VM debian 12 à jour
Core Alpha 4.4.2 à jour
Plugin Beta à jour
Je précise que ceci n’est que le résultat de ma reprise de test avec Debian 12
Que je n’aie pas les compétences pour juger de l’importance et des impacts de ces logs.
Je suis juste beta
testeur
Voici le log d’install des dépendances
+ touch /tmp/jeedom_install_in_progress_gsh
+ echo 1
+ echo 2
+ sudo apt update
sudo: unable to resolve host Wooperadeb12: Name or service not known
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x bookworm InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 3
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
lsb-release is already the newest version (12.0-1).
apt-utils is already the newest version (2.6.1).
git is already the newest version (1:2.39.2-1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[Check Version NodeJS actuelle : v18.19.0 : PHP Warning: PHP Startup: Unable to load dynamic library 'mosquitto.so' (tried: /usr/lib/php/20220829/mosquitto.so (/usr/lib/php/20220829/mosquitto.so: cannot open shared object file: No such file or directory), /usr/lib/php/20220829/mosquitto.so.so (/usr/lib/php/20220829/mosquitto.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
[ OK ]
[Check Prefix : /usr/local and sudo prefix : /usr/local and www-data prefix : /usr/local : [ OK ]
+ echo 4
Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
[ OK ]
+ echo 5
[ OK ]
+ echo 6
+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
+ sudo /var/www/html/core/class/../../resources/install_composer.sh
Begin installation of composer
--2024-01-24 14:04:17-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 54.36.53.46, 2001:41d0:302:1100::8:104f
Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58167 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 88% 6.19M 0s
50K ...... 100% 62.0M=0.008s
2024-01-24 14:04:17 (6.94 MB/s) - 'composer-setup.php' saved [58167/58167]
All settings correct for using Composer
Downloading...
Composer (version 2.6.6) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
+ echo 7
+ cd /var/www/html/core/class/../../plugins/gsh/resources/gshd
+ rm -rf node_modules
+ sudo npm install
added 65 packages, and audited 66 packages in 2s
4 vulnerabilities (2 moderate, 2 high)
To address all issues, run:
npm audit fix
Run `npm audit` for details.
+ sudo chown -R www-data:www-data gshd.js node_modules package-lock.json package.json server.ts tsconfig.json tslint.json types.d.ts
+ echo 8
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end gsh
+ rm /tmp/jeedom_install_in_progress_gsh
