Merci à tous pour vos contributions
Le daemon se lance mais j’ai cette erreur dans la log quand j’essaie de lancer une commande
[2022-10-02 10:02:14]ERROR : Exception running handler
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/__init__.py", line 347, in handle_callback
handler(*args)
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 468, in ezsp_callback_handler
self._handle_frame(*args)
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 505, in _handle_frame
dst_addressing = zigpy.types.Addressing.nwk(
AttributeError: type object 'Addressing' has no attribute 'nwk'
[2022-10-02 10:02:17]INFO : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 86, in command
await command()
File "/usr/local/lib/python3.7/dist-packages/zhaquirks/tuya/ts130f.py", line 72, in command
tsn=tsn
File "/usr/local/lib/python3.7/dist-packages/zigpy/quirks/__init__.py", line 188, in command
tsn=tsn,
File "/usr/local/lib/python3.7/dist-packages/zigpy/zcl/__init__.py", line 327, in request
command_id=hdr.command_id,
File "/usr/local/lib/python3.7/dist-packages/zigpy/endpoint.py", line 244, in request
expect_reply=expect_reply,
File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 315, in request
return await asyncio.wait_for(req.result, timeout)
File "/usr/lib/python3.7/asyncio/tasks.py", line 423, in wait_for
raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
During handling of the above exception, another exception occurred:
File "/var/www/html/plugins/zigbee/resources/zigbeed/restServer.py", line 271, in put
await zdevices.command(self.json_args)
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 91, in command
await command()
tsn=tsn
tsn=tsn,
Ma commande était la montée d’un VR. Elle fonctionne mais arrivée en butée, j’ai systématiquement cette erreur qui remonte (et qui faisait partie du message précédent)
handler(*args)
