Je suis un boulet, je viens de voir qu’il y a un autre fichier de log plus parlant :
[2023-05-16 21:06:24][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:48930]
[2023-05-16 21:06:24][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "action", "device": {"uuid": "89f02922-8bab-d6aa-e02b-9c556d984198", "source": "googlecast"}, "command": [{"cmd": "tts", "value": "Ceci est un test", "vol": "90"}]}
[2023-05-16 21:06:24][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:48930]
[2023-05-16 21:06:25][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-05-16 21:06:25][DEBUG] : SOCKET-READ------Received command from jeedom : action
[2023-05-16 21:06:25][DEBUG] : SOCKET-READ------Attempt an action on a device
[2023-05-16 21:06:25][DEBUG] : SOCKET-READ------Action Thread Launched
[2023-05-16 21:06:25][DEBUG] : ACTION------ action - tts - 89f02922-8bab-d6aa-e02b-9c556d984198 - Ceci est un test - none
[2023-05-16 21:06:25][DEBUG] : ACTION------TTS action
[2023-05-16 21:06:25][DEBUG] : CMD-TTS------TTS Filename hexdigest : 189d4f100dc15ca5dbecb9caff05ee97 (Ceci est un testjeedomttsfr-FR300)
[2023-05-16 21:06:25][DEBUG] : CMD-TTS------Generating file
[2023-05-16 21:06:25][DEBUG] : SENDER------PROXYTTS Using Proxy tts request to jeedom server for jeedomtts engine.
[2023-05-16 21:06:25][ERROR] : CMD-TTS------Exception while generating tts file : Decoding failed. ffmpeg returned error code: 1
Output from ffmpeg/avlib:
b'ffmpeg version 4.3.6-0+deb11u1 Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 10 (Debian 10.2.1-6)
configuration: --prefix=/usr --extra-version=0+deb11u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
WARNING: library configuration mismatch
avcodec configuration: --prefix=/usr --extra-version=0+deb11u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --enable-version3 --disable-doc --disable-programs --enable-libaribb24 --enable-liblensfun --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[mp3 @ 0x55c1984a7680] Failed to read frame size: Could not seek to 1075.
/var/www/html/plugins/googlecast/tmp/189d4f100dc15ca5dbecb9caff05ee97.mp3: Invalid argument
[2023-05-16 21:06:25][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 1719, in get_tts_data
speech = AudioSegment.from_mp3(filenamemp3)
File "/var/www/html/plugins/googlecast/resources/pydub/audio_segment.py", line 728, in from_mp3
return cls.from_file(file, 'mp3', parameters=parameters)
File "/var/www/html/plugins/googlecast/resources/pydub/audio_segment.py", line 713, in from_file
raise CouldntDecodeError(
pydub.exceptions.CouldntDecodeError: Decoding failed. ffmpeg returned error code: 1
[2023-05-16 21:06:25][DEBUG] : TTS------File generation failed !
[2023-05-16 21:06:25][DEBUG] : ACTION------SET VOLUME OPTION
[2023-05-16 21:06:25][DEBUG] : SENDER------Send to jeedom : {'uuid': '89f02922-8bab-d6aa-e02b-9c556d984198', 'nowplaying': {'uuid': '89f02922-8bab-d6aa-e02b-9c556d984198', 'online': True, 'is_active_input': False, 'is_stand_by': False, 'display_name': 'ERROR', 'status_text': 'ERROR', 'player_state': 'ERROR', 'title': '', 'album_artist': '', 'album_name': '', 'current_time': 0, 'artist': '', 'image': None, 'series_title': '', 'season': '', 'episode': '', 'stream_type': '', 'track': ''}}
[2023-05-16 21:06:25][DEBUG] : JEEDOMCHROMECAST------ Detected changes in status of Google Home Mini
[2023-05-16 21:06:25][DEBUG] : SENDER------Send to jeedom : {'uuid': '89f02922-8bab-d6aa-e02b-9c556d984198', 'nowplaying': {'uuid': '89f02922-8bab-d6aa-e02b-9c556d984198', 'online': True, 'friendly_name': 'Google Home Mini', 'is_active_input': False, 'is_stand_by': False, 'volume_level': 89, 'volume_muted': False, 'app_id': None, 'icon_url': None, 'display_name': '', 'status_text': ' ', 'is_busy': False, 'title': None, 'album_artist': None, 'metadata_type': None, 'album_name': None, 'current_time': '0', 'artist': None, 'series_title': None, 'season': None, 'episode': None, 'image': None, 'stream_type': 'UNKNOWN', 'track': None, 'player_state': 'UNKNOWN', 'supported_media_commands': 0, 'supports_pause': False, 'duration': None, 'content_type': None, 'idle_reason': None}}
[2023-05-16 21:06:25][DEBUG] : JEEDOMCHROMECAST------ Detected changes in status of Maison
[2023-05-16 21:06:25][DEBUG] : SENDER------Send to jeedom : {'uuid': 'f4e3a4fc-cdca-43e0-9cf1-f898a1260a1b', 'nowplaying': {'uuid': 'f4e3a4fc-cdca-43e0-9cf1-f898a1260a1b', 'online': True, 'friendly_name': 'Maison', 'is_active_input': False, 'is_stand_by': False, 'volume_level': 46, 'volume_muted': False, 'app_id': None, 'icon_url': None, 'display_name': '', 'status_text': ' ', 'is_busy': False, 'title': None, 'album_artist': None, 'metadata_type': None, 'album_name': None, 'current_time': '0', 'artist': None, 'series_title': None, 'season': None, 'episode': None, 'image': None, 'stream_type': 'UNKNOWN', 'track': None, 'player_state': 'UNKNOWN', 'supported_media_commands': 0, 'supports_pause': False, 'duration': None, 'content_type': None, 'idle_reason': None}}
[2023-05-16 21:06:25][DEBUG] : SENDER------Send to jeedom : {'devices': {'89f02922-8bab-d6aa-e02b-9c556d984198': {'uuid': '89f02922-8bab-d6aa-e02b-9c556d984198', 'typemsg': 'info', 'status': {'uuid': '89f02922-8bab-d6aa-e02b-9c556d984198', 'display_name': '', 'status_text': ' ', 'uri': '192.168.1.56:8009', 'friendly_name': 'Google Home Mini', 'is_active_input': False, 'is_stand_by': False, 'volume_level': 89, 'volume_muted': False, 'app_id': None, 'icon_url': None, 'is_busy': False, 'title': '', 'artist': '', 'series_title': '', 'stream_type': 'UNKNOWN', 'player_state': 'UNKNOWN'}, 'lastOnline': 1684260099, 'online': True, 'lastSent': 1684263985, 'lastOfflineSent': 0, 'options': {'ignore_CEC': '0'}, 'lastScan': 1684263928}, 'f4e3a4fc-cdca-43e0-9cf1-f898a1260a1b': {'uuid': 'f4e3a4fc-cdca-43e0-9cf1-f898a1260a1b', 'status': {'uuid': 'f4e3a4fc-cdca-43e0-9cf1-f898a1260a1b', 'uri': '192.168.1.56:32236', 'friendly_name': 'Maison', 'is_active_input': False, 'is_stand_by': False, 'volume_level': 46, 'volume_muted': False, 'app_id': None, 'icon_url': None, 'display_name': '', 'status_text': ' ', 'is_busy': False, 'title': '', 'artist': '', 'series_title': '', 'stream_type': 'UNKNOWN', 'player_state': 'UNKNOWN'}, 'typemsg': 'info', 'lastOnline': 1684260101, 'online': True, 'lastSent': 1684263985, 'lastOfflineSent': 0, 'options': {'ignore_CEC': '0'}, 'lastScan': 1684263928}}}
[2023-05-16 21:06:30][DEBUG] : SCANNER------ Start scanning... (schedule)
[2023-05-16 21:06:30][DEBUG] : MEMORY---- Total CPU time used : 7.195s (0.18%) | Last 62 sec : 0.141s (0.23%) | Memory : 51 Mo
[2023-05-16 21:07:12][DEBUG] : ZEROCONF------ Signal detected from chromecast on zeroconf network : Freebox Player POP
[2023-05-16 21:07:12][DEBUG] : ZEROCONF------ Signal from chromecast will be processed soon (Freebox Player POP)
[2023-05-16 21:07:13][DEBUG] : ZEROCONF------ Signal detected from chromecast on zeroconf network : Freebox Player POP
[2023-05-16 21:07:13][DEBUG] : ZEROCONF------ Signal from chromecast will be processed soon (Freebox Player POP)
[2023-05-16 21:07:14][DEBUG] : SCANNER------ Start scanning... (schedule)
[2023-05-16 21:07:14][DEBUG] : MEMORY---- Total CPU time used : 7.286s (0.19%) | Last 44 sec : 0.091s (0.21%) | Memory : 51 Mo
[2023-05-16 21:08:16][DEBUG] : SCANNER------ Start scanning... (schedule)
[2023-05-16 21:08:16][DEBUG] : MEMORY---- Total CPU time used : 7.384s (0.18%) | Last 62 sec : 0.098s (0.16%) | Memory : 51 Mo
Visiblement, il y aurait un problème pour la génération du fichier.
