Je pense que je dois manquer qqchose de basique car je ne trouve aucun post sur la configuration de base.
Grace a certains posts, j 'ai donc openalpr installé ainsi que ses dependences → OK
Dans la doc, j’ai récupéré l’image test et ait crée un scenario de test. J’envoie l’image en tant que message.
J’ai un deuxieme log disponible quelques secondes qui me dit ca ( a priori ok, mais je reposte au cas ou )
[2021-04-23 16:21:43][DEBUG] : {"version":2,"data_type":"alpr_results","epoch_time":1619187703297,"img_width":858,"img_height":709,"processing_time_ms":169.315369,"regions_of_interest":[{"x":0,"y":0,"width":858,"height":709}],"results":[{"plate":"AV8G5XG","confidence":89.549454,"matches_template":0,"plate_index":0,"region":"","region_confidence":0,"processing_time_ms":59.176758,"requested_topn":10,"coordinates":[{"x":92,"y":230},{"x":698,"y":237},{"x":698,"y":365},{"x":92,"y":358}],"candidates":[{"plate":"AV8G5XG","confidence":89.549454,"matches_template":0},{"plate":"AV865XG","confidence":86.135338,"matches_template":0},{"plate":"AV8B5XG","confidence":85.384041,"matches_template":0},{"plate":"AV8E5XG","confidence":85.319023,"matches_template":0},{"plate":"AV8S5XG","confidence":84.502075,"matches_template":0},{"plate":"AVBG5XG","confidence":83.378525,"matches_template":0},{"plate":"AV855XG","confidence":82.600105,"matches_template":0},{"plate":"AV85XG","confidence":81.445183,"matches_template":0},{"plate":"AVGG5XG","confidence":80.773605,"matches_template":0},{"plate":"AVB65XG","confidence":79.964409,"matches_template":0}]}]}
[2021-04-23 16:21:43][DEBUG] : [Detection]"{\"version\":2,\"data_type\":\"alpr_results\",\"epoch_time\":1619187703297,\"img_width\":858,\"img_height\":709,\"processing_time_ms\":169.315369,\"regions_of_interest\":[{\"x\":0,\"y\":0,\"width\":858,\"height\":709}],\"results\":[{\"plate\":\"AV8G5XG\",\"confidence\":89.549454,\"matches_template\":0,\"plate_index\":0,\"region\":\"\",\"region_confidence\":0,\"processing_time_ms\":59.176758,\"requested_topn\":10,\"coordinates\":[{\"x\":92,\"y\":230},{\"x\":698,\"y\":237},{\"x\":698,\"y\":365},{\"x\":92,\"y\":358}],\"candidates\":[{\"plate\":\"AV8G5XG\",\"confidence\":89.549454,\"matches_template\":0},{\"plate\":\"AV865XG\",\"confidence\":86.135338,\"matches_template\":0},{\"plate\":\"AV8B5XG\",\"confidence\":85.384041,\"matches_template\":0},{\"plate\":\"AV8E5XG\",\"confidence\":85.319023,\"matches_template\":0},{\"plate\":\"AV8S5XG\",\"confidence\":84.502075,\"matches_template\":0},{\"plate\":\"AVBG5XG\",\"confidence\":83.378525,\"matches_template\":0},{\"plate\":\"AV855XG\",\"confidence\":82.600105,\"matches_template\":0},{\"plate\":\"AV85XG\",\"confidence\":81.445183,\"matches_template\":0},{\"plate\":\"AVGG5XG\",\"confidence\":80.773605,\"matches_template\":0},{\"plate\":\"AVB65XG\",\"confidence\":79.964409,\"matches_template\":0}]}]}"
[2021-04-23 16:21:43][DEBUG] : Le dossier /var/www/html/tmp/openALPR/ est a 0
J’ai créé un groupe « test plaque » ou j 'ai rentré diferentes plaques, y compris celle de test ( avec les 2 variantes 6 et G au cas ou )
Puis une action de notification :
rien ne se passe …
Ou ai-je manqué qqchose ?
