Je rencontre un problème assez étrange lors de la tentative de connexion externe à Jeedom Connect et je n’ai pas trouvé de sujet équivalent.
Lorsque j’essaie de me connecter depuis l’exterieur (la connexion depuis le réseau local marche nickel), je reçois un timeout et les logs remontent l’info suivante :
0377|[2023-11-13 09:49:51,400][INFO] : New connection: #23 from IP: ('92.184.107.179', 44906)
0378|[2023-11-13 09:49:51,400][INFO] : Number of client connected #1
0379|[2023-11-13 09:49:51,401][WARNING] : Clients not authenticated #1
0380|[2023-11-13 09:49:51,753][DEBUG] : trying to close unauthenticate client. current time 1699868991.7534025 with max time 3
0381|[2023-11-13 09:49:51,753][WARNING] : no api key found for client ${'id': 23, 'handler': <websocket_server.websocket_server.WebSocketHandler object at 0xffff7c36a470>, 'address': ('92.184.107.179', 44906), 'realIpAdd': None, 'apiKey': None, 'configVersion': None, 'lastReadTimestamp': None, 'lastHistoricReadTimestamp': None, 'openTimestamp': 1699868991.4010663}
0382|[2023-11-13 09:49:52,755][DEBUG] : trying to close unauthenticate client. current time 1699868992.7550921 with max time 3
0383|[2023-11-13 09:49:52,755][WARNING] : no api key found for client ${'id': 23, 'handler': <websocket_server.websocket_server.WebSocketHandler object at 0xffff7c36a470>, 'address': ('92.184.107.179', 44906), 'realIpAdd': None, 'apiKey': None, 'configVersion': None, 'lastReadTimestamp': None, 'lastHistoricReadTimestamp': None, 'openTimestamp': 1699868991.4010663}
0384|[2023-11-13 09:49:53,756][DEBUG] : trying to close unauthenticate client. current time 1699868993.7566867 with max time 3
0385|[2023-11-13 09:49:53,757][WARNING] : no api key found for client ${'id': 23, 'handler': <websocket_server.websocket_server.WebSocketHandler object at 0xffff7c36a470>, 'address': ('92.184.107.179', 44906), 'realIpAdd': None, 'apiKey': None, 'configVersion': None, 'lastReadTimestamp': None, 'lastHistoricReadTimestamp': None, 'openTimestamp': 1699868991.4010663}
0386|[2023-11-13 09:49:54,758][DEBUG] : trying to close unauthenticate client. current time 1699868994.758309 with max time 3
0387|[2023-11-13 09:49:54,758][WARNING] : Over time unauthenticate closing connexion for {'id': 23, 'handler': <websocket_server.websocket_server.WebSocketHandler object at 0xffff7c36a470>, 'address': ('92.184.107.179', 44906), 'realIpAdd': None, 'apiKey': None, 'configVersion': None, 'lastReadTimestamp': None, 'lastHistoricReadTimestamp': None, 'openTimestamp': 1699868991.4010663}
0388|[2023-11-13 09:49:54,758][DEBUG] : Closing connection client #23 from address: ('92.184.107.179', 44906)
0389|[2023-11-13 09:49:54,800][INFO] : Client asked to close connection.
Je laisse l’adresse IP, il s’agit de l’adresse publique de mon mobile sur réseau YouPrice.
Mais si je passe sur Chrome pendant que l’application Jeedom Connect tourne toujours en fond et que je charge une page web.
La connexion Jeadom-Connect aboutit…
Une idée de ce qui peut causer ce problème et, surtout, comment le résoudre (si c’est possible, car si ça vient de l’opérateur…).
Merci à tous !
