Bonjour, @TiTidom
J’essais d’installer un nouveau jeedom mais impossible de lancer le demon du plugin TTSCAST.
j’utilise déjà ce plugin sur une config similaire et ça fonctionne sans problème.
page santé :
installation des dépendances :
[2024-04-26 17:49:44] *******************
[2024-04-26 17:49:44] * Check PyEnv Dir *
[2024-04-26 17:49:44] ** PyEnv Directory (None) :: /opt/pyenv **
[2024-04-26 17:49:44] ** Check PyEnv :: Done **
[2024-04-26 17:49:44] ***********************
[2024-04-26 17:49:44] * Check Old PyEnv Dir *
[2024-04-26 17:49:44] ** PyEnv Old Directory (None) :: /var/www/html/plugins/ttscast/resources/pyenv **
[2024-04-26 17:49:44] ** Venv Update :: Not Needed **
[2024-04-26 17:49:44] ** Check Old PyEnv :: Done **
[2024-04-26 17:49:44] * Update apt-get *
[2024-04-26 17:49:44] ** Clean apt-get :: Done **
[2024-04-26 17:49:44] Hit:1 http://deb.debian.org/debian bookworm InRelease
[2024-04-26 17:49:44] Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
[2024-04-26 17:49:44] Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
[2024-04-26 17:49:44] Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
[2024-04-26 17:49:45] Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
[2024-04-26 17:49:48] Reading package lists...
[2024-04-26 17:49:48] ** Update apt-get :: Done **
[2024-04-26 17:49:48] ****************************
[2024-04-26 17:49:48] * Simulate apt-get upgrade *
[2024-04-26 17:49:49] Building dependency tree...
[2024-04-26 17:49:49] Reading state information...
[2024-04-26 17:49:49] Calculating upgrade...
[2024-04-26 17:49:49] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-04-26 17:49:49] ** Upgrade Simulation :: Done **
[2024-04-26 17:49:49] ****************************************
[2024-04-26 17:49:49] * Install apt-get packages for Python3 *
[2024-04-26 17:49:49] Reading package lists...
[2024-04-26 17:49:50] Building dependency tree...
[2024-04-26 17:49:50] Reading state information...
[2024-04-26 17:49:50] python3 is already the newest version (3.11.2-1+b1).
[2024-04-26 17:49:50] python3-requests is already the newest version (2.28.1+dfsg-1).
[2024-04-26 17:49:50] python3-requests set to manually installed.
[2024-04-26 17:49:50] python3-pip is already the newest version (23.0.1+dfsg-1+rpt1).
[2024-04-26 17:49:50] python3-setuptools is already the newest version (66.1.1-1).
[2024-04-26 17:49:50] python3-setuptools set to manually installed.
[2024-04-26 17:49:50] python3-dev is already the newest version (3.11.2-1+b1).
[2024-04-26 17:49:50] python3-dev set to manually installed.
[2024-04-26 17:49:50] python3-venv is already the newest version (3.11.2-1+b1).
[2024-04-26 17:49:50] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2024-04-26 17:49:50] ** Install packages for Python3 :: Done **
[2024-04-26 17:49:50] ***************************
[2024-04-26 17:49:50] * Check Python3.x Version *
[2024-04-26 17:49:50] Python3.x Version :: 3.11
[2024-04-26 17:49:50] ** Check Python3 Version :: Done **
[2024-04-26 17:49:50] * PyEnv Environment *
[2024-04-26 17:49:50] ** PyEnv not required (Python >= 3.11) **
[2024-04-26 17:49:50] * Create Python3.11 venv *
[2024-04-26 17:50:00] ** Create Python3.11 Venv :: Done **
[2024-04-26 17:50:00] *****************************
[2024-04-26 17:50:00] * Install Python3 libraries *
[2024-04-26 17:50:00] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-04-26 17:50:00] Requirement already satisfied: pip in ./venv/lib/python3.11/site-packages (24.0)
[2024-04-26 17:50:01] Collecting wheel
[2024-04-26 17:50:01] Downloading https://www.piwheels.org/simple/wheel/wheel-0.43.0-py3-none-any.whl (65 kB)
[2024-04-26 17:50:01] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 65.8/65.8 kB 234.8 kB/s eta 0:00:00
[2024-04-26 17:50:02] Installing collected packages: wheel
[2024-04-26 17:50:02] Successfully installed wheel-0.43.0
[2024-04-26 17:50:03] ** Install Pip / Wheel :: Done **
[2024-04-26 17:50:03] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-04-26 17:50:04] Collecting PyChromecast==14.0.1
[2024-04-26 17:50:04] Downloading https://www.piwheels.org/simple/pychromecast/PyChromecast-14.0.1-py2.py3-none-any.whl (75 kB)
[2024-04-26 17:50:04] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 75.6/75.6 kB 277.9 kB/s eta 0:00:00
[2024-04-26 17:50:04] Collecting google-cloud-texttospeech==2.16.3
[2024-04-26 17:50:04] Downloading https://www.piwheels.org/simple/google-cloud-texttospeech/google_cloud_texttospeech-2.16.3-py2.py3-none-any.whl (151 kB)
[2024-04-26 17:50:04] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 152.0/152.0 kB 955.7 kB/s eta 0:00:00
[2024-04-26 17:50:05] Collecting gTTS==2.5.1
[2024-04-26 17:50:05] Downloading https://www.piwheels.org/simple/gtts/gTTS-2.5.1-py3-none-any.whl (29 kB)
[2024-04-26 17:50:05] Collecting protobuf>=4.25.1 (from PyChromecast==14.0.1)
[2024-04-26 17:50:05] Downloading protobuf-5.26.1-cp37-abi3-manylinux2014_aarch64.whl.metadata (592 bytes)
[2024-04-26 17:50:06] Collecting zeroconf>=0.25.1 (from PyChromecast==14.0.1)
[2024-04-26 17:50:06] Downloading zeroconf-0.132.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (6.0 kB)
[2024-04-26 17:50:06] Collecting casttube>=0.2.0 (from PyChromecast==14.0.1)
[2024-04-26 17:50:06] Downloading https://www.piwheels.org/simple/casttube/casttube-0.2.1-py3-none-any.whl (6.5 kB)
[2024-04-26 17:50:07] Collecting google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1 (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:07] Downloading https://www.piwheels.org/simple/google-api-core/google_api_core-2.18.0-py3-none-any.whl (138 kB)
[2024-04-26 17:50:07] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 138.3/138.3 kB 861.3 kB/s eta 0:00:00
[2024-04-26 17:50:07] Collecting google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1 (from google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:07] Downloading https://www.piwheels.org/simple/google-auth/google_auth-2.29.0-py2.py3-none-any.whl (189 kB)
[2024-04-26 17:50:07] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 189.2/189.2 kB 1.2 MB/s eta 0:00:00
[2024-04-26 17:50:07] Collecting proto-plus<2.0.0dev,>=1.22.3 (from google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:08] Downloading https://www.piwheels.org/simple/proto-plus/proto_plus-1.23.0-py3-none-any.whl (48 kB)
[2024-04-26 17:50:08] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 48.8/48.8 kB 520.2 kB/s eta 0:00:00
[2024-04-26 17:50:08] Collecting protobuf>=4.25.1 (from PyChromecast==14.0.1)
[2024-04-26 17:50:08] Downloading protobuf-4.25.3-cp37-abi3-manylinux2014_aarch64.whl.metadata (541 bytes)
[2024-04-26 17:50:08] Collecting requests<3,>=2.27 (from gTTS==2.5.1)
[2024-04-26 17:50:08] Downloading https://www.piwheels.org/simple/requests/requests-2.31.0-py3-none-any.whl (62 kB)
[2024-04-26 17:50:08] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 844.2 kB/s eta 0:00:00
[2024-04-26 17:50:08] Collecting click<8.2,>=7.1 (from gTTS==2.5.1)
[2024-04-26 17:50:08] Downloading https://www.piwheels.org/simple/click/click-8.1.7-py3-none-any.whl (97 kB)
[2024-04-26 17:50:08] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 97.9/97.9 kB 1.4 MB/s eta 0:00:00
[2024-04-26 17:50:09] Collecting googleapis-common-protos<2.0.dev0,>=1.56.2 (from google-api-core!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:09] Downloading https://www.piwheels.org/simple/googleapis-common-protos/googleapis_common_protos-1.63.0-py2.py3-none-any.whl (229 kB)
[2024-04-26 17:50:09] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 229.1/229.1 kB 3.0 MB/s eta 0:00:00
[2024-04-26 17:50:10] Collecting grpcio<2.0dev,>=1.33.2 (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:10] Downloading grpcio-1.62.2-cp311-cp311-manylinux_2_17_aarch64.whl.metadata (4.0 kB)
[2024-04-26 17:50:10] Collecting grpcio-status<2.0.dev0,>=1.33.2 (from google-api-core[grpc]!=2.0.*,!=2.1.*,!=2.10.*,!=2.2.*,!=2.3.*,!=2.4.*,!=2.5.*,!=2.6.*,!=2.7.*,!=2.8.*,!=2.9.*,<3.0.0dev,>=1.34.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:10] Downloading https://www.piwheels.org/simple/grpcio-status/grpcio_status-1.62.2-py3-none-any.whl (14 kB)
[2024-04-26 17:50:10] Collecting cachetools<6.0,>=2.0.0 (from google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:10] Downloading https://www.piwheels.org/simple/cachetools/cachetools-5.3.3-py3-none-any.whl (9.3 kB)
[2024-04-26 17:50:11] Collecting pyasn1-modules>=0.2.1 (from google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:11] Downloading https://www.piwheels.org/simple/pyasn1-modules/pyasn1_modules-0.4.0-py3-none-any.whl (181 kB)
[2024-04-26 17:50:11] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 181.2/181.2 kB 1.1 MB/s eta 0:00:00
[2024-04-26 17:50:11] Collecting rsa<5,>=3.1.4 (from google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:11] Downloading rsa-4.9-py3-none-any.whl.metadata (4.2 kB)
[2024-04-26 17:50:11] Collecting charset-normalizer<4,>=2 (from requests<3,>=2.27->gTTS==2.5.1)
[2024-04-26 17:50:11] Downloading charset_normalizer-3.3.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (33 kB)
[2024-04-26 17:50:11] Collecting idna<4,>=2.5 (from requests<3,>=2.27->gTTS==2.5.1)
[2024-04-26 17:50:12] Downloading https://www.piwheels.org/simple/idna/idna-3.7-py3-none-any.whl (66 kB)
[2024-04-26 17:50:12] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.8/66.8 kB 8.7 MB/s eta 0:00:00
[2024-04-26 17:50:12] Collecting urllib3<3,>=1.21.1 (from requests<3,>=2.27->gTTS==2.5.1)
[2024-04-26 17:50:12] Downloading https://www.piwheels.org/simple/urllib3/urllib3-2.2.1-py3-none-any.whl (121 kB)
[2024-04-26 17:50:12] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 121.1/121.1 kB 1.7 MB/s eta 0:00:00
[2024-04-26 17:50:12] Collecting certifi>=2017.4.17 (from requests<3,>=2.27->gTTS==2.5.1)
[2024-04-26 17:50:12] Downloading https://www.piwheels.org/simple/certifi/certifi-2024.2.2-py3-none-any.whl (163 kB)
[2024-04-26 17:50:12] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 163.8/163.8 kB 2.2 MB/s eta 0:00:00
[2024-04-26 17:50:12] Collecting ifaddr>=0.1.7 (from zeroconf>=0.25.1->PyChromecast==14.0.1)
[2024-04-26 17:50:12] Downloading https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
[2024-04-26 17:50:13] Collecting pyasn1<0.7.0,>=0.4.6 (from pyasn1-modules>=0.2.1->google-auth!=2.24.0,!=2.25.0,<3.0.0dev,>=2.14.1->google-cloud-texttospeech==2.16.3)
[2024-04-26 17:50:13] Downloading https://www.piwheels.org/simple/pyasn1/pyasn1-0.6.0-py2.py3-none-any.whl (85 kB)
[2024-04-26 17:50:13] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 85.3/85.3 kB 1.1 MB/s eta 0:00:00
[2024-04-26 17:50:13] Downloading protobuf-4.25.3-cp37-abi3-manylinux2014_aarch64.whl (293 kB)
[2024-04-26 17:50:13] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 293.7/293.7 kB 16.8 MB/s eta 0:00:00
[2024-04-26 17:50:13] Downloading zeroconf-0.132.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (11.3 MB)
[2024-04-26 17:50:13] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 11.3/11.3 MB 53.5 MB/s eta 0:00:00
[2024-04-26 17:50:13] Downloading charset_normalizer-3.3.2-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (136 kB)
[2024-04-26 17:50:13] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 136.6/136.6 kB 31.2 MB/s eta 0:00:00
[2024-04-26 17:50:13] Downloading grpcio-1.62.2-cp311-cp311-manylinux_2_17_aarch64.whl (5.3 MB)
[2024-04-26 17:50:13] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 5.3/5.3 MB 78.5 MB/s eta 0:00:00
[2024-04-26 17:50:13] Downloading rsa-4.9-py3-none-any.whl (34 kB)
[2024-04-26 17:50:13] Installing collected packages: ifaddr, zeroconf, urllib3, pyasn1, protobuf, idna, grpcio, click, charset-normalizer, certifi, cachetools, rsa, requests, pyasn1-modules, proto-plus, googleapis-common-protos, gTTS, grpcio-status, google-auth, casttube, PyChromecast, google-api-core, google-cloud-texttospeech
[2024-04-26 17:50:15] Successfully installed PyChromecast-14.0.1 cachetools-5.3.3 casttube-0.2.1 certifi-2024.2.2 charset-normalizer-3.3.2 click-8.1.7 gTTS-2.5.1 google-api-core-2.18.0 google-auth-2.29.0 google-cloud-texttospeech-2.16.3 googleapis-common-protos-1.63.0 grpcio-1.62.2 grpcio-status-1.62.2 idna-3.7 ifaddr-0.2.0 proto-plus-1.23.0 protobuf-4.25.3 pyasn1-0.6.0 pyasn1-modules-0.4.0 requests-2.31.0 rsa-4.9 urllib3-2.2.1 zeroconf-0.132.2
[2024-04-26 17:50:16] ** Install Python3 librairies :: Done **
[2024-04-26 17:50:16] ****************************
[2024-04-26 17:50:16] * Set Owner on Directories *
[2024-04-26 17:50:16] ** Set Owner for Venv Dir :: Done **
[2024-04-26 17:50:16] * Install DONE *
log debug :
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Start Daemon
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Plugin Version: 1.2.3
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Log level: debug
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Socket port: 55111
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Socket host: localhost
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] CycleFactor: 1.0
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] CycleMain: 2.0
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] CycleComm: 0.5
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] CycleEvent: 0.5
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] PID file: /tmp/jeedom/ttscast/deamon.pid
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] ApiKey: ***
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] ApiTTSKey: ***
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Google Cloud ApiKey: noKey
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] VoiceRSS ApiKey: ***
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] App Disable Ding: False
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Cmd Wait Timeout: 60
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] CallBack: http://127.0.0.1:80/plugins/ttscast/core/php/jeettscast.php
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Jeedom WebSrvCache: http://192.168.1.127/plugins/ttscast/data/cache/
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Jeedom WebSrvMedia: http://192.168.1.127/plugins/ttscast/data/media/
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Jeedom WebSrvImages: http://192.168.1.127/plugins/ttscast/data/images/
[2024-04-26 18:25:03][INFO] : [DAEMON][MAIN] Jeedom WebSrvJeeTTS: http://192.168.1.127/core/api/
[2024-04-26 18:25:03][DEBUG] : [DAEMON][UTILS] Writing PID 8050 to /tmp/jeedom/ttscast/deamon.pid
[2024-04-26 18:25:03][INFO] : [DAEMON][COM] Init request module v2.31.0
[2024-04-26 18:25:03][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2024-04-26 18:25:03][DEBUG] : http://127.0.0.1:80 "GET /plugins/ttscast/core/php/jeettscast.php?apikey=xxxx HTTP/1.1" 403 199
[2024-04-26 18:25:03][ERROR] : [DAEMON][COM][TEST] Callback result as a unknown error: 'Response' object has no attribute 'status'. Please check your network configuration page
[2024-04-26 18:25:03][ERROR] : [DAEMON][JEEDOMCOM] sendToJeedom :: Network communication ERROR (Daemon to Jeedom)
[2024-04-26 18:25:03][INFO] : [DAEMON] Shutdown :: Begin...
[2024-04-26 18:25:03][INFO] : [DAEMON] Shutdown :: Devices Disconnect :: Begin...
[2024-04-26 18:25:03][INFO] : [DAEMON] Shutdown :: Devices Disconnect :: OK
[2024-04-26 18:25:03][ERROR] : [DAEMON] Exception on Shutdown :: 'NoneType' object has no attribute 'stop_discovery'
[2024-04-26 18:25:03][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/ttscast/resources/ttscastd/ttscastd.py", line 1792, in shutdown
Config.NETCAST_BROWSER.stop_discovery()
AttributeError: 'NoneType' object has no attribute 'stop_discovery'
[2024-04-26 18:25:03][DEBUG] : [DAEMON] Removing PID file /tmp/jeedom/ttscast/deamon.pid
[2024-04-26 18:25:03][INFO] : [DAEMON] Shutdown :: Exit 0
Je vois bien qu’il y a une erreur de communication reseau mais je ne vois pas d’où vient le problème…
page congig reseau
Merci par avance pour votre aide…
