Je migre du plugin zigbee vers zigbee2mqtt, il y d’avantages de support sur pas mal de composants mais voila que ma sirène qui s’intègre bien et remonte bien les commandes… je n’arrive pas à la déclencher
Documentation :
Elle remonte bien :
Voici les informations brutes :
"date_code": "2021.2.19",
"definition": {
"description": "Smart siren",
"exposes": [
"access": 1,
"description": "Remaining battery in %, can take up to 24 hours before reported.",
"name": "battery",
"property": "battery",
"type": "numeric",
"unit": "%",
"value_max": 100,
"value_min": 0
"access": 2,
"features": [
"access": 2,
"description": "Mode of the warning (sound effect)",
"name": "mode",
"property": "mode",
"type": "enum",
"values": [
"stop",
"burglar",
"fire",
"emergency",
"police_panic",
"fire_panic",
"emergency_panic"
"access": 2,
"description": "Sound level",
"name": "level",
"property": "level",
"type": "enum",
"values": [
"low",
"medium",
"high",
"very_high"
"access": 2,
"description": "Intensity of the strobe",
"name": "strobe_level",
"property": "strobe_level",
"type": "enum",
"values": [
"low",
"medium",
"high",
"very_high"
"access": 2,
"description": "Turn on\/off the strobe (light) during warning",
"name": "strobe",
"property": "strobe",
"type": "binary",
"value_off": false,
"value_on": true
"access": 2,
"description": "Length of the flash cycle",
"name": "strobe_duty_cycle",
"property": "strobe_duty_cycle",
"type": "numeric",
"value_max": 10,
"value_min": 0
"access": 2,
"description": "Duration in seconds of the alarm",
"name": "duration",
"property": "duration",
"type": "numeric",
"unit": "s"
"name": "warning",
"property": "warning",
"type": "composite"
"access": 1,
"description": "Link quality (signal strength)",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "HS2WD-E",
"options": [],
"supports_ota": false,
"vendor": "HEIMAN"
"disabled": false,
"endpoints": {
"1": {
"bindings": [
"cluster": "genPowerCfg",
"target": {
"endpoint": 1,
"ieee_address": "0x00212effff04f446",
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genPowerCfg",
"genIdentify",
"genGroups",
"ssIasZone",
"ssIasWd",
"haDiagnostic"
"output": [
"genOta"
"configured_reportings": [
"attribute": "batteryPercentageRemaining",
"maximum_report_interval": 62000,
"minimum_report_interval": 3600,
"reportable_change": 0
"scenes": []
"242": {
"bindings": [],
"clusters": {
"input": [],
"output": [
"greenPower"
"configured_reportings": [],
"scenes": []
"friendly_name": "0xcc86ecfffeb01f25",
"ieee_address": "0xcc86ecfffeb01f25",
"interview_completed": true,
"interviewing": false,
"manufacturer": "HEIMAN",
"model_id": "WarningDevice-EF-3.0",
"network_address": 65371,
"power_source": "Mains (single phase)",
"supported": true,
"type": "Router"
Les commandes
Mais aucun « mode » ne fonctionne, la commande se lance bien mais pas de bruit. J’ai préalablement lancé des commandes de durée, strobe et volume me disant qu’il avait besoin de se configurer mais rien.
AVANT sur le plugin zigbee j’avais cela :
Mode enum :
1::ias_wd::start_warning::1::1::2::#duration#::2::0|Son ON, Led ON ;
1::ias_wd::start_warning::1::0::2::#duration#::2::0| Son ON, Led OFF ;
1::ias_wd::start_warning::0::1::0::#duration#::2::0|Son OFF, Led ON ;
1::ias_wd::start_warning::0::0::0::#duration#::2::0| Son OFF, Led OFF |
Jamais eu de soucis, quelqu’un à déjà utilisé ces sirènes sur cette remontée de commande ?
Merci d’avance à tous,
