Informations Jeedom Delta
Debian : 11.11
Core : 4.4.18 (master)
DNS Jeedom Delta : non
Plugin : Fully KiosK
Version : 2024-09-14 10:36:55 (stable)
J’ai installé l’application Fully Kiosk (v1.56.2) sur une tablette Android et j’ai voulu essayer de configurer le plugin du même nom pour faire remonter quelques informations.
L’installation du plugin s’est bien passée
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_fully_kiosk
0003|+ echo 1
0004|+ echo 2
0005|+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
0006|+ sudo /var/www/html/core/class/../../resources/install_composer.sh
0007|Begin installation of composer
0008|--2024-10-05 11:05:05-- https://getcomposer.org/installer
0009|Resolving getcomposer.org (getcomposer.org)... 2001:41d0:302:1100::8:104f, 54.36.53.46
0010|Connecting to getcomposer.org (getcomposer.org)|2001:41d0:302:1100::8:104f|:443... connected.
0011|HTTP request sent, awaiting response... 200 OK
0012|Length: 58444 (57K) [application/octet-stream]
0013|Saving to: ‘composer-setup.php’
0014|0K .......... .......... .......... .......... .......... 87% 3.28M 0s
0015|50K ....... 100% 64.7M=0.02s
0016|2024-10-05 11:05:06 (3.72 MB/s) - ‘composer-setup.php’ saved [58444/58444]
0017|All settings correct for using Composer
0018|Downloading...
0019|Composer (version 2.8.1) successfully installed to: /var/www/composer.phar
0020|Use it: php composer.phar
0021|End installation of composer
0022|+ echo 3
0023|+ echo 4
0024|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end fully_kiosk
0025|+ echo 5
0026|+ rm /tmp/jeedom_install_in_progress_fully_kiosk
0027|+ echo '*******************End of package installation******************'
0028|*******************End of package installation******************
J’ai ajouté ma tablette via la page du plugin, mais impossible de communiquer avec elle, rien ne remonte.
0000|[2024-10-05 10:58:02] DEBUG : fully_kiosk::getInformations 1251 requesting http://192.168.1.13:2323/?type=json&cmd=deviceInfo&password=
0001|[2024-10-05 10:58:02] DEBUG : fully_kiosk::getInformations 1263 $jsondata
0002|[2024-10-05 10:58:02] INFO : ConnexionKOfor Tablette ASUS (192.168.1.13)
Première question, dans la documentation il est simplement mentionné de saisir le mot de passe. Mais quel mot de passe ? Sachant que je n’ai aucun mot de passe nécessaire à l’allumage ou ouverture de cette tablette.
Bien évidemment quand j’essaie d’utiliser l’outil de configuration avec l’adresse http://192.168.1.13:2323 j’ai une erreur :
Je peux faire un ping sur ma tablette qui répond.
Seconde question : faut-il configurer quelque chose au niveau de l’application FK sur la tablette pour qu’elle communique avec le plugin ?
Si oui, que faut-il paramétrer ? Quelle(s) rubrique(s) ? Car les settings FK sont tentaculaires… et rien n’est mentionné dans la documentation à ce sujet.
Ceux d’entre vous qui utilisent ce plugin, pourraient-ils m’indiquer la marche à suivre ?
