Sur VM Debian12 à jour
Core alpha installé après avoir récupéré le script via wget
Quelques plugins installés pour tester si OK
La j’installe RFXCom pour tester justement
Les dépendances sont Nok
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_rfxcom
0003|+ echo 1
0004|+ echo 2
0005|+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
0006|+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
0007|Launch pre-install of rfxcom dependancy
0008|error: externally-managed-environment
0009|× This environment is externally managed
0010|╰─> To install Python packages system-wide, try apt install
0011|python3-xyz, where xyz is the package you are trying to
0012|install.
0013|If you wish to install a non-Debian-packaged Python package,
0014|create a virtual environment using python3 -m venv path/to/venv.
0015|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0016|sure you have python3-full installed.
0017|If you wish to install a non-Debian packaged Python application,
0018|it may be easiest to use pipx install xyz, which will manage a
0019|virtual environment for you. Make sure you have pipx installed.
0020|See /usr/share/doc/python3.11/README.venv for more information.
0021|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0022|hint: See PEP 668 for the detailed specification.
0023|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0024|Reading package lists...
0025|Building dependency tree...
0026|Reading state information...
0027|Package 'python3-serial' is not installed, so not removed
0028|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0029|+ echo 3
0030|+ sudo apt update
0031|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0032|Hit:1 http://deb.debian.org/debian bookworm InRelease
0033|Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
0034|Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
0035|Hit:4 https://deb.nodesource.com/node_16.x bookworm InRelease
0036|Reading package lists...
0037|Building dependency tree...
0038|Reading state information...
0039|All packages are up to date.
0040|+ echo 4
0041|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3
0042|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0043|Reading package lists...
0044|Building dependency tree...
0045|Reading state information...
0046|python3 is already the newest version (3.11.2-1+b1).
0047|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0048|+ echo 5
0049|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pip
0050|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0051|Reading package lists...
0052|Building dependency tree...
0053|Reading state information...
0054|python3-pip is already the newest version (23.0.1+dfsg-1).
0055|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0056|+ echo 6
0057|+ sudo apt install -o Dpkg::Options::=--force-confdef -y build-essential
0058|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0059|Reading package lists...
0060|Building dependency tree...
0061|Reading state information...
0062|build-essential is already the newest version (12.9).
0063|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0064|+ echo 7
0065|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
0066|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0067|Reading package lists...
0068|Building dependency tree...
0069|Reading state information...
0070|python3-pyudev is already the newest version (0.24.0-1).
0071|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0072|+ echo 8
0073|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-dev
0074|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0075|Reading package lists...
0076|Building dependency tree...
0077|Reading state information...
0078|python3-dev is already the newest version (3.11.2-1+b1).
0079|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0080|+ echo 9
0081|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
0082|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0083|Reading package lists...
0084|Building dependency tree...
0085|Reading state information...
0086|python3-requests is already the newest version (2.28.1+dfsg-1).
0087|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0088|+ echo 10
0089|+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptools
0090|WARNING apt does not have a stable CLI interface. Use with caution in scripts.
0091|Reading package lists...
0092|Building dependency tree...
0093|Reading state information...
0094|python3-setuptools is already the newest version (66.1.1-1).
0095|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0096|+ echo 11
0097|++ cut -f 2-
0098|++ awk '$1 <= 4'
0099|++ find /usr/local/lib/python3.11/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
0100|+ RESULTTODELETE=
0101|++ sed 's, ,\ ,g'
0102|++ echo ''
0103|+ RESULTTODELETE2=
0104|+ xargs rm -rf
0105|+ echo ''
0106|+ echo 12
0107|+ sudo pip3 cache purge
0108|WARNING No matching packages
0109|Files removed: 0
0110|+ echo 13
0111|+ sudo pip3 install --upgrade pip
0112|error: externally-managed-environment
0113|× This environment is externally managed
0114|╰─> To install Python packages system-wide, try apt install
0115|python3-xyz, where xyz is the package you are trying to
0116|install.
0117|If you wish to install a non-Debian-packaged Python package,
0118|create a virtual environment using python3 -m venv path/to/venv.
0119|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0120|sure you have python3-full installed.
0121|If you wish to install a non-Debian packaged Python application,
0122|it may be easiest to use pipx install xyz, which will manage a
0123|virtual environment for you. Make sure you have pipx installed.
0124|See /usr/share/doc/python3.11/README.venv for more information.
0125|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0126|hint: See PEP 668 for the detailed specification.
0127|+ echo 14
0128|+ sudo pip3 install --force-reinstall --upgrade six
0129|error: externally-managed-environment
0130|× This environment is externally managed
0131|╰─> To install Python packages system-wide, try apt install
0132|python3-xyz, where xyz is the package you are trying to
0133|install.
0134|If you wish to install a non-Debian-packaged Python package,
0135|create a virtual environment using python3 -m venv path/to/venv.
0136|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0137|sure you have python3-full installed.
0138|If you wish to install a non-Debian packaged Python application,
0139|it may be easiest to use pipx install xyz, which will manage a
0140|virtual environment for you. Make sure you have pipx installed.
0141|See /usr/share/doc/python3.11/README.venv for more information.
0142|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0143|hint: See PEP 668 for the detailed specification.
0144|+ echo 15
0145|+ sudo pip3 install --force-reinstall --upgrade requests
0146|error: externally-managed-environment
0147|× This environment is externally managed
0148|╰─> To install Python packages system-wide, try apt install
0149|python3-xyz, where xyz is the package you are trying to
0150|install.
0151|If you wish to install a non-Debian-packaged Python package,
0152|create a virtual environment using python3 -m venv path/to/venv.
0153|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0154|sure you have python3-full installed.
0155|If you wish to install a non-Debian packaged Python application,
0156|it may be easiest to use pipx install xyz, which will manage a
0157|virtual environment for you. Make sure you have pipx installed.
0158|See /usr/share/doc/python3.11/README.venv for more information.
0159|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0160|hint: See PEP 668 for the detailed specification.
0161|+ echo 16
0162|+ sudo pip3 install --force-reinstall --upgrade setuptools
0163|error: externally-managed-environment
0164|× This environment is externally managed
0165|╰─> To install Python packages system-wide, try apt install
0166|python3-xyz, where xyz is the package you are trying to
0167|install.
0168|If you wish to install a non-Debian-packaged Python package,
0169|create a virtual environment using python3 -m venv path/to/venv.
0170|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0171|sure you have python3-full installed.
0172|If you wish to install a non-Debian packaged Python application,
0173|it may be easiest to use pipx install xyz, which will manage a
0174|virtual environment for you. Make sure you have pipx installed.
0175|See /usr/share/doc/python3.11/README.venv for more information.
0176|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0177|hint: See PEP 668 for the detailed specification.
0178|+ echo 17
0179|+ sudo pip3 install --force-reinstall --upgrade pyudev
0180|error: externally-managed-environment
0181|× This environment is externally managed
0182|╰─> To install Python packages system-wide, try apt install
0183|python3-xyz, where xyz is the package you are trying to
0184|install.
0185|If you wish to install a non-Debian-packaged Python package,
0186|create a virtual environment using python3 -m venv path/to/venv.
0187|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0188|sure you have python3-full installed.
0189|If you wish to install a non-Debian packaged Python application,
0190|it may be easiest to use pipx install xyz, which will manage a
0191|virtual environment for you. Make sure you have pipx installed.
0192|See /usr/share/doc/python3.11/README.venv for more information.
0193|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0194|hint: See PEP 668 for the detailed specification.
0195|+ echo 18
0196|+ sudo pip3 install --force-reinstall --upgrade pyserial
0197|error: externally-managed-environment
0198|× This environment is externally managed
0199|╰─> To install Python packages system-wide, try apt install
0200|python3-xyz, where xyz is the package you are trying to
0201|install.
0202|If you wish to install a non-Debian-packaged Python package,
0203|create a virtual environment using python3 -m venv path/to/venv.
0204|Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
0205|sure you have python3-full installed.
0206|If you wish to install a non-Debian packaged Python application,
0207|it may be easiest to use pipx install xyz, which will manage a
0208|virtual environment for you. Make sure you have pipx installed.
0209|See /usr/share/doc/python3.11/README.venv for more information.
0210|note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
0211|hint: See PEP 668 for the detailed specification.
0212|+ echo 19
0213|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
0214|+ rm /tmp/jeedom_install_in_progress_rfxcom
0215|+ echo '*******************End of package installation******************'
0216|*******************End of package installation******************
