je viens demandé a l’aide car je pense a la suite d’une maj je ne parviens plus a faire fonctionner mon plugin z2m… je ne sais pas quoi faire…
voici ce que j’ai:
+ touch /tmp/jeedom_install_in_progress_z2m
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
Launch pre-install of z2m dependancy
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
apt: no process found
apt-get: no process found
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
apt-utils is already the newest version (1.8.2.3).
build-essential is already the newest version (12.6).
git is already the newest version (1:2.20.1-2+deb10u8).
lsb-release is already the newest version (10.2019051400+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[Check Version NodeJS actuelle : v18.20.2 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
--2024-04-15 21:58:51-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 2001:41d0:302:1100::8:104f, 54.36.53.46
Connecting to getcomposer.org (getcomposer.org)|2001:41d0:302:1100::8:104f|:443... failed: Network is unreachable.
Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58444 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 87% 2.62M 0s
50K ....... 100% 34.6M=0.02s
2024-04-15 21:58:52 (2.95 MB/s) - 'composer-setup.php' saved [58444/58444]
Begin installation of composer
All settings correct for using Composer
Downloading...
Composer (version 2.7.2) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
added 115 packages in 4s
18 packages are looking for funding
run `npm fund` for details
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
+ echo 4
+ sudo apt update
+ echo 5
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
php-yaml is already the newest version (2.0.2+1.3.1-4+b1).
+ echo 7
+ sudo systemctl restart apache2
+ echo 8
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ echo Launch post-install of z2m dependancy
+ realpath /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ dirname /var/www/html/plugins/z2m/resources/post-install.sh
+ BASEDIR=/var/www/html/plugins/z2m/resources
+ [ -d /var/www/html/plugins/z2m/resources/zigbee2mqtt ]
+ mkdir /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /var/www/html/plugins/z2m/resources/zigbee2mqtt
Cloning into '/var/www/html/plugins/z2m/resources/zigbee2mqtt'...
+ cd /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ [ -f /var/www/html/plugins/z2m/resources/../data/wanted_z2m_version ]
+ npm ci
npm ERR! code ENETUNREACH
npm ERR! syscall connect
npm ERR! errno ENETUNREACH
npm ERR! request to https://registry.npmjs.org/zigbee2mqtt-frontend/-/zigbee2mqtt-frontend-0.6.161.tgz failed, reason: connect ENETUNREACH 2606:4700::6810:1a22:443
npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-04-15T19_59_30_136Z-debug-0.log
+ npm run build
> zigbee2mqtt@1.36.1 build
> tsc && node index.js writehash
sh: 1: tsc: not found
+ chown www-data:www-data -R /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ echo 9
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end z2m
PHP Warning: yaml_parse_file(/var/www/html/plugins/z2m/core/class/../../data/configuration.yaml): failed to open stream: No such file or directory in /var/www/html/plugins/z2m/core/class/z2m.class.php on line 212
+ echo 10
+ rm /tmp/jeedom_install_in_progress_z2m
> zigbee2mqtt@1.36.1 start
> node index.js
node:internal/modules/cjs/loader:1143
throw err;
Error: Cannot find module 'semver'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js
at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
at Module._load (node:internal/modules/cjs/loader:981:27)
at Module.require (node:internal/modules/cjs/loader:1231:19)
at require (node:internal/modules/helpers:177:18)
at Object.<anonymous> (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:1:16)
at Module._compile (node:internal/modules/cjs/loader:1364:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
at Module.load (node:internal/modules/cjs/loader:1203:32)
at Module._load (node:internal/modules/cjs/loader:1019:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
code: 'MODULE_NOT_FOUND',
requireStack: [ '/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js' ]
Node.js v18.20.2
Bon j’ai refait mon install sur debian 11 n’ayant meme pas fait attention a ce point depuis le temps que mon jeedom tourne sans aucun problème… mais rien de plus maintenant c’est plutôt du coté de MQTT Manager que ca coince
+ touch /tmp/jeedom_install_in_progress_mqtt2
+ echo 1
+ echo 2
+ sudo apt update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
+ echo 3
Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
apt-utils is already the newest version (2.2.4).
git is already the newest version (1:2.30.2-1+deb11u2).
lsb-release is already the newest version (11.1.0).
+ echo 4
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
+ echo 5
+ echo 6
+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
+ sudo /var/www/html/core/class/../../resources/install_composer.sh
--2024-04-21 23:01:56-- https://getcomposer.org/installer
0K .......... .......... .......... .......... .......... 87% 2.66M 0s
50K ....... 100% 33.4M=0.02s
2024-04-21 23:01:56 (3.00 MB/s) - 'composer-setup.php' saved [58444/58444]
Downloading...
Composer (version 2.7.3) successfully installed to: /var/www/html/core/ajax/composer.phar
+ echo 7
+ cd /var/www/html/core/class/../../plugins/mqtt2/resources/mqtt2d
+ rm -rf node_modules
+ sudo npm install
Concernant MQTT je vois que tu as maintenant 2 erreurs pour JeeZigbee. Si les dépendances sont KO sur JeeZigbee ça impact le plugin MQTT, en tout cas chez moi c’est le cas. Une fois les dépendances installées, il est passé au vert.
Pour ce genre de problème il faut poster les logs en particulier les démons sans ça vous dire d’où vient le soucis et trouver le bon c’est autant de chance que de gagner au loto (et pour le moment je fais que perdre…)
Bonjour, si c’est en réponse à mon commentaire, c’était simplement pour indiquer que j’ai un problème similaire. Je ne voulais pas polluer l’échange avec mes logs vu que j’ai un ticket ouvert auprès de l’assistance Jeedom. Ce que je peux dire c’est que j’ai une erreur similaire dans z2m « Error: Cannot find module ‹ semver › ».
Personnellement pour l’instant pas de piste, je vais surement tenter le passage à debian 11.
Bonne journée.
C’est pour tout le monde, si quand vous avez un soucis de ce type vous postez les logs des dépendances et du démon en general si je passe et que je vois le poste vous avez une réponse rapidement. Si il manque des infos je commence a prendre l’habitude d’aller voir les autres poste du community ou tout est complet.
Pour information, je viens de recevoir une MAJ du plugin JeedomZeegbee. Après son installation, puis réinstallation de dépendance et relance du demon l’accès à ma clé Conbee II est ok !
Changelog :
22/04/2024
Correction d’un bug sur duplication de commande (sur les scenes)
Correction d’un bug sur les slider avec valeur negative
est ce que cela convient ? ce que j’ai quand je relance le demon de JeeZigbee
je n’ai aucune explication mais effectivement coté MQTT Manager depuis la MAJ de JeeZigbee tout semble bon …
en tout cas merci d’avance pour l’aide
> node index.js
throw err;
Error: Cannot find module 'rimraf'
Require stack:
at Object.<anonymous> (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:7:22)
Node.js v18.20.2
[2024-04-24 20:00:05] ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-04-24 20:00:05] INFO : Arrêt du démon z2m
[2024-04-24 20:00:07] INFO : Démarrage du démon Z2M : ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
[2024-04-24 20:00:18] ERROR : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2024-04-24 20:00:05
[2024-04-24 20:05:04] ERROR : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
[2024-04-24 20:05:04] INFO : Arrêt du démon z2m
[2024-04-24 20:05:05] INFO : Démarrage du démon Z2M : ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ echo 1
+ echo 2
+ echo 3
--2024-04-24 20:08:39-- https://getcomposer.org/installer
0K .......... .......... .......... .......... .......... 87% 2.40M 0s
50K ....... 100% 36.3M=0.02s
2024-04-24 20:08:39 (2.71 MB/s) - 'composer-setup.php' saved [58444/58444]
Downloading...
Composer (version 2.7.4) successfully installed to: /var/www/html/core/ajax/composer.phar
added 117 packages in 5s
19 packages are looking for funding
+ echo 4
+ sudo apt update
+ echo 5
+ echo 6
php-yaml is already the newest version (2.2.1+2.1.0+2.0.4+1.3.2-2).
+ echo 7
+ echo 8
+ rm -rf /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ npm ci
npm ERR! Exit handler never called!
npm ERR! This is an error with npm itself. Please report this error at:
npm ERR! <https://github.com/npm/cli/issues>
npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-04-24T18_09_10_826Z-debug-0.log
+ npm run build
+ echo 9
PHP Fatal error: Uncaught Exception: Veuillez vérifier la configuration in /var/www/html/plugins/z2m/core/class/z2m.class.php:299
Stack trace:
#0 /var/www/html/plugins/z2m/core/class/z2m.class.php(37): z2m::deamon_start()
#1 /var/www/html/core/php/jeecli.php(61): z2m::dependancy_end()
#2 {main}
thrown in /var/www/html/plugins/z2m/core/class/z2m.class.php on line 299
+ echo 10
C’est pas le port et faut vraiment pas touché à ça si vous savez pas ce que vous faite vous allez casser tout jeedom.
La c’est un soucis dans les dépendances au niveau de l’installation de zigbee2mqtt. Le soucis c’est que la on a rien fait côté jeedom et on maîtrise pas du tout cette partie qui est propre a zigbee2mqtt. Aucune idée de pourquoi leur installeur échoue on dirait qu’il manque typescript (tsc) mais aucune idée de pourquoi….
j’ai dupliqué mon jeedom sur une seconde carte SD pour passer sur debian 11 j’avoue avoir commencer un peux a toucher a tout ayant une sauvegarde et l’ancien jeedom prêt a démarrer
j’ai heureusement la majorité de mon install qui tourne toujours sur Zigbee Officiel, cela m’ennui pour quelque équipements qui n’avais pas était intégré…
juste une info je sais pas si ca a un impacte ca a quand parfaitement marché pendant plusieurs mois mais j’ai deux combi 2 sur Zigbee et 1 POP sur Z2m
