Debian 12- Alpha 4.4 - erreur composer apres update
Sur mon alpha 4.4 en deb12, j’ai juste fait mise à jour ce matin… depuis l’install je n’avais pas testé.
La mise a jour s’est faite mais j’ai ca dans le log http.error
0000|[Tue Sep 05 08:18:43.404528 2023] [php:warn] [pid 825] [client 192.168.1.250:59208] PHP Warning:  require(/var/www/html/vendor/symfony/polyfill-intl-normalizer/bootstrap.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0001|[Tue Sep 05 08:18:43.404616 2023] [php:error] [pid 825] [client 192.168.1.250:59208] PHP Fatal error:  Uncaught Error: Failed opening required '/var/www/html/vendor/composer/../symfony/polyfill-intl-normalizer/bootstrap.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php:71\nStack trace:\n#0 /var/www/html/vendor/composer/autoload_real.php(61): composerRequire5a0c414efab2298f121e5cbed8bbcba9()\n#1 /var/www/html/vendor/autoload.php(7): ComposerAutoloaderInit5a0c414efab2298f121e5cbed8bbcba9::getLoader()\n#2 /var/www/html/core/php/core.inc.php(19): require_once('...')\n#3 /var/www/html/core/ajax/log.ajax.php(20): require_once('...')\n#4 {main}\n  thrown in /var/www/html/vendor/composer/autoload_real.php on line 71
0002|[Tue Sep 05 08:18:44.398489 2023] [php:warn] [pid 2705] [client 192.168.1.250:59215] PHP Warning:  require(/var/www/html/vendor/composer/../symfony/polyfill-php70/bootstrap.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0003|[Tue Sep 05 08:18:44.398550 2023] [php:error] [pid 2705] [client 192.168.1.250:59215] PHP Fatal error:  Uncaught Error: Failed opening required '/var/www/html/vendor/composer/../symfony/polyfill-php70/bootstrap.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php:71\nStack trace:\n#0 /var/www/html/vendor/composer/autoload_real.php(61): composerRequire5a0c414efab2298f121e5cbed8bbcba9()\n#1 /var/www/html/vendor/autoload.php(7): ComposerAutoloaderInit5a0c414efab2298f121e5cbed8bbcba9::getLoader()\n#2 /var/www/html/core/php/core.inc.php(19): require_once('...')\n#3 /var/www/html/core/ajax/log.ajax.php(20): require_once('...')\n#4 {main}\n  thrown in /var/www/html/vendor/composer/autoload_real.php on line 71
0004|[Tue Sep 05 08:18:45.406388 2023] [php:warn] [pid 1225] [client 192.168.1.250:59216] PHP Warning:  require(/var/www/html/vendor/composer/../symfony/polyfill-php70/bootstrap.php): Failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0005|[Tue Sep 05 08:18:45.406454 2023] [php:error] [pid 1225] [client 192.168.1.250:59216] PHP Fatal error:  Uncaught Error: Failed opening required '/var/www/html/vendor/composer/../symfony/polyfill-php70/bootstrap.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php:71\nStack trace:\n#0 /var/www/html/vendor/composer/autoload_real.php(61): composerRequire5a0c414efab2298f121e5cbed8bbcba9()\n#1 /var/www/html/vendor/autoload.php(7): ComposerAutoloaderInit5a0c414efab2298f121e5cbed8bbcba9::getLoader()\n#2 /var/www/html/core/php/core.inc.php(19): require_once('...')\n#3 /var/www/html/core/ajax/log.ajax.php(20): require_once('...')\n#4 {main}\n  thrown in /var/www/html/vendor/composer/autoload_real.php on line 71
Normalement cette erreur arrive pendant la mise à jour c’est normal.
