daemon connection has been closed...
12/04/2021 09:55:19 - Connection to DeltaDore server has been closed...
12/04/2021 09:55:46 - Websocket connection initialization....
12/04/2021 09:55:46 - Connecting to '192.168.1.181'
12/04/2021 09:55:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:55:49 - Jeedore Daemon connection has been closed...
12/04/2021 09:55:49 - Connection to DeltaDore server has been closed...
12/04/2021 09:56:16 - Websocket connection initialization....
12/04/2021 09:56:16 - Connecting to '192.168.1.181'
12/04/2021 09:56:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:56:19 - Jeedore Daemon connection has been closed...
12/04/2021 09:56:19 - Connection to DeltaDore server has been closed...
12/04/2021 09:56:46 - Websocket connection initialization....
12/04/2021 09:56:46 - Connecting to '192.168.1.181'
12/04/2021 09:56:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:56:49 - Jeedore Daemon connection has been closed...
12/04/2021 09:56:49 - Connection to DeltaDore server has been closed...
12/04/2021 09:57:16 - Websocket connection initialization....
12/04/2021 09:57:16 - Connecting to '192.168.1.181'
12/04/2021 09:57:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:57:19 - Jeedore Daemon connection has been closed...
12/04/2021 09:57:19 - Connection to DeltaDore server has been closed...
12/04/2021 09:57:21 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:57:21 - Jeedore Daemon connection has been closed...
12/04/2021 09:57:21 - An error with websocket connection has occured...
12/04/2021 09:57:21 - Error websocket : 'An error has occurred in sending data.
12/04/2021 09:57:21 - Jeedore Daemon has received a DeltaDore error...
12/04/2021 09:57:46 - Websocket connection initialization....
12/04/2021 09:57:46 - Connecting to '192.168.1.181'
12/04/2021 09:57:48 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:57:48 - Jeedore Daemon connection has been closed...
12/04/2021 09:57:48 - Connection to DeltaDore server has been closed...
12/04/2021 09:58:16 - Websocket connection initialization....
12/04/2021 09:58:16 - Connecting to '192.168.1.181'
12/04/2021 09:58:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:58:19 - Jeedore Daemon connection has been closed...
12/04/2021 09:58:19 - Connection to DeltaDore server has been closed...
12/04/2021 09:58:46 - Websocket connection initialization....
12/04/2021 09:58:46 - Connecting to '192.168.1.181'
12/04/2021 09:58:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:58:49 - Jeedore Daemon connection has been closed...
12/04/2021 09:58:49 - Connection to DeltaDore server has been closed...
12/04/2021 09:59:16 - Websocket connection initialization....
12/04/2021 09:59:16 - Connecting to '192.168.1.181'
12/04/2021 09:59:18 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:59:18 - Jeedore Daemon connection has been closed...
12/04/2021 09:59:18 - Connection to DeltaDore server has been closed...
12/04/2021 09:59:46 - Websocket connection initialization....
12/04/2021 09:59:46 - Connecting to '192.168.1.181'
12/04/2021 09:59:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 09:59:49 - Jeedore Daemon connection has been closed...
12/04/2021 09:59:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:00:16 - Websocket connection initialization....
12/04/2021 10:00:16 - Connecting to '192.168.1.181'
12/04/2021 10:00:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:00:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:00:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:00:46 - Websocket connection initialization....
12/04/2021 10:00:46 - Connecting to '192.168.1.181'
12/04/2021 10:00:48 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:00:48 - Jeedore Daemon connection has been closed...
12/04/2021 10:00:48 - Connection to DeltaDore server has been closed...
12/04/2021 10:01:16 - Websocket connection initialization....
12/04/2021 10:01:16 - Connecting to '192.168.1.181'
12/04/2021 10:01:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:01:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:01:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:01:46 - Websocket connection initialization....
12/04/2021 10:01:46 - Connecting to '192.168.1.181'
12/04/2021 10:01:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:01:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:01:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:02:16 - Websocket connection initialization....
12/04/2021 10:02:16 - Connecting to '192.168.1.181'
12/04/2021 10:02:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:02:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:02:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:02:46 - Websocket connection initialization....
12/04/2021 10:02:46 - Connecting to '192.168.1.181'
12/04/2021 10:02:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:02:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:02:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:03:16 - Websocket connection initialization....
12/04/2021 10:03:16 - Connecting to '192.168.1.181'
12/04/2021 10:03:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:03:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:03:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:03:46 - Websocket connection initialization....
12/04/2021 10:03:46 - Connecting to '192.168.1.181'
12/04/2021 10:03:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:03:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:03:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:04:16 - Websocket connection initialization....
12/04/2021 10:04:16 - Connecting to '192.168.1.181'
12/04/2021 10:04:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:04:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:04:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:04:46 - Websocket connection initialization....
12/04/2021 10:04:46 - Connecting to '192.168.1.181'
12/04/2021 10:04:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:04:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:04:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:05:16 - Websocket connection initialization....
12/04/2021 10:05:16 - Connecting to '192.168.1.181'
12/04/2021 10:05:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:05:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:05:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:05:46 - Websocket connection initialization....
12/04/2021 10:05:46 - Connecting to '192.168.1.181'
12/04/2021 10:05:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:05:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:05:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:06:16 - Websocket connection initialization....
12/04/2021 10:06:16 - Connecting to '192.168.1.181'
12/04/2021 10:06:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:06:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:06:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:06:46 - Websocket connection initialization....
12/04/2021 10:06:46 - Connecting to '192.168.1.181'
12/04/2021 10:06:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:06:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:06:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:07:16 - Websocket connection initialization....
12/04/2021 10:07:16 - Connecting to '192.168.1.181'
12/04/2021 10:07:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:07:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:07:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:07:21 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:07:21 - Jeedore Daemon connection has been closed...
12/04/2021 10:07:21 - An error with websocket connection has occured...
12/04/2021 10:07:21 - Error websocket : 'An error has occurred in sending data.
12/04/2021 10:07:21 - Jeedore Daemon has received a DeltaDore error...
12/04/2021 10:07:46 - Websocket connection initialization....
12/04/2021 10:07:46 - Connecting to '192.168.1.181'
12/04/2021 10:07:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:07:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:07:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:08:16 - Websocket connection initialization....
12/04/2021 10:08:16 - Connecting to '192.168.1.181'
12/04/2021 10:08:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:08:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:08:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:08:46 - Websocket connection initialization....
12/04/2021 10:08:46 - Connecting to '192.168.1.181'
12/04/2021 10:08:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:08:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:08:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:09:16 - Websocket connection initialization....
12/04/2021 10:09:16 - Connecting to '192.168.1.181'
12/04/2021 10:09:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:09:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:09:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:09:46 - Websocket connection initialization....
12/04/2021 10:09:46 - Connecting to '192.168.1.181'
12/04/2021 10:09:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:09:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:09:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:10:16 - Websocket connection initialization....
12/04/2021 10:10:16 - Connecting to '192.168.1.181'
12/04/2021 10:10:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:10:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:10:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:10:46 - Websocket connection initialization....
12/04/2021 10:10:46 - Connecting to '192.168.1.181'
12/04/2021 10:10:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:10:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:10:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:11:16 - Websocket connection initialization....
12/04/2021 10:11:16 - Connecting to '192.168.1.181'
12/04/2021 10:11:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:11:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:11:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:11:46 - Websocket connection initialization....
12/04/2021 10:11:46 - Connecting to '192.168.1.181'
12/04/2021 10:11:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:11:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:11:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:12:16 - Websocket connection initialization....
12/04/2021 10:12:16 - Connecting to '192.168.1.181'
12/04/2021 10:12:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:12:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:12:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:12:46 - Websocket connection initialization....
12/04/2021 10:12:46 - Connecting to '192.168.1.181'
12/04/2021 10:12:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:12:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:12:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:13:16 - Websocket connection initialization....
12/04/2021 10:13:16 - Connecting to '192.168.1.181'
12/04/2021 10:13:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:13:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:13:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:13:46 - Websocket connection initialization....
12/04/2021 10:13:46 - Connecting to '192.168.1.181'
12/04/2021 10:13:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:13:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:13:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:14:16 - Websocket connection initialization....
12/04/2021 10:14:16 - Connecting to '192.168.1.181'
12/04/2021 10:14:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:14:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:14:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:14:46 - Websocket connection initialization....
12/04/2021 10:14:46 - Connecting to '192.168.1.181'
12/04/2021 10:14:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:14:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:14:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:15:16 - Websocket connection initialization....
12/04/2021 10:15:16 - Connecting to '192.168.1.181'
12/04/2021 10:15:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:15:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:15:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:15:46 - Websocket connection initialization....
12/04/2021 10:15:46 - Connecting to '192.168.1.181'
12/04/2021 10:15:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:15:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:15:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:16:16 - Websocket connection initialization....
12/04/2021 10:16:16 - Connecting to '192.168.1.181'
12/04/2021 10:16:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:16:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:16:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:16:46 - Websocket connection initialization....
12/04/2021 10:16:46 - Connecting to '192.168.1.181'
12/04/2021 10:16:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:16:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:16:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:17:16 - Websocket connection initialization....
12/04/2021 10:17:16 - Connecting to '192.168.1.181'
12/04/2021 10:17:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:17:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:17:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:17:21 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:17:21 - Jeedore Daemon connection has been closed...
12/04/2021 10:17:21 - An error with websocket connection has occured...
12/04/2021 10:17:21 - Error websocket : 'An error has occurred in sending data.
12/04/2021 10:17:21 - Jeedore Daemon has received a DeltaDore error...
12/04/2021 10:17:46 - Websocket connection initialization....
12/04/2021 10:17:46 - Connecting to '192.168.1.181'
12/04/2021 10:17:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:17:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:17:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:18:16 - Websocket connection initialization....
12/04/2021 10:18:16 - Connecting to '192.168.1.181'
12/04/2021 10:18:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:18:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:18:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:18:46 - Websocket connection initialization....
12/04/2021 10:18:46 - Connecting to '192.168.1.181'
12/04/2021 10:18:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:18:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:18:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:19:16 - Websocket connection initialization....
12/04/2021 10:19:16 - Connecting to '192.168.1.181'
12/04/2021 10:19:18 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:19:18 - Jeedore Daemon connection has been closed...
12/04/2021 10:19:18 - Connection to DeltaDore server has been closed...
12/04/2021 10:19:46 - Websocket connection initialization....
12/04/2021 10:19:46 - Connecting to '192.168.1.181'
12/04/2021 10:19:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:19:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:19:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:20:16 - Websocket connection initialization....
12/04/2021 10:20:16 - Connecting to '192.168.1.181'
12/04/2021 10:20:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:20:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:20:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:20:46 - Websocket connection initialization....
12/04/2021 10:20:46 - Connecting to '192.168.1.181'
12/04/2021 10:20:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:20:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:20:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:21:16 - Websocket connection initialization....
12/04/2021 10:21:16 - Connecting to '192.168.1.181'
12/04/2021 10:21:18 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:21:18 - Jeedore Daemon connection has been closed...
12/04/2021 10:21:18 - Connection to DeltaDore server has been closed...
12/04/2021 10:21:46 - Websocket connection initialization....
12/04/2021 10:21:46 - Connecting to '192.168.1.181'
12/04/2021 10:21:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:21:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:21:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:22:16 - Websocket connection initialization....
12/04/2021 10:22:16 - Connecting to '192.168.1.181'
12/04/2021 10:22:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:22:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:22:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:22:46 - Websocket connection initialization....
12/04/2021 10:22:46 - Connecting to '192.168.1.181'
12/04/2021 10:22:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:22:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:22:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:23:16 - Websocket connection initialization....
12/04/2021 10:23:16 - Connecting to '192.168.1.181'
12/04/2021 10:23:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:23:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:23:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:23:46 - Websocket connection initialization....
12/04/2021 10:23:46 - Connecting to '192.168.1.181'
12/04/2021 10:23:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:23:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:23:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:24:16 - Websocket connection initialization....
12/04/2021 10:24:16 - Connecting to '192.168.1.181'
12/04/2021 10:24:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:24:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:24:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:24:46 - Websocket connection initialization....
12/04/2021 10:24:46 - Connecting to '192.168.1.181'
12/04/2021 10:24:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:24:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:24:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:25:16 - Websocket connection initialization....
12/04/2021 10:25:16 - Connecting to '192.168.1.181'
12/04/2021 10:25:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:25:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:25:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:25:46 - Websocket connection initialization....
12/04/2021 10:25:46 - Connecting to '192.168.1.181'
12/04/2021 10:25:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:25:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:25:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:26:16 - Websocket connection initialization....
12/04/2021 10:26:16 - Connecting to '192.168.1.181'
12/04/2021 10:26:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:26:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:26:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:26:46 - Websocket connection initialization....
12/04/2021 10:26:46 - Connecting to '192.168.1.181'
12/04/2021 10:26:48 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:26:48 - Jeedore Daemon connection has been closed...
12/04/2021 10:26:48 - Connection to DeltaDore server has been closed...
12/04/2021 10:27:16 - Websocket connection initialization....
12/04/2021 10:27:16 - Connecting to '192.168.1.181'
12/04/2021 10:27:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:27:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:27:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:27:21 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:27:21 - Jeedore Daemon connection has been closed...
12/04/2021 10:27:21 - An error with websocket connection has occured...
12/04/2021 10:27:21 - Error websocket : 'An error has occurred in sending data.
12/04/2021 10:27:21 - Jeedore Daemon has received a DeltaDore error...
12/04/2021 10:27:46 - Websocket connection initialization....
12/04/2021 10:27:46 - Connecting to '192.168.1.181'
12/04/2021 10:27:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:27:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:27:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:28:16 - Websocket connection initialization....
12/04/2021 10:28:16 - Connecting to '192.168.1.181'
12/04/2021 10:28:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:28:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:28:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:28:46 - Websocket connection initialization....
12/04/2021 10:28:46 - Connecting to '192.168.1.181'
12/04/2021 10:28:48 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:28:48 - Jeedore Daemon connection has been closed...
12/04/2021 10:28:48 - Connection to DeltaDore server has been closed...
12/04/2021 10:29:16 - Websocket connection initialization....
12/04/2021 10:29:16 - Connecting to '192.168.1.181'
12/04/2021 10:29:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:29:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:29:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:29:46 - Websocket connection initialization....
12/04/2021 10:29:46 - Connecting to '192.168.1.181'
12/04/2021 10:29:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:29:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:29:49 - Connection to DeltaDore server has been closed...
12/04/2021 10:30:16 - Websocket connection initialization....
12/04/2021 10:30:16 - Connecting to '192.168.1.181'
12/04/2021 10:30:19 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:30:19 - Jeedore Daemon connection has been closed...
12/04/2021 10:30:19 - Connection to DeltaDore server has been closed...
12/04/2021 10:30:46 - Websocket connection initialization....
12/04/2021 10:30:46 - Connecting to '192.168.1.181'
12/04/2021 10:30:49 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
12/04/2021 10:30:49 - Jeedore Daemon connection has been closed...
12/04/2021 10:30:49 - Connection to DeltaDore server has been closed...
Je suis sur une Jeedom ATLAS en version 4.1.27.
Jeedore est à jour.
J’ai essayé de mettre le daemon en gestion manuelle le problème persiste.
Merci de votre aide.
Cordialement
