Voici, j’espère que c’est bien ça qu’il te faut.
Et oui j’ai 11 commandes.
Merci, bonne journée
0000|[2025-05-25 23:07:00]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0001|[2025-05-25 23:07:00]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0002|[2025-05-25 23:07:00]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0003|[2025-05-25 23:07:01]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0004|[2025-05-25 23:07:03]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0005|[2025-05-25 23:07:04] ERROR : Cancel send, because not connected!
0006|[2025-05-25 23:07:06]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0007|[2025-05-25 23:07:09] ERROR : Cancel send, because not connected!
0008|[2025-05-25 23:07:14] ERROR : Cancel send, because not connected!
0009|[2025-05-25 23:07:17]WARNING : Failed to connect
0010|[2025-05-25 23:07:19] ERROR : No response received after 3.0 retries, continue with next request
0011|[2025-05-25 23:07:19] ERROR : Onduleur Solaredge/I_DC_Current: exception during read request on device id 1, address 40096 -> Modbus Error: [Input/Output] No response received after 3.0 retries, continue with next request
0012|[2025-05-25 23:07:25]WARNING : Failed to connect
0013|[2025-05-25 23:07:25] ERROR : Onduleur Solaredge/I_Statut: exception during read request on device id 1, address 40107 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0014|[2025-05-25 23:07:27]WARNING : Failed to connect [Errno 113] Connect call failed ('192.168.1.11', 1502)
0015|[2025-05-25 23:07:27] ERROR : Onduleur Solaredge/I_AC_Power: exception during read request on device id 1, address 40083 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0016|[2025-05-25 23:07:30]WARNING : Failed to connect [Errno 113] Connect call failed ('192.168.1.11', 1502)
0017|[2025-05-25 23:07:30] ERROR : Onduleur Solaredge/I_Temp_Sink: exception during read request on device id 1, address 40103 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0018|[2025-05-25 23:07:33]WARNING : Failed to connect [Errno 113] Connect call failed ('192.168.1.11', 1502)
0019|[2025-05-25 23:07:33]WARNING : Failed to connect [Errno 113] Connect call failed ('192.168.1.11', 1502)
0020|[2025-05-25 23:07:33] ERROR : Onduleur Solaredge/M_AC_Power: exception during read request on device id 1, address 40206 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0021|[2025-05-25 23:07:36]WARNING : Failed to connect [Errno 113] Connect call failed ('192.168.1.11', 1502)
0022|[2025-05-25 23:07:36]WARNING : Failed to connect [Errno 113] Connect call failed ('192.168.1.11', 1502)
0023|[2025-05-25 23:07:36] ERROR : Onduleur Solaredge/I_AC_VoltageCA: exception during read request on device id 1, address 40076 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0024|[2025-05-25 23:07:36]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0025|[2025-05-25 23:07:37]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0026|[2025-05-25 23:07:37]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0027|[2025-05-25 23:07:37] ERROR : Onduleur Solaredge/I_AC_Current: exception during read request on device id 1, address 40072 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0028|[2025-05-25 23:07:37]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0029|[2025-05-25 23:07:38]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0030|[2025-05-25 23:07:38]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0031|[2025-05-25 23:07:38]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0032|[2025-05-25 23:07:38] ERROR : Onduleur Solaredge/M_AC_VA_A: exception during read request on device id 1, address 40212 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0033|[2025-05-25 23:07:39]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0034|[2025-05-25 23:07:39]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0035|[2025-05-25 23:07:39]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0036|[2025-05-25 23:07:39] ERROR : Onduleur Solaredge/I_AC_Fréquence: exception during read request on device id 1, address 40204 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0037|[2025-05-25 23:07:40]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0038|[2025-05-25 23:07:40]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0039|[2025-05-25 23:07:40]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0040|[2025-05-25 23:07:40]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0041|[2025-05-25 23:07:41] ERROR : Onduleur Solaredge/M_AC_PF: exception during read request on device id 1, address 40221 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0042|[2025-05-25 23:07:41]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0043|[2025-05-25 23:07:41]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0044|[2025-05-25 23:07:42]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0045|[2025-05-25 23:07:42]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0046|[2025-05-25 23:07:42] ERROR : Onduleur Solaredge/I_DC_Voltage: exception during read request on device id 1, address 40098 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0047|[2025-05-25 23:07:42]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0048|[2025-05-25 23:07:43]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0049|[2025-05-25 23:07:43]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0050|[2025-05-25 23:07:43] ERROR : Onduleur Solaredge/I_DC_Current: exception during read request on device id 1, address 40096 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0051|[2025-05-25 23:07:43]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0052|[2025-05-25 23:07:43]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0053|[2025-05-25 23:07:44]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0054|[2025-05-25 23:07:44]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0055|[2025-05-25 23:07:44] ERROR : Onduleur Solaredge/I_Statut: exception during read request on device id 1, address 40107 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0056|[2025-05-25 23:07:44]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0057|[2025-05-25 23:07:45]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0058|[2025-05-25 23:07:45]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0059|[2025-05-25 23:07:45]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0060|[2025-05-25 23:07:45] ERROR : Onduleur Solaredge/I_AC_Power: exception during read request on device id 1, address 40083 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0061|[2025-05-25 23:07:45]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0062|[2025-05-25 23:07:46]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0063|[2025-05-25 23:07:46]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0064|[2025-05-25 23:07:46] ERROR : Onduleur Solaredge/I_Temp_Sink: exception during read request on device id 1, address 40103 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0065|[2025-05-25 23:07:46]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0066|[2025-05-25 23:07:47]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0067|[2025-05-25 23:07:47]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0068|[2025-05-25 23:07:47]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0069|[2025-05-25 23:07:47] ERROR : Onduleur Solaredge/M_AC_Power: exception during read request on device id 1, address 40206 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0070|[2025-05-25 23:07:48]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0071|[2025-05-25 23:07:48]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0072|[2025-05-25 23:07:48]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0073|[2025-05-25 23:07:48] ERROR : Onduleur Solaredge/I_AC_VoltageCA: exception during read request on device id 1, address 40076 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0074|[2025-05-25 23:07:48]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0075|[2025-05-25 23:07:49]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0076|[2025-05-25 23:07:49]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0077|[2025-05-25 23:07:49]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0078|[2025-05-25 23:07:49] ERROR : Onduleur Solaredge/I_AC_Current: exception during read request on device id 1, address 40072 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0079|[2025-05-25 23:07:50]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0080|[2025-05-25 23:07:50]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0081|[2025-05-25 23:07:50]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0082|[2025-05-25 23:07:50]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0083|[2025-05-25 23:07:51] ERROR : Onduleur Solaredge/M_AC_VA_A: exception during read request on device id 1, address 40212 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0084|[2025-05-25 23:07:51]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0085|[2025-05-25 23:07:51]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0086|[2025-05-25 23:07:52]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0087|[2025-05-25 23:07:52] ERROR : Onduleur Solaredge/I_AC_Fréquence: exception during read request on device id 1, address 40204 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0088|[2025-05-25 23:07:52]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0089|[2025-05-25 23:07:52]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0090|[2025-05-25 23:07:52]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0091|[2025-05-25 23:07:53]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0092|[2025-05-25 23:07:53] ERROR : Onduleur Solaredge/M_AC_PF: exception during read request on device id 1, address 40221 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0093|[2025-05-25 23:07:53]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0094|[2025-05-25 23:07:53]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0095|[2025-05-25 23:07:54]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0096|[2025-05-25 23:07:54]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0097|[2025-05-25 23:07:54] ERROR : Onduleur Solaredge/I_DC_Voltage: exception during read request on device id 1, address 40098 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0098|[2025-05-25 23:07:54]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0099|[2025-05-25 23:07:54]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0100|[2025-05-25 23:07:55]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0101|[2025-05-25 23:07:55] ERROR : Onduleur Solaredge/I_DC_Current: exception during read request on device id 1, address 40096 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0102|[2025-05-25 23:07:55]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0103|[2025-05-25 23:07:55]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0104|[2025-05-25 23:07:56]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0105|[2025-05-25 23:07:56]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0106|[2025-05-25 23:07:56] ERROR : Onduleur Solaredge/I_Statut: exception during read request on device id 1, address 40107 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.1.11:1502]
0107|[2025-05-25 23:07:57]WARNING : Failed to connect [Errno 111] Connect call failed ('192.168.1.11', 1502)
0108|[2025-05-26 04:01:03] INFO : MyModbusd: Command 'read' received from jeedom: sending the command to MyModbusClient
