Depuis mon passage en version Debian 12.7 (debian 11 avant avec le core en alpha 4.5) j’ai ce message dans mes logs. Il s’agit d’un chauffe eau pac de chez atlantic; Le plugin est en version beta 2024-05-25 16:11:24
Erreur sur cozytouch::cozyRefresh() : Unsupported operand types: string - int
Voici le log plus complet
4120|Vary: Origin
4121|Vary: Access-Control-Request-Method
4122|Vary: Access-Control-Request-Headers
4123|Set-Cookie: JSESSIONID=E2~738585B2AE80A8DE7852664B1178E121; Path=/enduser-mobile-web; Secure; HttpOnly; SameSite=None
4124|Cache-Control: no-cache, no-store, max-age=0, must-revalidate
4125|Pragma: no-cache
4126|Expires: 0
4127|Strict-Transport-Security: max-age=31536000 ; includeSubDomains
4128|X-XSS-Protection: 1; mode=block
4129|X-Frame-Options: DENY
4130|X-Content-Type-Options: nosniff
4131|Content-Type: application/json;charset=UTF-8
4132|Transfer-Encoding: chunked
4133|Date: Sat, 05 Oct 2024 13:18:01 GMT
4134|Server: overkiz
4135|{"success":true,"roles":[{"name":"ENDUSER"}]}
4136|[2024-10-05 15:18:02] DEBUG JSESSIONID ok
4137|[2024-10-05 15:18:02] DEBUG makeRequest function route : devices method : GET
4138|[2024-10-05 15:18:02] DEBUG call url : https://ha110-1.overkiz.com/enduser-mobile-web/enduserAPI/setup/devices
4139|[2024-10-05 15:18:02] DEBUG curl result : [{"creationTime":1643098041000,"lastUpdateTime":1643098041000,"label":"Box","deviceURL":"internal://2012-4786-1836/pod/0","shortcut":false,"controllableName":"internal:PodV3Component","definition":{"commands":[{"commandName":"getName","nparams":0},{"commandName":"update","nparams":0},{"commandName":"setCountryCode","nparams":1},{"commandName":"activateCalendar","nparams":0},{"commandName":"deactivateCalendar","nparams":0},{"commandName":"refreshPodMode","nparams":0},{"commandName":"refreshUpdateStatus","nparams":0},{"commandName":"setCalendar","nparams":1},{"commandName":"setLightingLedPodMode","nparams":1},{"commandName":"setPodLedOff","nparams":0},{"commandName":"setPodLedOn","nparams":0}],"states":[{"type":"DiscreteState","values":["offline","online"],"qualifiedName":"core:ConnectivityState"},{"type":"DataState","qualifiedName":"core:CountryCodeState"},{"eventBased":true,"type":"DataState","qualifiedName":"core:LocalAccessProofState"},{"type":"DataState","qualifiedName":"core:LocalIPv4AddressState"},{"type":"DataState","qualifiedName":"core:NameState"},{"eventBased":true,"type":"DiscreteState","values":["pressed","stop"],"qualifiedName":"internal:Button1State"},{"eventBased":true,"type":"DiscreteState","values":["pressed","stop"],"qualifiedName":"internal:Button2State"},{"eventBased":true,"type":"DiscreteState","values":["pressed","stop"],"qualifiedName":"internal:Button3State"},{"type":"ContinuousState","qualifiedName":"internal:LightingLedPodModeState"}],"dataProperties":[],"widgetName":"Pod","uiProfiles":["UpdatableComponent"],"uiClass":"Pod","qualifiedName":"internal:PodV3Component","type":"ACTUATOR"},"states":[{"name":"core:NameState","type":3,"value":"Box"},{"name":"internal:LightingLedPodModeState","type":2,"value":1.0},{"name":"core:CountryCodeState","type":3,"value":"FR"},{"name":"core:LocalIPv4AddressState","type":3,"value":"192.168.1.81"}],"available":true,"enabled":true,"placeOID":"553526a7-e52c-4854-8dec-4912ffdc1223","widget":"Pod","type":1,"oid":"1c5892b7-7967-4c8b-aced-8f66dc02e857","uiClass":"Pod"},{"creationTime":1643098041000,"lastUpdateTime":1643098041000,"label":"INTERNAL (wifi/0)","deviceURL":"internal://2012-4786-1836/wifi/0","shortcut":false,"controllableName":"internal:WifiComponent","definition":{"commands":[{"commandName":"clearCredentials","nparams":0},{"commandName":"setTargetInfraConfig","nparams":2},{"commandName":"setWifiMode","nparams":1}],"states":[{"type":"DataState","qualifiedName":"internal:CurrentInfraConfigState"},{"type":"ContinuousState","qualifiedName":"internal:SignalStrengthState"},{"type":"DataState","qualifiedName":"internal:WifiModeState"}],"dataProperties":[],"widgetName":"Wifi","uiProfiles":["Specific"],"uiClass":"Wifi","qualifiedName":"internal:WifiComponent","type":"ACTUATOR"},"states":[{"name":"internal:WifiModeState","type":3,"value":"infrastructure"},{"name":"internal:CurrentInfraConfigState","type":3,"value":"Livebox-DD30"},{"name":"internal:SignalStrengthState","type":1,"value":71}],"available":true,"enabled":true,"placeOID":"553526a7-e52c-4854-8dec-4912ffdc1223","widget":"Wifi","type":1,"oid":"1c509005-4ce7-4ad2-87f0-d38a2e6aaf35","uiClass":"Wifi"},{"creationTime":1643098864000,"lastUpdateTime":1643098864000,"label":"IO (12145086)","deviceURL":"io://2012-4786-1836/12145086","shortcut":false,"controllableName":"io:StackComponent","definition":{"commands":[{"commandName":"advancedSomfyDiscover","nparams":1},{"commandName":"discover1WayController","nparams":2},{"commandName":"discoverActuators","nparams":1},{"commandName":"discoverSensors","nparams":1},{"commandName":"discoverSomfyUnsetActuators","nparams":0},{"commandName":"joinNetwork","nparams":0},{"commandName":"resetNetworkSecurity","nparams":0},{"commandName":"shareNetwork","nparams":0}],"states":[],"dataProperties":[],"widgetName":"IOStack","uiProfiles":["Specific"],"uiClass":"ProtocolGateway","qualifiedName":"io:StackComponent","type":"PROTOCOL_GATEWAY"},"available":true,"enabled":true,"placeOID":"553526a7-e52c-4854-8dec-4912ffdc1223","widget":"IOStack","type":5,"oid":"6c89195e-8d65-44e9-84e2-af068a8f0a12","uiClass":"ProtocolGateway"},{"creationTime":1643098872000,"lastUpdateTime":1643098872000,"label":"DHWP Actuator","deviceURL":"io://2012-4786-1836/7905158#1","shortcut":false,"controllableName":"io:AtlanticDomesticHotWaterProductionV2_CETHI_V4_IOComponent","definition":{"commands":[{"commandName":"addLockLevel","nparams":2},{"commandName":"advancedRefresh","nparams":2},{"commandName":"delayedStopIdentify","nparams":1},{"commandName":"getName","nparams":0},{"commandName":"identify","nparams":0},{"commandName":"refreshManufacturerName","nparams":0},{"commandName":"refreshTargetTemperature","nparams":0},{"commandName":"refreshWaterConsumption","nparams":0},{"commandName":"removeLockLevel","nparams":1},{"commandName":"resetLockLevels","nparams":0},{"commandName":"setComfortTargetTemperature","nparams":1},{"commandName":"setDateTime","nparams":1},{"commandName":"setEcoTargetTemperature","nparams":1},{"commandName":"setFrostProtectionTargetTemperature","nparams":1},{"commandName":"setName","nparams":1},{"commandName":"setTargetTemperature","nparams":1},{"commandName":"startIdentify","nparams":0},{"commandName":"stopIdentify","nparams":0},{"commandName":"wink","nparams":1},{"commandName":"pairOneWayController","nparams":2},{"commandName":"refreshAntiLegionellosis","nparams":0},{"commandName":"refreshAwayModeDuration","nparams":0},{"commandName":"refreshBoilerInstallationOption","nparams":0},{"commandName":"refreshBoostModeDuration","nparams":0},{"commandName":"refreshCurrentOperatingMode","nparams":0},{"commandName":"refreshDHWCapacity","nparams":0},{"commandName":"refreshDHWError","nparams":0},{"commandName":"refreshDHWMode","nparams":0},{"commandName":"refreshElectricalExtraManagement","nparams":0},{"commandName":"refreshExtractionOption","nparams":0},{"commandName":"refreshInstallation","nparams":0},{"commandName":"refreshMiddleWaterTemperature","nparams":0},{"commandName":"refreshOperatingModeCapabilities","nparams":0},{"commandName":"refreshOperatingRange","nparams":0},{"commandName":"refreshOperatingTime","nparams":0},{"commandName":"refreshProgrammingSlots","nparams":0},{"commandName":"refreshRateManagement","nparams":0},{"commandName":"refreshSmartGridOption","nparams":0},{"commandName":"setAntiLegionellosis","nparams":1},{"commandName":"setAwayModeDuration","nparams":1},{"commandName":"setBoilerInstallationOption","nparams":1},{"commandName":"setBoostModeDuration","nparams":1},{"commandName":"setCurrentOperatingMode","nparams":1},{"commandName":"setDHWMode","nparams":1},{"commandName":"setElectricalExtraManagement","nparams":1},{"commandName":"setExtractionOption","nparams":1},{"commandName":"setHaltedTargetTemperature","nparams":1},{"commandName":"setInstallation","nparams":1},{"commandName":"setOperatingRange","nparams":1},{"commandName":"setProgrammingSlots","nparams":1},{"commandName":"setRateManagement","nparams":1},{"commandName":"setSmartGridOption","nparams":1},{"commandName":"unpairAllOneWayControllers","nparams":0},{"commandName":"unpairOneWayController","nparams":2}],"states":[{"type":"ContinuousState","qualifiedName":"core:BoostModeDurationState"},{"type":"ContinuousState","qualifiedName":"core:ComfortTargetTemperatureState"},{"eventBased":true,"type":"DataState","qualifiedName":"core:CommandLockLevelsState"},{"type":"ContinuousState","qualifiedName":"core:DHWPSoftwareVersionState"},{"type":"DataState","qualifiedName":"core:DateTimeState"},{"type":"DiscreteState","values":["good","low","normal","verylow"],"qualifiedName":"core:DiscreteRSSILevelState"},{"type":"ContinuousState","qualifiedName":"core:EcoTargetTemperatureState"},{"type":"ContinuousState","qualifiedName":"core:FrostProtectionTargetTemperatureState"},{"type":"ContinuousState","qualifiedName":"core:HaltedTargetTemperatureState"},{"type":"DataState","qualifiedName":"core:ManufacturerNameState"},{"type":"ContinuousState","qualifiedName":"core:MaximalShowerManualModeState"},{"type":"ContinuousState","qualifiedName":"core:MaximalTemperatureManualModeState"},{"type":"ContinuousState","qualifiedName":"core:MinimalShowerManualModeState"},{"type":"ContinuousState","qualifiedName":"core:MinimalTemperatureManualModeState"},{"type":"DataState","qualifiedName":"core:NameState"},{"type":"ContinuousState","qualifiedName":"core:NumberOfTankState"},{"type":"DiscreteState","values":["antifreeze","auto","away","eco","frostprotection","manual","max","normal","off","on","prog","program","boost"],"qualifiedName":"core:OperatingModeState"},{"type":"ContinuousState","qualifiedName":"core:PriorityLockTimerState"},{"type":"ContinuousState","qualifiedName":"core:RSSILevelState"},{"type":"ContinuousState","qualifiedName":"core:SecuredPositionTemperatureState"},{"type":"DiscreteState","values":["available","unavailable"],"qualifiedName":"core:StatusState"},{"type":"ContinuousState","qualifiedName":"core:TargetTemperatureState"},{"type":"ContinuousState","qualifiedName":"core:TemperatureState"},{"type":"DataState","qualifiedName":"core:V40WaterVolumeEstimationState"},{"type":"ContinuousState","qualifiedName":"core:VersionState"},{"type":"ContinuousState","qualifiedName":"core:WaterConsumptionState"},{"type":"ContinuousState","qualifiedName":"io:AntiLegionellosisState"},{"type":"ContinuousState","qualifiedName":"io:AwayModeDurationState"},{"type":"DiscreteState","values":["boilerOptimising","boilerPriority","heatPumpOptimising","heatPumpPriority"],"qualifiedName":"io:BoilerInstallationOptionState"},{"type":"ContinuousState","qualifiedName":"io:DHWCapacityState"},{"type":"DataState","qualifiedName":"io:DHWErrorState"},{"type":"DiscreteState","values":["autoMode","manualEcoActive","manualEcoInactive"],"qualifiedName":"io:DHWModeState"},{"type":"ContinuousState","qualifiedName":"io:ElectricBoosterOperatingTimeState"},{"type":"DiscreteState","values":["auto","deactive"],"qualifiedName":"io:ElectricalExtraManagementState"},{"type":"DiscreteState","values":["fastExtractionSpeed","lowExtractionSpeed","noExtraction"],"qualifiedName":"io:ExtractionOptionState"},{"type":"ContinuousState","qualifiedName":"io:HeatPumpOperatingTimeState"},{"type":"DiscreteState","values":["extraBoiler","extraSolar","onlyThermodynamic"],"qualifiedName":"io:InstallationState"},{"type":"ContinuousState","qualifiedName":"io:MiddleWaterTemperatureState"},{"type":"DataState","qualifiedName":"io:OperatingModeCapabilitiesState"},{"type":"DiscreteState","values":["pac24h_elec24h","pacProg_elecProg"],"qualifiedName":"io:OperatingRangeState"},{"type":"DataState","qualifiedName":"io:PowerConsumptionFanState"},{"type":"DataState","qualifiedName":"io:PowerHeatElectricalState"},{"type":"DataState","qualifiedName":"io:PowerHeatPumpState"},{"type":"DiscreteState","values":["comfortLevel1","comfortLevel2","comfortLevel3","comfortLevel4","environmentProtection","humanProtection","userLevel1","userLevel2"],"qualifiedName":"io:PriorityLockLevelState"},{"type":"DiscreteState","values":["LSC","SAAC","SFC","UPS","externalGateway","localUser","myself","rain","security","temperature","timer","user","wind"],"qualifiedName":"io:PriorityLockOriginatorState"},{"type":"DataState","qualifiedName":"io:ProgrammingSlotsState"},{"type":"DiscreteState","values":["forbidden","no","recommended","unsuitable","wanted"],"qualifiedName":"io:RateManagementState"},{"type":"DiscreteState","values":["active","deactive"],"qualifiedName":"io:SmartGridOptionState"}],"dataProperties":[{"value":"500","qualifiedName":"core:identifyInterval"}],"widgetName":"DomesticHotWaterProduction","uiProfiles":["StatefulThermostatWithSensor","StatefulThermostat","Thermostat","WaterConsumption"],"uiClass":"WaterHeatingSystem","qualifiedName":"io:AtlanticDomesticHotWaterProductionV2_CETHI_V4_IOComponent","type":"ACTUATOR"},"states":[{"name":"core:NameState","type":3,"value":"DHWP Actuator"},{"name":"core:VersionState","type":3,"value":"45373232383034202020"},{"name":"core:PriorityLockTimerState","type":1,"value":0},{"name":"core:CommandLockLevelsState","type":3,"value":"[]","lastUpdateTime":1725014036000},{"name":"core:StatusState","type":3,"value":"available"},{"name":"core:DiscreteRSSILevelState","type":3,"value":"good"},{"name":"core:RSSILevelState","type":2,"value":98.0},{"name":"io:RateManagementState","type":3,"value":"?"},{"name":"io:OperatingModeCapabilitiesState","type":11,"value":{"relaunch":1,"absence":1,"rateManagement":0,"energyDemandStatus":0}},{"name":"core:OperatingModeState","type":11,"value":{"relaunch":"off","absence":"off"}},{"name":"io:DHWErrorState","type":11,"value":{"code":255,"minor":255,"family":"W","type":0}},{"name":"io:HeatPumpOperatingTimeState","type":1,"value":2244},{"name":"io:ElectricBoosterOperatingTimeState","type":1,"value":12},{"name":"io:DHWModeState","type":3,"value":"autoMode"},{"name":"core:TemperatureState","type":2,"value":40.0},{"name":"io:OperatingRangeState","type":3,"value":"pac24h_elec24h"},{"name":"io:ProgrammingSlotsState","type":11,"value":{"slot2":{"start":"12:00","end":"16:00"},"slot1":{"start":"22:00","end":"06:00"}}},{"name":"io:AntiLegionellosisState","type":1,"value":2},{"name":"io:ElectricalExtraManagementState","type":3,"value":"deactive"},{"name":"io:SmartGridOptionState","type":3,"value":"deactive"},{"name":"io:MiddleWaterTemperatureState","type":2,"value":56.4},{"name":"core:V40WaterVolumeEstimationState","type":1,"value":3716},{"name":"io:PowerHeatElectricalState","type":1,"value":23182},{"name":"io:PowerHeatPumpState","type":1,"value":18914},{"name":"core:DateTimeState","type":11,"value":{"month":10,"hour":19,"year":2024,"weekday":4,"day":4,"minute":51,"second":44}},{"name":"core:BoostModeDurationState","type":1,"value":0},{"name":"io:AwayModeDurationState","type":3,"value":"0"},{"name":"core:ManufacturerNameState","type":3,"value":"Atlantic"},{"name":"io:DHWCapacityState","type":1,"value":250}],"attributes":[{"name":"core:FirmwareRevision","type":3,"value":"E722804"},{"name":"core:Manufacturer","type":3,"value":"Atlantic Group"}],"available":true,"enabled":true,"placeOID":"553526a7-e52c-4854-8dec-4912ffdc1223","widget":"DomesticHotWaterProduction","type":1,"oid":"b90885f5-a8a6-4fe3-9f03-1f53c9195de6","uiClass":"WaterHeatingSystem"},{"creationTime":1643098872000,"lastUpdateTime":1643098872000,"label":"IO (7905158#2)","deviceURL":"io://2012-4786-1836/7905158#2","shortcut":false,"controllableName":"io:DHWCumulatedElectricalEnergyConsumptionIOSystemDeviceSensor","definition":{"commands":[{"commandName":"refreshElectricEnergyConsumption","nparams":0}],"states":[{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff0State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff1State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff2State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff3State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff4State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff5State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff6State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff7State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff8State"},{"type":"ContinuousState","qualifiedName":"core:ConsumptionTariff9State"},{"type":"ContinuousState","qualifiedName":"core:ElectricEnergyConsumptionState"},{"type":"DiscreteState","values":["available","unavailable"],"qualifiedName":"core:StatusState"}],"dataProperties":[],"widgetName":"CumulativeElectricPowerConsumptionSensor","uiProfiles":["ElectricEnergyConsumption"],"uiClass":"ElectricitySensor","qualifiedName":"io:DHWCumulatedElectricalEnergyConsumptionIOSystemDeviceSensor","type":"SENSOR"},"states":[{"name":"core:StatusState","type":3,"value":"available"},{"name":"core:ElectricEnergyConsumptionState","type":1,"value":1090672},{"name":"core:ConsumptionTariff0State","type":1,"value":1070616}],"attributes":[{"name":"core:FirmwareRevision","type":3,"value":"E722804"},{"name":"core:Manufacturer","type":3,"value":"Atlantic Group"},{"name":"core:PowerSourceType","type":3,"value":"mainSupply"},{"name":"core:MeasuredValueType","type":3,"value":"core:ElectricalEnergyInWh"}],"available":true,"enabled":true,"placeOID":"553526a7-e52c-4854-8dec-4912ffdc1223","widget":"CumulativeElectricPowerConsumptionSensor","type":2,"oid":"5537221c-d19e-48e9-be0f-016e208ff94b","uiClass":"ElectricitySensor"},{"creationTime":1643098041000,"lastUpdateTime":1643098041000,"label":"ZIGBEE (65535)","deviceURL":"zigbee://2012-4786-1836/65535","shortcut":false,"controllableName":"zigbee:TransceiverV3_0Component","definition":{"commands":[],"states":[],"dataProperties":[],"widgetName":"ZigbeeStack","uiProfiles":["Specific"],"uiClass":"ProtocolGateway","qualifiedName":"zigbee:TransceiverV3_0Component","type":"PROTOCOL_GATEWAY"},"available":true,"enabled":true,"placeOID":"553526a7-e52c-4854-8dec-4912ffdc1223","widget":"ZigbeeStack","type":5,"oid":"e6e2d837-daa9-4319-96fa-ac086c47bcf7","uiClass":"ProtocolGateway"}]
4140|[2024-10-05 15:18:02] DEBUG Ope mode info : {"relaunch":1,"absence":1,"rateManagement":0,"energyDemandStatus":0}
4141|[2024-10-05 15:18:02] DEBUG Refresh info : b90885f5-a8a6-4fe3-9f03-1f53c9195de6
4142|[2024-10-05 15:18:02] DEBUG Refresh is heating
4143|[2024-10-05 15:18:02] DEBUG Refresh is heating
4144|[2024-10-05 15:18:02] DEBUG Heating : 0
4145|[2024-10-05 15:18:02] DEBUG Refresh boost
4146|[2024-10-05 15:18:02] DEBUG Boost : 0(0)
4147|[2024-10-05 15:18:02] DEBUG Calcul proportion d eau chaude
4148|[2024-10-05 15:18:02] ERROR Erreur sur cozytouch::cozyRefresh() : Unsupported operand types: string - int
Le cron en erreur
