VM debian 12 à jour
Core Alpha 4.4.2 à jour
Plugin Beta à jour
Je précise que ceci n’est que le résultat de ma reprise de test avec Debian 12
Que je n’aie pas les compétences pour juger de l’importance et des impacts de ces logs.
Je suis juste beta
testeur
Voici le log d’install des dépendances
+ touch /tmp/jeedom_install_in_progress_mqtt2
+ echo 1
+ echo 2
+ sudo apt update
sudo: unable to resolve host Wooperadeb12: Name or service not known
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x bookworm InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 3
lsb-release is already the newest version (12.0-1).
apt-utils is already the newest version (2.6.1).
git is already the newest version (1:2.39.2-1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[Check Version NodeJS actuelle : v18.19.0 : PHP Warning: PHP Startup: Unable to load dynamic library 'mosquitto.so' (tried: /usr/lib/php/20220829/mosquitto.so (/usr/lib/php/20220829/mosquitto.so: cannot open shared object file: No such file or directory), /usr/lib/php/20220829/mosquitto.so.so (/usr/lib/php/20220829/mosquitto.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
[ OK ]
[Check Prefix : /usr/local and sudo prefix : /usr/local and www-data prefix : /usr/local : [ OK ]
+ echo 4
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
[ OK ]
+ echo 5
[ OK ]
+ echo 6
+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
+ sudo /var/www/html/core/class/../../resources/install_composer.sh
Begin installation of composer
--2024-01-24 14:08:24-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 54.36.53.46, 2001:41d0:302:1100::8:104f
Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
HTTP request sent, awaiting response...
200 OK
Length: 58167 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 88% 2.06M 0s
50K ...... 100% 52.3M=0.02s
2024-01-24 14:08:25 (2.33 MB/s) - 'composer-setup.php' saved [58167/58167]
All settings correct for using Composer
Downloading...
Composer (version 2.6.6) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
+ echo 7
+ cd /var/www/html/core/class/../../plugins/mqtt2/resources/mqtt2d
+ rm -rf node_modules
+ sudo npm install
added 110 packages, and audited 111 packages in 3s
13 packages are looking for funding
run `npm fund` for details
2 moderate severity vulnerabilities
To address all issues, run:
npm audit fix
Run `npm audit` for details.
+ sudo chown -R www-data:www-data jeedom mqtt2d.js node_modules old_node_modules package-lock.json package.json
+ echo 8
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end mqtt2
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
+ rm /tmp/jeedom_install_in_progress_mqtt2
Pour le sudo: unable to resolve host Wooperadeb12: Name or service not known
je précise que depuis mon pc un ping vers cette adresse fonctionne. Même si je sais que le nom est pas académique
