Debian 12.5 Jeedom Alpha 4.4.2 plugin XiaomiHome beta - > DEMON NOK
DEbian 12.5 fresh install sur VMM Synology
Jeedom Alpha 4.4.2
Le demon reste sur NOK
+ touch /tmp/jeedom_install_in_progress_xiaomihome
+ echo 1
+ echo 2
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://ftp.fr.debian.org/debian bookworm InRelease
Hit:3 http://ftp.fr.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_16.x bookworm InRelease
Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ sudo apt install -y pipx
pipx is already the newest version (1.1.0-1).
The following package was automatically installed and is no longer required:
libre2-9
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 3
+ sudo pipx install --force-reinstall --upgrade pyudev
usage: pipx [-h] [--version]
{install,inject,upgrade,upgrade-all,uninstall,uninstall-all,reinstall,reinstall-all,list,run,runpip,ensurepath,environment,completions}
pipx: error: unrecognized arguments: --force-reinstall --upgrade
+ echo 4
+ sudo pipx install --force-reinstall --upgrade construct
+ echo 5
+ sudo pipx install --force-reinstall --upgrade requests
+ echo 6
+ sudo pipx install --force-reinstall --upgrade pyserial
+ echo 7
+ sudo pipx install --force-reinstall --upgrade future
+ echo 8
+ sudo pipx install --force-reinstall --upgrade pycrypto
+ echo 9
+ sudo pipx install --force-reinstall --upgrade cryptography
+ echo 10
+ sudo pipx install --force-reinstall --upgrade enum34
+ echo 11
+ sudo pipx install --force-reinstall --upgrade enum-compat
+ echo 12
+ sudo pipx install --force-reinstall --upgrade wheel
+ echo 13
+ sudo pipx install --force-reinstall --upgrade yeelight
+ echo 14
+ sudo pipx install --force-reinstall --upgrade python-miio
+ echo 15
+ sudo apt update
+ echo 16
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-cryptography
python3-cryptography is already the newest version (38.0.4-3).
libre2-9
+ echo 17
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libffi-dev
libffi-dev is already the newest version (3.4.4-1).
libre2-9
+ echo 18
+ sudo apt install -o Dpkg::Options::=--force-confdef -y libssl-dev
libssl-dev is already the newest version (3.0.11-1~deb12u2).
libre2-9
+ echo 19
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end xiaomihome
+ rm /tmp/jeedom_install_in_progress_xiaomihome
Une idée ? pipx ?
je viens tout juste de tomber sur ton message.
Perso je n’ai pas encore réussi à trouver une solution une solution pour ce souci lié à Python qui oblige désormais à se lancer dans une environnement virtuel sous Debian 12.X
J’avais tenté pipx mais ça ne marchait pas et le démon ne démarrait (plugin geckospa).
j’ai lu quelque part que l’équipe Jeedom se penchait sur le problème au niveau du Core donc je vais attendre des infos de leur part.
Perso j’ai abandonné l’idée de Debian 12 pour l’instant et je suis passé de Jeedom 4.3.23 en Debian 10 à 4.4.2 sous Debian 11.9
Lionel
Oui la version à utiliser pour l’instant est debian11.
Le support de debian 12 est expérimental dans le sens où même lorsque le core le permettra pour les démons python (ce qui va arriver), il faudra laisser le temps aux plugins d’être mis à jour et ça dépendra des devs de chaque plugin.
Donc faut pas y compter avant plusieurs mois je pense.
LE plugin Xiami Home est maintenant fonctionnel sur les dernieres versions core/plugin.
Merci on peut fermer
