Je tente une fresh install sur un rpi5 ( bookworm 12.8 ), Jai bien utilisé le script de l’alpha, toute les étapes semble bien se passer, sauf a l’étape 10 (Jeedom install) :
Composer (version 2.8.4) successfully installed to: /root/composer.phar
Use it: php composer.phar
End installation of composer
No composer.lock file present. Updating dependencies to latest instead of installing from lock file. See https://getcomposer.org/install for more information.
Loading composer repositories with package information
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Root composer.json requires influxdata/influxdb-php, it could not be found in any version, there may be a typo in the package name.
Potential causes:
- A typo in the package name
- The package is not available in a stable-enough version according to your minimum-stability setting
see <https://getcomposer.org/doc/04-schema.md#minimum-stability> for more details.
- It's a private package and you forgot to add a custom repository to find it
Read <https://getcomposer.org/doc/articles/troubleshooting.md> for further common problems.
Running update with --no-dev does not mean require-dev is ignored, it just means the packages will not be installed. If dev requirements are blocking the update you have to resolve those problems.
[START INSTALL]
PHP Warning: require_once(/var/www/html/install/../vendor/autoload.php): Failed to open stream: No such file or directory in /var/www/html/install/install.php on line 30
PHP Fatal error: Uncaught Error: Failed opening required '/var/www/html/install/../vendor/autoload.php' (include_path='.:/usr/share/php') in /var/www/html/install/install.php:30
Stack trace:
#0 {main}
thrown in /var/www/html/install/install.php on line 30
Cannot install Jeedom - Cancelling
@Loic est-il possible que ce commit soit la cause ? ou c’est le hasard.
Je peux plus vraiment valider les pr comme ça ou même faire de modification en direct…. Donc pour ce week end c’est mort mais je vais regarder pour en approuver certaine et si quelqu’un de l’équipe jeedom approuve aussi alors je pourrais valider le pr
Ma PR a 4 mois donc on n’est pas à 2 jours près
J’ai pensé ajouter une variable ${JEEDOM_REPO} sur le script d’install pour choisir le repo d’installation aussi, ça m’aurait servi dans le passé…
