**Je viens de passer sur une clef Conbee II. **
Aprés un passage a vide et déconnection incessante de la clef, aprés chargement du soft, j’ai mise à jour sur Win avec
GCFFlasher -l
GCFFlasher -d COM3 -t 60 -f …/firmware/deCONZ_ConBeeII_0x26580700.bin.GCF
sur Jeedom, la mise à jour est bien appliquée
"1": {
"etag": "6fbcdaac2xxxxxxxxx279100aeb",
"hascolor": false,
"lastseen": "2020-07-30T19:14:46.944",
"manufacturername": "dresden elektronik",
"modelid": "ConBee II",
"name": "Configuration tool 1",
"state": {
"reachable": true
"swversion": "0x26580700",
"type": "Configuration tool",
"uniqueid": "00:21:2e:ff:ff:05:db:f4-01"
**Cela fonctionne sur un PI3 avec détection de 2 capteurs. Mais sur PI4, aucun capteur n'est détecté.**
**Voici les logs, merci de votre aide**
[2020-07-30 20:04:19.281][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-07-30 20:04:19.282][DEBUG] : Closing All Websockets
[2020-07-30 20:04:20.283][DEBUG] : Add gateway : gateway
[2020-07-30 20:04:20.283][DEBUG] : Starting WebSocket for gateway on ip 127.0.0.1 and port 20877
[2020-07-30 21:04:23] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/sensors type : POST [] []
[2020-07-30 21:04:23] deconz.DEBUG: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"37415df5186407b0a7c02dc293473130","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2020-07-30T19:03:40.344","status":180,"sunrise":"2020-07-30T04:43:56","sunset":"2020-07-30T19:43:44"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:04:23] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/lights type : POST [] []
[2020-07-30 21:04:23] deconz.DEBUG: {"1":{"etag":"6fbcdaac2f6be994d4071a5279100aeb","hascolor":false,"lastseen":"2020-07-30T19:04:22.943","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26580700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:04:27] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/lights/1 type : POST [] []
[2020-07-30 21:04:39] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/lights/1 type : POST [] []
[2020-07-30 21:04:43] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : PUT [] []
[2020-07-30 21:04:43] deconz.DEBUG: {"\/config\/permitjoin":180} [] []
[2020-07-30 21:05:15] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:15] deconz.DEBUG: {"UTC":"2020-07-30T19:05:15","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:15","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:15","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:15] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/sensors type : POST [] []
[2020-07-30 21:05:15] deconz.DEBUG: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"37415df5186407b0a7c02dc293473130","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2020-07-30T19:03:40.344","status":180,"sunrise":"2020-07-30T04:43:56","sunset":"2020-07-30T19:43:44"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:05:15] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/lights type : POST [] []
[2020-07-30 21:05:15] deconz.DEBUG: {"1":{"etag":"6fbcdaac2f6be994d4071a5279100aeb","hascolor":false,"lastseen":"2020-07-30T19:05:13.333","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26580700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:05:16] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:16] deconz.DEBUG: {"UTC":"2020-07-30T19:05:16","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:16","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:16","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:17] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:17] deconz.DEBUG: {"UTC":"2020-07-30T19:05:17","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:17","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:17","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:18] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:18] deconz.DEBUG: {"UTC":"2020-07-30T19:05:18","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:18","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:18","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:19] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:19] deconz.DEBUG: {"UTC":"2020-07-30T19:05:19","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:19","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:19","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:20] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:20] deconz.DEBUG: {"UTC":"2020-07-30T19:05:20","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:20","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:20","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:21] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:21] deconz.DEBUG: {"UTC":"2020-07-30T19:05:21","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:21","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:21","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:22] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:22] deconz.DEBUG: {"UTC":"2020-07-30T19:05:22","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:22","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:22","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:23] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : GET [] []
[2020-07-30 21:05:23] deconz.DEBUG: {"UTC":"2020-07-30T19:05:23","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05DBF4","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26580700","gateway":"192.168.1.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.1.145","linkbutton":false,"localtime":"2020-07-30T19:05:23","mac":"dc:a6:32:03:a6:11","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":38099,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"12h","timezone":"Etc\/GMT","uuid":"c5769e74-bb84-48be-9c66-576cb370f92d","websocketnotifyall":true,"websocketport":20877,"whitelist":{"09DC1503E0":{"create date":"2020-07-30T18:16:46","last use date":"2020-07-30T18:46:37","name":"jeedom"},"4DA9032932":{"create date":"2020-07-30T18:11:07","last use date":"2020-07-30T18:11:30","name":"jeedom"},"8FE2467DF1":{"create date":"2020-07-29T20:01:48","last use date":"2020-07-30T17:55:22","name":"jeedom"},"9DDC09DC15":{"create date":"2020-07-30T18:12:18","last use date":"2020-07-30T18:14:56","name":"jeedom"},"A90329328F":{"create date":"2020-07-30T19:04:05","last use date":"2020-07-30T19:05:23","name":"jeedom"}},"zigbeechannel":15} [] []
[2020-07-30 21:05:26] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/sensors type : POST [] []
[2020-07-30 21:05:26] deconz.DEBUG: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"37415df5186407b0a7c02dc293473130","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2020-07-30T19:03:40.344","status":180,"sunrise":"2020-07-30T04:43:56","sunset":"2020-07-30T19:43:44"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:05:26] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/lights type : POST [] []
[2020-07-30 21:05:26] deconz.DEBUG: {"1":{"etag":"6fbcdaac2f6be994d4071a5279100aeb","hascolor":false,"lastseen":"2020-07-30T19:05:25.341","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26580700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:05:30] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/config type : PUT [] []
[2020-07-30 21:05:30] deconz.DEBUG: {"\/config\/permitjoin":180} [] []
[2020-07-30 21:06:28] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/sensors type : POST [] []
[2020-07-30 21:06:28] deconz.DEBUG: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"37415df5186407b0a7c02dc293473130","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2020-07-30T19:03:40.344","status":180,"sunrise":"2020-07-30T04:43:56","sunset":"2020-07-30T19:43:44"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
[2020-07-30 21:06:28] deconz.DEBUG: 127.0.0.1:8484/api/A90329328F/lights type : POST [] []
[2020-07-30 21:06:28] deconz.DEBUG: {"1":{"etag":"6fbcdaac2f6be994d4071a5279100aeb","hascolor":false,"lastseen":"2020-07-30T19:06:27.744","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26580700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:05:db:f4-01"}} [] []
