j’ai un peu le meme probleme, j’ai une telecommande de storebanne qui normalement c’est pas rolling code elle ressemble à ca avec programmation fix rf433
Sauf que en mode undecoded ou rfxmngr sous windows j’obtient ca :
01/08/2023 04:58:35:458= 387F006B01010D0190024102CD01090185024C02D001040189024B02CB0109018C024802D401010190024402D4010002D40101018602520000
Packettype = RAW Packet
Packet Length = 56
subtype = RAW packet
Sequence nbr = 107
Repeat = 1
Nbr of pulses = 13
269 400 577 717 265 389 588 720 260 393 587 715 265 396 584 724 257 400 580 724 256 724 257 390 594 0
01/08/2023 04:58:35:527= 387F006C01011F018D024602CB010C0184025002D201030188024E02D20103018E024802D301030193024302D2010402D30103018A024E0000
Packet Length = 56
Sequence nbr = 108
Repeat = 1
Nbr of pulses = 13
287 397 582 715 268 388 592 722 259 392 590 722 259 398 584 723 259 403 579 722 260 723 259 394 590 0
01/08/2023 04:58:35:627= 387F006D0101200183025102D70101018D024702CE01080192024502D401020198023E02D30104018E024802D800FF02CF0108018B024E0000
Packet Length = 56
Sequence nbr = 109
Repeat = 1
Nbr of pulses = 13
288 387 593 727 257 397 583 718 264 402 581 724 258 408 574 723 260 398 584 728 255 719 264 395 590 0
01/08/2023 04:58:35:774= 387F006E01011B0187024D02CE010B0187024E02DA00FD018B024B02D60101018F024802D601010195024202DD00FA02D50102018D024C0000
Packet Length = 56
Sequence nbr = 110
Repeat = 1
Nbr of pulses = 13
283 391 589 718 267 391 590 730 253 395 587 726 257 399 584 726 257 405 578 733 250 725 258 397 588 0
01/08/2023 04:58:35:943= 387F006F01011E0184025002C40115018F024602D401030192024502DD00FA0193024402D10106018B024C02D3010502D10106018D024C0000
Packet Length = 56
Sequence nbr = 111
Repeat = 1
Nbr of pulses = 13
286 388 592 708 277 399 582 724 259 402 581 733 250 403 580 721 262 395 588 723 261 721 262 397 588 0
01/08/2023 04:58:36:155= 387F00700101160189024C02D601030184025102D800FF0192024602D401030189024E02D50102018C024C02D6010202D00107018F024B0000
Packet Length = 56
Sequence nbr = 112
Repeat = 1
Nbr of pulses = 13
278 393 588 726 259 388 593 728 255 402 582 724 259 393 590 725 258 396 588 726 258 720 263 399 587 0
01/08/2023 04:58:36:397= 387F00710101160184025102CE010C0192024302D001070194024402DA00FD018D024A02D80100018C024B02D6010202D30105018C024D0000
Packet Length = 56
Sequence nbr = 113
Repeat = 1
Nbr of pulses = 13
278 388 593 718 268 402 579 720 263 404 580 730 253 397 586 728 256 396 587 726 258 723 261 396 589 0
du coup j’envoi les meme trame enchainé dans rfxcom mais ca fait rien :
dans le log en debug j’obtiens pas d’erreur mais cela ne fait pas reagir le store :
[2023-08-03 01:20:59]DEBUG : flushInput serial port
[2023-08-03 01:20:59]DEBUG : Write message to serial port
[2023-08-03 01:20:59]DEBUG : Write data to serial port : 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
[2023-08-03 01:20:59]DEBUG : Write message ok : 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
[2023-08-03 01:20:59]DEBUG : Message: 0402010b00
[2023-08-03 01:20:59]DEBUG : Decode : 0402010b00
[2023-08-03 01:20:59]DEBUG : Test message: 0402010b00
[2023-08-03 01:20:59]DEBUG : PacketType: 0x02
[2023-08-03 01:20:59]DEBUG : Length: 5
[2023-08-03 01:20:59]DEBUG : Start decoding packet type 0x02
[2023-08-03 01:20:59]DEBUG : Subtype = Reponse du Transmetteur
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x0B', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Reponse du Transmetteur = 0x00
[2023-08-03 01:20:59]DEBUG : Message Transmis
[2023-08-03 01:20:59]DEBUG : Message: 0402010c00
[2023-08-03 01:20:59]DEBUG : Decode : 0402010c00
[2023-08-03 01:20:59]DEBUG : Test message: 0402010c00
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x0C', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Message: 0402010d00
[2023-08-03 01:20:59]DEBUG : Decode : 0402010d00
[2023-08-03 01:20:59]DEBUG : Test message: 0402010d00
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x0D', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Message: 0402010e00
[2023-08-03 01:20:59]DEBUG : Decode : 0402010e00
[2023-08-03 01:20:59]DEBUG : Test message: 0402010e00
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x0E', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Message: 0402010f00
[2023-08-03 01:20:59]DEBUG : Decode : 0402010f00
[2023-08-03 01:20:59]DEBUG : Test message: 0402010f00
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x0F', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Message: 0402011000
[2023-08-03 01:20:59]DEBUG : Decode : 0402011000
[2023-08-03 01:20:59]DEBUG : Test message: 0402011000
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x10', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Message: 0402011100
[2023-08-03 01:20:59]DEBUG : Decode : 0402011100
[2023-08-03 01:20:59]DEBUG : Test message: 0402011100
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x11', 'msg1': '0x00'}
[2023-08-03 01:20:59]DEBUG : Message: 0402011200
[2023-08-03 01:20:59]DEBUG : Decode : 0402011200
[2023-08-03 01:20:59]DEBUG : Test message: 0402011200
[2023-08-03 01:20:59]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0x12', 'msg1': '0x00'}
je sais pas si quelqu’un peut m’aider. @Bison peut être…
et surtout ce que je suis super surpris c’est que j’ai aussi un RMPro qui ne gere que le 433mhz et non rolling code, et la pour le coup j’ai reussi à duppliquer mes commande ouvrir ferme sans probleme mais c’est n’est pas le même format :
la RMPro marche avec le plugin broadlink, mais en IP, j’aimerais passer mais commande de la RMpro sur RFXcom que je trouvais plus complet… mais finalement je suis pas convaincu là…
