Bonjour a tous.
Pourriez vous créer ou mettre a jour l’équipement Thermostat AV2010/32 de Bitronvideo sur le plugin Zigbee?
J’ai actuellement 3 thermostat cité plus haut, je suis sensé pouvoir passé en mode Cool/heat/off, j’ai réussi les deux mode off/heat mais ne parvient pas a les mètre en mode « cool » (pour le rafraichissement).j’ai une PAC réversible.
Je suis sur PI4 /Jeedom 4.1.22 /Contrôleur Conbee II/Plugin Zigbee.
"ieee": "00:0d:6f:00:0e:f0:cc:dc",
"nwk": 58199,
"status": 2,
"lqi": "239",
"rssi": "-64",
"last_seen": "1619194533.8553908",
"node_descriptor": "02:40:80:71:10:52:52:00:00:00:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 769,
"profile_id": 260,
"manufacturer": "Bitron Home",
"model": "902010\/32",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 2
"id": 4,
"name": "manufacturer",
"value": "Bitron Home"
"id": 5,
"name": "model",
"value": "902010\/32"
"id": 6,
"name": "date_code",
"value": "2017082417236318"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "V1b225-20151013"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 32
"id": 3,
"name": "Identify",
"attributes": []
"id": 10,
"name": "Time",
"attributes": [
"id": 1,
"name": "time_status",
"value": 0
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 513,
"name": "Thermostat",
"attributes": [
"id": 0,
"name": "local_temp",
"value": 2290
"id": 2,
"name": "occupancy",
"value": 1
"id": 17,
"name": "occupied_cooling_setpoint",
"value": 2600
"id": 18,
"name": "occupied_heating_setpoint",
"value": 2000
"id": 19,
"name": "unoccupied_cooling_setpoint",
"value": 2600
"id": 20,
"name": "unoccupied_heating_setpoint",
"value": 2000
"id": 28,
"name": "system_mode",
"value": 4
"id": 41,
"name": "running_state",
"value": 0
"id": 516,
"name": "Thermostat User Interface Configuration",
"attributes": []
"id": 2821,
"name": "Diagnostic",
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4209,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 0,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 769,
"input_clusters": [
0,
1,
3,
10,
32,
513,
516,
2821
3,
25
"class": "zigpy.device"
[2021-04-23 18:19:37][DEBUG] : {"ieee":"00:0d:6f:00:0e:f0:cc:dc","attributes":[{"endpoint":1,"cluster_type":"in","cluster":513,"attributes":{"18":2500}}],"allowQueue":false}
[2021-04-23 18:19:38][DEBUG] : {"ieee":"00:0d:6f:00:0e:f0:cc:dc","attributes":[{"endpoint":1,"cluster_type":"in","cluster":513,"attributes":{"18":2550}}],"allowQueue":false}
[2021-04-23 18:19:41][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"18":{"value":"2500","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:19:41][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::18 => 2500
[2021-04-23 18:19:42][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"41":{"value":"RunningState.Heat_State_On","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:19:42][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::41 => RunningState.Heat_State_On
[2021-04-23 18:19:47][DEBUG] : {"ieee":"00:0d:6f:00:0e:f0:cc:dc","attributes":[{"endpoint":1,"cluster_type":"in","cluster":513,"attributes":{"18":2000}}],"allowQueue":false}
[2021-04-23 18:20:10][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"18":{"value":"2000","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:10][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::18 => 2000
[2021-04-23 18:20:11][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"41":{"value":"RunningState.Idle","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:11][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::41 => RunningState.Idle
[2021-04-23 18:20:18][DEBUG] : {"ieee":"00:0d:6f:00:0e:f0:cc:dc","attributes":[{"endpoint":1,"cluster_type":"in","cluster":513,"attributes":{"18":1100}}],"allowQueue":false}
[2021-04-23 18:20:21][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"17":{"value":"2600","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:21][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::17 => 2600
[2021-04-23 18:20:23][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"19":{"value":"2600","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:23][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::19 => 2600
[2021-04-23 18:20:24][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"20":{"value":"2000","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:24][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::20 => 2000
[2021-04-23 18:20:27][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"28":{"value":"SystemMode.Heat","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:27][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::28 => SystemMode.Heat
[2021-04-23 18:20:28][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"2":{"value":"Occupancy.Occupied","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:28][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::2 => Occupancy.Occupied
[2021-04-23 18:20:40][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":{"18":{"value":"1100","cluster_name":"Thermostat"}}}}}}
[2021-04-23 18:20:40][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::18 => 1100
[2021-04-23 18:20:50][DEBUG] : {"devices":{"00:0d:6f:00:0e:f0:cc:dc":{"1":{"513":[{"value":"2300","cluster_name":"Thermostat"}]}}}}
[2021-04-23 18:20:50][DEBUG] : Search attribut for 00:0d:6f:00:0e:f0:cc:dc logicalId : 1::513::0 => 2300
