Depuis plusieurs jours je n’arrive plus à accéder à mon Jeedom Connect, l’application essaie de se connecter en vain en m’affichant « Mode hors connexion » par contre je reçois bien les notifications et j’arrive bien à accéder à mon jeedom via « Interface WEB »
Je n’ai absolument rien toucher à mon jeedom mis à part effectuer les éventuelles MAJ des plugin
Ce problème intervient en 4G ou sur le même réseau.
Dans le log Debug j’obtiens ça lorsque je lance JC:
0000|[2022-09-06 22:10:16]DEBUG : [API] HTTP Received {"method":"CONNECT","params":{"apiKey":"XXX","deviceId":"XXX","deviceName":"S21 Ultra de Julien","userHash":"XXX******************************************************","appVersion":"1.4.0","pluginRequire":"1.2.3","token":"XXX","platformOs":"android","osVersion":31},"jsonrpc":"2.0","id":XXX}
0001|[2022-09-06 22:10:16]DEBUG : [API] HTTP Received {"method":"SET_APPSTATE","params":{"state":"active","apiKey":"XXX"},"jsonrpc":"2.0","id":XXX}
0002|[2022-09-06 22:10:16]DEBUG : [API] Send SET_APPSTATE -> null
0003|[2022-09-06 22:10:18]DEBUG : [API] HTTP Received {"method":"SET_APPSTATE","params":{"state":"background","apiKey":"XXX"},"jsonrpc":"2.0","id":XXX}
0004|[2022-09-06 22:10:18]DEBUG : [API] Send SET_APPSTATE -> null
0005|[2022-09-06 22:10:32]DEBUG : [API] HTTP Received {"method":"PING","jsonrpc":"2.0","id":XXX,"params":{"apiKey":"XXX"}}
0006|[2022-09-06 22:10:32]DEBUG : [API] Send PING -> null
0007|[2022-09-06 22:10:32]DEBUG : [API] HTTP Received {"method":"CONNECT","params":{"apiKey":"XXX","deviceId":"XXX","deviceName":"S21 Ultra de Julien","userHash":"XXX","appVersion":"1.4.0","pluginRequire":"1.2.3","token":":XXX","platformOs":"android","osVersion":31},"jsonrpc":"2.0","id":XXX
0008|[2022-09-06 22:10:39]DEBUG : [API] HTTP Received {"method":"PING","jsonrpc":"2.0","id":XXX params":{"apiKey":"XXX"}}
0009|[2022-09-06 22:10:39]DEBUG : [API] Send PING -> null
0010|[2022-09-06 22:10:39]DEBUG : [API] HTTP Received {"method":"CONNECT","params":{"apiKey":"XXX","deviceId":"XXX","deviceName":"S21 Ultra de Julien","userHash":"XXX","appVersion":"1.4.0","pluginRequire":"1.2.3","token":XXX","platformOs":"android","osVersion":31},"jsonrpc":"2.0","id":XXX}
0011|[2022-09-06 22:10:46]DEBUG : [API] HTTP Received {"method":"CONNECT","params":{"apiKey":"XXX","deviceId":"XXX","deviceName":"S21 Ultra de Julien","userHash":"XXX","appVersion":"1.4.0","pluginRequire":"1.2.3","token":"XXX","platformOs":"android","osVersion":31},"jsonrpc":"2.0","id":XXX}
0012|[2022-09-06 22:10:53]DEBUG : [API] HTTP Received {"method":"CONNECT","params":{"apiKey":"XXX","deviceId":"XXX","deviceName":"S21 Ultra de Julien","userHash":"XXX","appVersion":"1.4.0","pluginRequire":"1.2.3","token":"XXX","platformOs":"android","osVersion":31},"jsonrpc":"2.0","id":XXX}
0013|[2022-09-06 22:11:00]DEBUG : [API] HTTP Received {"method":"PING","jsonrpc":"2.0","id":XXX,"params":{"apiKey":"XXX"}}
0014|[2022-09-06 22:11:00]DEBUG : [API] HTTP Received {"method":"CONNECT","params":{"apiKey":"XXX","deviceId":"XXX","deviceName":"S21 Ultra de Julien","userHash":"XXX","appVersion":"1.4.0","pluginRequire":"1.2.3","token":XXX","platformOs":"android","osVersion":31},"jsonrpc":"2.0","id":XXX}
0015|[2022-09-06 22:11:00]DEBUG : [API] Send PING -> null
0016|[2022-09-06 22:11:02]DEBUG : [API] HTTP Received {"method":"SET_APPSTATE","params":{"state":"background","apiKey":"XXX"},"jsonrpc":"2.0","id":XXX}
0017|[2022-09-06 22:11:02]DEBUG : [API] Send SET_APPSTATE -> null
Si une âme charitable à une idée et peut m’aider
Merci à vous!
Jeedom Core : 4.2.21
Version JC : 1.4.1
DNS Jeedom : oui
Equipements :
Margaux_JC : v1.4.0 sur android [os : 31] (polling)
Julien_JC : v1.4.0 sur android [os : 31] (polling)
), peu de temps après la MAJ de l’appli et du plugin.
