J’ai une passerelle SCN-IP100.03 IP Router avec Secure.
Et Jeedom 4.2.21 et je n’arrive pas à faire communiquer mon jeedom avec mon bus KNX.
Voici les log du module EIB-KNX.
|1 Oct 2022 21:26:37:129|Jeedom: Layer 3 [17:Server/server 0.011] registerLink: 17:Server|
|1 Oct 2022 21:26:37:129|Jeedom: I00000129: [ 1:main] Connected: cfg:Gateway.|
|1 Oct 2022 21:26:37:129|Jeedom: I00000129: [ 1:main] Connected: cfg:Server.|
|1 Oct 2022 21:26:37:129|Jeedom: I00000129: [ 1:main] Connected: cfg:TCP.|
|1 Oct 2022 21:26:37:129|Jeedom: I00000129: [ 1:main] Connected: cfg:systemd_.|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 4 [ 1:main 0.011] setup OK|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 4 [ 1:main 0.012] trigger going up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 3 [13:Gateway/Conn 0.012] Start: cfg:Gateway|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [13:Gateway/Conn 0.012] down => >up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [13:Gateway/Conn 0.012] Starting|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 2 [14:Gateway/ipt 0.012] Open|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 2 [14:Gateway/ipt 0.014] Opened|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 4 [13:Gateway/Conn 0.014] >up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 3 [17:Server/server 0.014] Start: cfg:Server|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [17:Server/server 0.014] down => >up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 8 [17:Server/server 0.014] Open|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 8 [23:router/driver 0.014] OpenD|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 8 [23:router/driver 0.016] OpenedD|
|1 Oct 2022 21:26:37:129|Jeedom: N00000127: [24:router.pace_] The 'pace' filter without a queue acts globally.|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 3 [22:router/ConnC 0.016] registerLink: 22:router_22|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 3 [22:router/ConnC 0.016] Start: cfg:router|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [22:router/ConnC 0.016] down => >up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [22:router/ConnC 0.016] Starting|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [22:router/ConnC 0.016] >up => up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 4 [22:router/ConnC 0.016] up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [22:router/ConnC 0.016] Started|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 8 [17:Server/server 0.031] Opened|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 5 [17:Server/server 0.031] >up => up|
|1 Oct 2022 21:26:37:129|Jeedom: Layer 4 [17:Server/server 0.031] up|
Et voici ma config:
D’avance merci pour vos réponses.
Bonne soirée,
Guillaume
Voici une copie de ma configuration dans Jeedom @mika-nt28
Peux tu désactivé le filtres serveur dans les options.
Bonjour Mika,
Malheureusement, ca ne change rien …
Date Message
8 Oct 2022 8:0:50:524 Jeedom: Layer 8 [ 4:systemd_/systemd 10.012] StopServer
8 Oct 2022 8:0:50:524 Jeedom: Layer 5 [ 4:systemd_/systemd 10.012] >down => down
8 Oct 2022 8:0:50:524 Jeedom: Layer 4 [ 4:systemd_/systemd 10.013] down
8 Oct 2022 8:0:50:524 Jeedom: Layer 4 [ 7:systemd_/systemd 10.013] Stopping
8 Oct 2022 8:0:50:524 Jeedom: Layer 5 [ 7:systemd_/systemd 10.013] up => >down
8 Oct 2022 8:0:50:524 Jeedom: Layer 8 [ 7:systemd_/systemd 10.013] StopServer
8 Oct 2022 8:0:50:524 Jeedom: Layer 8 [22:systemd_/CConn 10.013] ClientConnection 0.0.2 closing
8 Oct 2022 8:0:50:524 Jeedom: Layer 3 [ 1:main 10.013] Release 0.0.2
8 Oct 2022 8:0:50:524 Jeedom: Layer 3 [24:systemd_/ConnS 10.013] unregisterLink: systemd__24
8 Oct 2022 8:0:50:524 Jeedom: Layer 8 [22:systemd_/CConn 10.013] Exiting
8 Oct 2022 8:0:50:524 Jeedom: Layer 7 [22:systemd_/CConn 10.013] CloseGroupSocket
8 Oct 2022 8:0:50:524 Jeedom: Layer 5 [ 7:systemd_/systemd 10.022] >down => down
8 Oct 2022 8:0:50:524 Jeedom: Layer 4 [ 7:systemd_/systemd 10.022] down
8 Oct 2022 8:0:50:524 Jeedom: Layer 4 [ 1:main 10.022] check start
8 Oct 2022 8:0:50:524 Jeedom: Layer 4 [25:systemd_/LineDr 10.022] CloseGroupSocket
8 Oct 2022 8:0:50:724 knxd.service: Main process exited, code=exited, status=1/FAILURE
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [16:Server/server 10.023] is down
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [13:Gateway/Conn 10.023] is down
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [ 4:systemd_/systemd 10.023] is down
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [ 7:systemd_/systemd 10.023] is down
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [ 1:main 10.023] check end: want_up 0 some 1>0 all 0>0, going 0 up 0 down 4
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [ 1:main 10.023] down
8 Oct 2022 8:0:50:742 Jeedom: N00000128: [ 1:main] Shutting down.
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [ 1:main 10.034] deleting
8 Oct 2022 8:0:50:742 Jeedom: Layer 8 [16:Server/server 10.035] Close
8 Oct 2022 8:0:50:742 Jeedom: Layer 2 [14:Gateway/ipt 10.035] Close
8 Oct 2022 8:0:50:742 Jeedom: Layer 8 [10:TCP/inet 10.035] StopServer
8 Oct 2022 8:0:50:742 Jeedom: Layer 8 [ 4:systemd_/systemd 10.035] StopServer
8 Oct 2022 8:0:50:742 Jeedom: Layer 4 [ 1:main 10.037] deleted.
8 Oct 2022 8:0:50:796 knxd.service: Failed with result 'exit-code'.
A tu des équipements de configurer si oui peux tu les désactivé
J’ai désactivé ma lampe.
11 Oct 2022 14:22:58:562 Jeedom: Layer 3 [24:systemd_/ConnS 9.990] unregisterLink: systemd__24
11 Oct 2022 14:22:58:756 Jeedom: Layer 8 [22:systemd_/CConn 9.990] Exiting
11 Oct 2022 14:22:58:756 Jeedom: Layer 7 [22:systemd_/CConn 9.991] CloseGroupSocket
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [25:systemd_/LineDr 9.991] CloseGroupSocket
11 Oct 2022 14:22:58:756 Jeedom: Layer 5 [ 7:systemd_/systemd 10.002] >down => down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 7:systemd_/systemd 10.002] down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [13:Gateway/Conn 10.003] Stopping
11 Oct 2022 14:22:58:756 Jeedom: Layer 5 [13:Gateway/Conn 10.003] down/error => >down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [13:Gateway/Conn 10.003] down/error
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [16:Server/server 10.003] Stopping
11 Oct 2022 14:22:58:756 Jeedom: Layer 5 [16:Server/server 10.003] up => >down
11 Oct 2022 14:22:58:756 Jeedom: Layer 8 [27:tunnel/0.0.3 10.003] Stop Conn 1
11 Oct 2022 14:22:58:756 Jeedom: Layer 8 [20:/driver 10.003] CloseD
11 Oct 2022 14:22:58:756 Jeedom: Layer 5 [16:Server/server 10.004] >down => down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [16:Server/server 10.004] down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 1:main 10.004] check start
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 4:systemd_/systemd 10.004] is down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 7:systemd_/systemd 10.004] is down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [13:Gateway/Conn 10.005] is down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [16:Server/server 10.005] is down
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 1:main 10.005] check end: want_up 0 some 1>0 all 0>0, going 0 up 0 down 4
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 1:main 10.005] down
11 Oct 2022 14:22:58:756 Jeedom: N00000128: [ 1:main] Shutting down.
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 1:main 10.018] deleting
11 Oct 2022 14:22:58:756 Jeedom: Layer 8 [ 4:systemd_/systemd 10.018] StopServer
11 Oct 2022 14:22:58:756 Jeedom: Layer 8 [10:TCP/inet 10.018] StopServer
11 Oct 2022 14:22:58:756 Jeedom: Layer 2 [14:Gateway/ipt 10.019] Close
11 Oct 2022 14:22:58:756 Jeedom: Layer 4 [ 1:main 10.019] deleted.
11 Oct 2022 14:22:58:873 knxd.service: Main process exited, code=exited, status=1/FAILURE
11 Oct 2022 14:22:58:886 knxd.service: Failed with result 'exit-code'.
Je ne vois toujours rien dans le moniteur de bus
Je ne vois pas pourquoi le problème
Est ce possible de me faire parvenir un accès à votre Jeedom et me transmettre les informations par mp
