Debian 12 : Using ${var} in strings is deprecated
Sur la version bêta du 2025-03-02 01:22:54 il y a plusieurs warnings PHP Deprecated :
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 425
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 427
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 462
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 463
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 464
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 465
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 466
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 479
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 540
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 544
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 655
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 693
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 1369
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 1406
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 1460
PHP Deprecated:  Using ${var} in strings is deprecated, use {$var} instead in /var/www/html/plugins/meteofrance/core/class/meteofrance.class.php on line 1562
J’ai bien compris comment corriger mais je ne sais pas faire de PR.
